Old 12-20-2006, 05:43 PM   #13726
DennisNyholm's Avatar
There are some 'mods' you can do to the front shocks in order to get them to lower the car more. I don't know the technical term for each part, but maybe someone else can chime in and fill in the blanks. There are two things you can do:
1.) The plastic piece that the shock shafts screws into can be shortened slightly so that the spring perch will sit lower on it. I took off about 1/8" on mine and the shaft could still screw in with plenty of turns on it.
2.) On the shock collar, when it is all the way up on the shock body, hits the screws that hold the shock to the tower. The collar has tapered plastic on the upper and lower part and that is the part that is hitting. You can trim the upper plastic portion of the shock collar so that now you can raise the shock collar another couple of mm.
With both of these mods done to the front shocks, I was easily able to get down to 5 mm and below.
Hope that helps.
DennisNyholm is offline   Reply With Quote
Old 01-30-2007, 04:47 AM   #13727
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Anybody ever try a oneway on carpet with rubber tires? I'm thinking about trying this with cs27's. Todge and Lemeiux's setups on the Losi site use one. Wanted to know others experience with either setups or the oneway.
Dasupacat1 is offline   Reply With Quote
Old 01-30-2007, 05:27 AM   #13728
Mike Haynes's Avatar
A one way is typically faster but is harder to drive at times since you can not easily use breaks without spining out.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 01-30-2007, 05:44 AM   #13729
SteveM's Avatar
Trader Rating: 133 (100%+)
For running stock sedan with rubber on carpet a front one-way is very desirable. I run one on mine and my lap times dropped as a result. Just don't use brakes otherwise you risk spinning out.
SteveM is offline   Reply With Quote
Old 01-30-2007, 05:59 AM   #13730
Dasupacat1's Avatar
I don't use brakes at all. Let the car coast into the turn.
Old 01-30-2007, 06:08 AM   #13731
SteveM's Avatar
Exactly!
Old 01-30-2007, 01:39 PM   #13732
LOSI123's Avatar
Trader Rating: 63 (100%+)
hey guys, i was wondering what weight you can get a xxx-s g+ down to, with titanium screw set & ceramic ball bearings, also the weight without these items
both setups running standard body & ib4200's
regards Paul.
LOSI123 is offline   Reply With Quote
Old 01-30-2007, 03:37 PM   #13733
imjonah's Avatar
Default It be heavy
It is a heavy car, you would have to Dremel out major parts of the chassis, to get it to be as light as the carbon fibre cars. It might help to pull the rear bumper and tape the batteries in place.
imjonah is offline   Reply With Quote
Old 01-30-2007, 05:46 PM   #13734
LOSI123's Avatar
also any one know if the axle part of LOSA9929 mip alu cvd.
is also aluminium or is it just the dogbone?
Old 01-30-2007, 05:48 PM   #13735
LOSI123's Avatar
yeah i know its heavy but i was wondering if anyone has gotten it light and what amount they got it too in grams?
Old 01-30-2007, 06:53 PM   #13736
if my memory serves well, LOSA9929 its just dogbone only, blue anodized
pls visit http://www.losipartshouse.com
Faiz is offline   Reply With Quote
Old 02-08-2007, 12:48 PM   #13737
are people still running this car....reason for asking is im getting one for free and wanted to know if can still compete with the latest TC's
thanks
losi-sw is offline   Reply With Quote
Old 02-08-2007, 01:28 PM   #13738
LOSI123's Avatar
At our local club, me and another guy have been winning with xxx-s i race in 540, he raced in 540 & 27turn stock.
Old 02-08-2007, 03:42 PM   #13739
nemisis's Avatar
can anybody tell me wat would be a good spur to run in the losi on a tight track with a 27 turn stock motor in
nemisis is offline   Reply With Quote
Old 02-08-2007, 06:08 PM   #13740
Sigearhead's Avatar
Trader Rating: 68 (100%+)
The 118 will work but I prefer the 128
Sigearhead is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
