Old 09-01-2006, 02:48 PM   #13636
Send a message via MSN to TAMIYAMANUK
right guys just got my hands on a losi xxxs and am using it as a wet car but i have one promblem its the spindles on the front just keep on breaking although am probly the 2nd best at my track they just break when a tap another car any ideas guys ?????
please dont say drive better as thats what alot of people have said ive even got through the graphite ones as well?
TAMIYAMANUK is offline   Reply With Quote
Old 09-01-2006, 03:02 PM   #13637
dstyles's Avatar
give these a try... and if you're lucky, there was a p-dub type bumper available at one time.
http://www.horizonhobby.com/Products...rodID=LOSA4245
http://www.horizonhobby.com/Products...ProdID=BRP6226
dstyles is offline   Reply With Quote
Old 09-01-2006, 03:09 PM   #13638
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Originally Posted by Tyler Keel
Could anyone give me a good Rubber Tire setup for carpet to start with? Thanks.
TK
Tyler give this one a shot.
http://www.teamlosi.com/ProdInfo/Fil...rackside03.pdf
The link said it was a rubber tire setup.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 09-01-2006, 08:02 PM   #13639
you did'nt mention is it straight or sideways, but assumed you hit another car car straightways then wider bumper would be good answer,
if yours is XXX-S G+ then it have bumper retainer plate, that would help foam bumper not deform too much on crash..
Faiz is offline   Reply With Quote
Old 09-02-2006, 05:10 AM   #13640
so wider front bumper is the key then becasue ive been throught like 3 sets of spindles and its gettin on me tits really so will buy some more G spindles and i nice big bumper on the front
Old 09-03-2006, 03:06 PM   #13641
nemisis's Avatar
Default help
hi i need some help my xxxs graphite is constantly going through spur gears and i cant figure out why its driving me mental please help thanks
nemisis is offline   Reply With Quote
Old 09-03-2006, 03:36 PM   #13642
JAY_UK's Avatar
Send a message via MSN to JAY_UK
Check the following:
Correct meshing between spur gear and pinion.
Correct belt tension.
Drivetrain is free and not bound.
Diffs are not over tightened.
There are no stones/grit sat in the bottom of the chassis (remove the bottom cover plate to inspect.)
You are running the same pitch spur and pinion.
Errrrm, think thats about it!
JAY_UK is offline   Reply With Quote
Old 09-03-2006, 03:45 PM   #13643
nemisis's Avatar
Default tyres
can anyone recomend a good set of rubber tyres for tarmac racing
Old 09-03-2006, 06:17 PM   #13644
JAY_UK's Avatar
Where abouts do you race? What kind of track is it? Twisty, open etc?! You need to give a bit more information so we can help you out.
Have you looked at what the other racers at your track are using? Look at some of the fastest guys cars and see what they are running.
Old 09-04-2006, 11:32 AM   #13645
nemisis's Avatar
well it varies from time to time tight or open so
Old 09-13-2006, 06:21 AM   #13646
Send a message via ICQ to piorc
hey guys, just a question!
does the gp3700 fits on xxx-s g+?
tks a lot
piorc is offline   Reply With Quote
Old 09-21-2006, 07:58 AM   #13647
SteveM's Avatar
Trader Rating: 133 (100%+)
Not unless you file or Dremel the chassis. I have GP3700 and IB3800 packs and I had to shave the slots and the battery strap to get the chassis to accept these larger cells.
tks a lot
SteveM is offline   Reply With Quote
Old 09-25-2006, 12:36 AM   #13648
Default How to remove glue from old stickers ?
Hi guys,
I need some advice. Well, how can I remove glue from old stickers on the XXX-S G+ chassis ? Which method or product can I use ?
Thanks.
Cheers.
Team Losi XXX-S G+ (Mamba Max 7700)
Team Losi XXX-4 G+ (Nosram Matrix 2005 & Storm 3 stars)
Team Xray T1 FK '05 (Nosram Matrix ISTC & Storm 3.5)
Team Orion Avionics Advantage / Team Orion Li-po 3200 Carbon Edition (5) / Futaba 3PK
Blin is offline   Reply With Quote
Old 09-25-2006, 12:40 AM   #13649
olhipster1's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to olhipster1
Default motor spray
use motor spray...then wipe or rub off.
olhipster1 is offline   Reply With Quote
Old 09-25-2006, 12:45 AM   #13650
..then use old rag soaked in acetone to remove remaining adhesive,
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
