Old 12-06-2001, 12:40 PM   #1351
Trips's Avatar
Trader Rating: 16 (100%+)
Sounds like a cool thing BigDog... It would definitely be less of a pain to be able to just drop the TC3 bones right in with no mods.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 12-06-2001, 03:39 PM   #1352
mike_Webb's Avatar
Send a message via AIM to mike_Webb
With the Hodge mod on the rear hub carrier... do you use that mod with the low roll center? I want to get the long ball studs tonight if someone can tell me the Losi part number, or if it is the .188, .250, or .380 Ball stud.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 12-06-2001, 04:31 PM   #1353
STLNLST's Avatar
Trader Rating: 19 (100%+)
mike_webb- I wondered what the part number was myself. I just went out a bought what looks to be the correct ball stud. I bought part number A-9947 (titanium studded balls with hex head .380) It looks like the stud shown in the picture. Hope this helps some
TO ALL-The car was killer last weekend on carpet. I was the TQ over Jimmy Jacobson after the first round of qualifying. I was still running Matt Francis' set up with slight shock angle changes. I'm trying one of Todd's set ups this weekend. I would have posted this sooner but my cable modem provider went bankrupt and they just got us back on line lastnight. Anyone having good luck with the different roll center blocks? The way it's been explained to me it would seem that you would only run the low roll center blocks on tracks that don't have a lot of traction.. Is this true? Doesn't that modification raise the roll center and allow the chassis to roll a little more in turn creating more traction?
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 12-06-2001, 04:50 PM   #1354
HarshGuy's Avatar
I just put washers under the stock ballstuds ...accomplished the same thing (raises the ball).
HarshGuy is offline   Reply With Quote
Old 12-06-2001, 06:21 PM   #1355
STLNLST
Body roll is derived from the distance between the CG and RC. It works on the leverage principle. The further the 2 are away from each other the more leverage there is to cause roll. If the CG and RC are in the exact same spot you should get no roll.
That's what I've been told.
Hello Javier.
Sydewynder is offline   Reply With Quote
Old 12-06-2001, 07:31 PM   #1356
Bobby Z's Avatar
Default Carpet setup with foams
Ok guys. Who ever has any setup advice for a carpet track with foam tires help me out. The track is 60 X 50 and has many 90 and 180 degree corners with not much of a straight away. My car was working wonderful at the beginning of the season but now I'm loosing ground to the TC3's in the corners. I think I have the corner speed, but my overall speed and quickness (punch) just isn't there. All of my other equipment is up to par (batteries, motors, electronics, tires). I'm just looking for more speed whether it be with different gearing or setup or whatever!
Any suggestions?
Here is my current setup:
Front: 57 piston, 70 wt oil, black spring, 5mm ride height (mandatory), shock in 3rd hole out on tower, stock camber link, 1 degree toe out, 4 degree castor blocks, 0 degree kickup, low roll center, -1.5 deg camber, no sway bar.
Rear: 57 piston, 50 wt oil, purple spring, 5 mm ride height, shock in 3rd hole out on tower-outside on arm, #2 & B camber link, 1.5 degree toe-in per side, 0 degree antisquat, -1 degree camber, low roll center, no sway bar.
Misc: TRC Plaid front, TRC purple rear, batteries forward, 41 tooth pulley in rear of car, P2k geared 23/90
Thanks in advance
Bob
Bobby Z is offline   Reply With Quote
Old 12-06-2001, 07:36 PM   #1357
mike_Webb's Avatar
WE HAVE TITANIUM SCREW ACCESS
http://www.t-d-motorsports.com/titanium.htm
This guy did a lot of work trying to find a supplier of TI Screws.
$3.10 a screw is a bit much so I am going to order some a little at a time but now we can get rid of the really heavy Steel Screws
Mike Webb
Old 12-06-2001, 10:50 PM   #1358
SpeedTech's Avatar
Default Christmas Super Sale!! :)
Hi Guys,
Just want to drop a quick note in here that we are having our Christmas Super Sale going on right now!!! For details, check out our website's first page. Those of you that's been thinking about getting our XXX-S hop-ups, now is a good time to get them during our sale. We are also giving away a car kit for FREE this month.
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 12-07-2001, 12:43 AM   #1359
Here are some Carpet setups ive been working on at my home track in Minnesota. Both Foam and Rubber setups for Ozite! Follow this link!
Xxx-s @ Tchr
John_Klick is offline   Reply With Quote
Old 12-07-2001, 09:44 AM   #1360
XER987's Avatar
I AM IN THE PROCESS OF BUILDING MY XXX-S. I'M AT THE SHOCKS NOW AND I NEED SOME HELP. I TRIED TO LOOK FOR A PREVIOUS POST, BUT THERE ARE JUST TOO MANY. ARE THE SHOCKS SHAFTS SUPPOSED TO GET SUCKED BACK UP INTO THE BODY??? I'VE HAD EXPERIENCE WITH THE TYPICAL SHOCKS, BUT NOT THE UPSIDE DOWN ONES. CAN ANYBODY GIVE ME A COUPLE QUICK TIPS?? THANKS.
JOHN
XER987 is offline   Reply With Quote
Old 12-07-2001, 09:51 AM   #1361
mike_Webb's Avatar
Yes... the shaft should suck back in.. Mine suck back about 1/2 to 3/4 way back in.
Mike Webb
Old 12-07-2001, 10:00 AM   #1362
XER987's Avatar
THANKS. THOUGHT I WAS DOING SOMETHING WRONG. I'VE ONLY BEEN RACING FOR A YEAR NOW. I'VE HAD 2 MR-4TC' AND A PRO 3. THE XXX-S SEEMS TO BE THE BEST CAR I'VE BUILT SO FAR. AS FAR AS CONSTRUCTION. I HOPE IT PERFORMS AS WELL. I NEED TO START WHIPPING TOSE TC3'S.
Old 12-07-2001, 10:05 AM   #1363
mike_Webb's Avatar
Well if you really want to whip the TC3's I hope you are a very good driver and running MOD. Right now at our track that is about 4 or 5 XXX-S running stock and in order for us to beat them we have to race a nearly perfect race or else they kill us in the infield
Mike Webb
Old 12-07-2001, 10:39 AM   #1364
Dragonxmx's Avatar
Default Slowing down
Bobby Z,
Just a thought,
If the TC3's lap times are not better and the XXX-S is slowing, I'd change the belt.
Dragonxmx is offline   Reply With Quote
Old 12-07-2001, 10:49 AM   #1365
Jared Kirkwood's Avatar
Send a message via AIM to Jared Kirkwood
Is it really that bad in stock vs. the TC3s? I thought the whole purpose of this car was to be good in stock? I've only had mine on the track once just because the track I raced at stopped with touring cars and only do oval. (Yeah BOO) So I'm just asking.
The day I went to test I was only a few tenths off the tracks best laps. I accounted that being more to due that I wasn't used to the car yet and still lacking a bit on setup as it seemed to push a bit more than the TC3 or my HPI Pro 3 was doing.
If this is the case? What is losi doing to help out? I've not really seen them offering new setups. Hodge only made a comment on TT forum that they learned some new stuff on the carpet put wouldn't tell because he didn't want the AE clan knowing.
Like I said you guys are getting hands on expersience and I'm not right now. I'm just asking and not meaning to burst any bubbles.
Jared Kirkwood is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
