Old 06-25-2006, 07:00 AM   #13591
koinonas's Avatar
Well its been over a month, the clouds went away and the Sun finally came out and finally got the XXX-S to its first race meet. Was very impressed with the handling and control compared to the old TT01.
However still found the drivetrain very tight so stripped it down tonight to flush out and relube the bearings. Found that all bearings were pretty free except for the big ones that the diffs run on. These were rubber shielded bearings and I suspect were a major source of friction in the system.
So wanted to check if everyone out there still runs the original rubber shielded bearing for the diffs, or whether it would be safe for me to change over to a metal shielded one (from what I've heard these roll alot better).
Also since I've put the thing back together, found that the Losi no longer rolls smoothly. I've got the belt reasonably loose (can push it down maybe 10mm in section between rear diff and spur) and it looks like the belt progressively loosens up and then tightens up (and makes a short regular whining noise) as you push the car along.
I'm not the best mechanic so after some hints of what I might have stuffed up and look out for when I strip it down again later this week.
koinonas is offline   Reply With Quote
Old 06-25-2006, 04:05 PM   #13592
XXXS noob here
Hey all.
I just bought an XXXS G+ off ebay...what do i need to look out for?
Going to be using it as a partial drifter, but mainly a speed machine - to replace my ancient HPI Nitro tourer.
What breaks/wears out on these?
TomF is offline   Reply With Quote
Old 06-25-2006, 06:39 PM   #13593
mojoman's Avatar
I use metal shielded diff bearings and lube them after every two to three weeks, depending on how often you run your car. As long as you keep up maintence you should be fine.
If you have a motor in your car your pinion is probably too close to the spur gear. This happens to me a lot. If that's not it check your belt by both 41 tooth gears at the front and rear of the car. It may be pinched.
Good Luck Mate!!!
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 07-04-2006, 05:25 PM   #13594
Does anyone know if Trinity or ANYONE else still make the motor mount heatsinks? I'm buying TSR6's XXX-S G+'s and I also have a XXX-4 G+ (the real reason I want a heatsink. So if anyone knows it would be great.
I was going to read all the posts, but at over 400 somin pages, I'll just ask.
Jay
pyro18t is offline   Reply With Quote
Old 07-05-2006, 03:44 AM   #13595
Menzees's Avatar
Send a message via MSN to Menzees
Default heatsink
There's one on ebay going very cheap if your interested.
http://cgi.ebay.com.au/team-losi-xxx...QQcmdZViewItem
Hope that helps.
Menzees is offline   Reply With Quote
Old 07-05-2006, 03:58 AM   #13596
Menzees's Avatar
Default set up.
Also i've been setting up my car for the past year by trial and error. This is effective but can be time consuming and frustrating. Does anyone know a great all round setup that will do very well on a small indoor track with allot of corners.
Cheers Menzees.
Old 07-05-2006, 04:41 AM   #13597
mojoman's Avatar
Cheers Menzees.
Asphalt or carpet? I use Todd Hodge's SoCal setup from the Losi website. Here is the link. They have a bunch for carpet as well.
Casey Castleman
Old 07-05-2006, 04:41 AM   #13598
Thanks but I'd like to get one new if it's possible, I guess I'm just kinda anal like that.
Jay
Old 07-06-2006, 12:28 AM   #13599
Menzees's Avatar
Thanks allot, Ive heard good things about that setup, very popular in Australia.
Old 07-06-2006, 07:41 AM   #13600
Whats the best upgrades for this car? Does it handel pretty good? And does it even have a chanse wining any races? I just got this car so I am a noobie to electric so please dont flame me.
rclover#0000001 is offline   Reply With Quote
Old 07-06-2006, 07:58 AM   #13601
It wont win any races AT ALL!!!! If you can't drive... it's all about your driving skill.
Jay
Old 07-06-2006, 01:20 PM   #13602
mojoman's Avatar
The one thing invaluable for the car is the black drive belt kit. A 128 tooth spur would be helpful as well. Install the low roll centers in the front and rear of the car. They also make an aluminum hardware set but I don't know who's selling them now??? Carbon fiber shock towers oh yea and don't forget to have fun.
My mom used to say "if you don't have anything nice to say......"well you know the rest.
Casey Castleman
Old 07-06-2006, 04:19 PM   #13603
Thanks dude.
Old 07-06-2006, 04:23 PM   #13604
That's not really how I ment it, what I was tring to say is that if your a bad aaaace driver then your going to be winning with alomst any car. If your not very good and hit walls all the time then more than likely your not going to place.
Do i personally think that the XXX-S is still competative? Heck yeah man!
Jay
P.S. sorry if I came off as a richard.
Old 07-06-2006, 05:10 PM   #13605
Its iight. I understood u anyways.... So it can still be competive eh.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
