Old 05-22-2006, 07:39 AM   #13576
rayhuang's Avatar
Originally Posted by koinonas
Really happy with the handling (setup as it came out of the box) and would say performance will improve when the bearings and motor etc all get worn in a bit more.
Looking forward to when I actually get to take it out for a race meet.
I would recommend the HOdge Reedy Race set-up withg a very tight front diff. I dont race much ooutdoors, but that set-up is so stuipid dialed to me. Its so smooth and predictable even on dirty unprepared concrete the cars planted.
Old 05-23-2006, 07:23 PM   #13577
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
does the tooth cutting thing mess up breaking or acc.?
thedudeaturdoor is offline   Reply With Quote
Old 05-24-2006, 09:01 AM   #13578
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
it makes the drivtrain roll freeier. Also correct me if Im wrong, u may need to tighten the belt tensioner a little. I run my black belt cut maybe every other tooth.
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 05-24-2006, 03:37 PM   #13579
I had a xxx-s and I ran an black belt with everyother tooth cut and the belt tensioner was set at the lowest setting but not lose enought to let the belt slip.
JRXS is offline   Reply With Quote
Old 06-04-2006, 04:54 PM   #13580
mojoman's Avatar
Hey does anybody know where to find the original steel dogbones? I've probably gone through 1/2 dozen aluminum in the past three months. A part # would really be great. Peace.
Casey Castleman
Team Driver: OHP / Jaco / Razor Graphix / Thorpewood
RIP The Coliseum at HobbyTown USA Frederick, MD
mojoman is offline   Reply With Quote
Old 06-04-2006, 06:00 PM   #13581
gearhead13's Avatar
Try www.horizonhobbies.com. they have most all xxx-s parts
gearhead13 is offline   Reply With Quote
Old 06-04-2006, 07:02 PM   #13582
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
I just raced a XXXS that has been handed around to a bunch of local club guys, and for never having driven the car, and dropping my off road radio and motor into it, it worked great. I'm excited to tear it down and go through the car this week. Nice to know the Losis hold up over time.
One question for those who have experience with the kit. After chasing a massive off throttle push entering the corner all day, I finally got the car loosened up on entry to turn, and it turned great on exit, but it was really nervous and twitchy in the middle of the corner, or right exactly on the pick up of throttle.
Granted, the setup on it is relatively unknown, and it was all kind of bashed together to race today, but is there something to look for when taking things apart that might cause such odd behavior in the middle of the corner? It was almost like it was bottoming out and unloading the tires. From what I can remember, it was a blue/silver spring combo, no swaybars, CS27s on asphalt with 5.5mm ride height F/R and a Protoform Stratus. Everything else was kind of left where it was previously.
I think a good going-through with shocks and suspension settings, and a new Maza 6 will help everything greatly, but if someone has experienced this issue and knows a solution, I'm all ears.
TIA,
doug
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 06-04-2006, 07:08 PM   #13583
pls check these > www.losipartshouse.com
Faiz is offline   Reply With Quote
Old 06-05-2006, 10:40 AM   #13584
mojoman's Avatar
Just ordered a pair from losipartshouse should have checked there first. Thanks for your help. We'll have to see how steel holds up to my driving tactics.
Casey Castleman
Old 06-09-2006, 03:16 AM   #13585
TIA,
doug
Id try longer camber links ( should make it more forgiving) and make sure your droop is the same all round.
maybe the car is offloading weight from one wheel in the corner ?
try this ? http://www.teamlosi.com/xxxs_page/xxxs_droop.htm
look more at setting the tweak as losi calls it
they have some good setup sheets to start you off aswell.
Y.Bear is offline   Reply With Quote
Old 06-18-2006, 03:15 AM   #13586
Fast XXXS's Avatar
Trader Rating: 48 (100%+)
Hi,
Is my car to heavy? It weighs 1600g RTR without transponder.
Its a Graphite+ with novak gtx, 2PL radio system, IB3800 and a silver 540 with rubber tyres. Is there anyway i can reduce weight other than dremmeling the chassis and tapping in the battery packs.
Also what would be a good setup running a johnson 540 motor on a rough, low to medium grip, ashphalt track. I heard stock setup works well.
Fast XXXS is offline   Reply With Quote
Old 06-18-2006, 11:04 AM   #13587
Is there any problem fitting 4200's batteries in the G+. I haven't raced it in a few years and I need to buy new packs.
Shawn Plume
www.pmhobbycraft.ca
Frantic Racing (Est. 1988)
Ophidian is offline   Reply With Quote
Old 06-21-2006, 10:23 PM   #13588
Fast XXXS's Avatar
can anyone help me?
Old 06-21-2006, 10:37 PM   #13589
mojoman's Avatar
Originally Posted by Fast XXXS
Hi,
You can reduce weight by swapping out the steel hardware for aluminum. I don't know about 540's I run a stock motor in mine. Don't cut the chassi!!!
Casey Castleman
Old 06-21-2006, 10:41 PM   #13590
mojoman's Avatar
If your battery bar has had 3800's or even 3700's in place it won't be a problem. What I've found is the bar slowly bends with the more batteries you put in the car. Granted I run 3800's without a hitch never tried 4200's. You may have to press pretty hard. Good Luck!
Casey Castleman
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
