Old 08-25-2001, 10:39 PM   #121
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
that a boy paul....thanks for the info trips...
Matt M. is offline   Reply With Quote
Old 08-26-2001, 06:11 AM   #122
Suspended
Go Losi!!!!!!
MASTER XXX-S is offline   Reply With Quote
Old 08-26-2001, 02:04 PM   #123
Taz_S's Avatar
Originally posted by Schuie Driver
I definitely do not agree with the statement that this car is too heavy to be raced competitively. In fact I only plan on adding the graphite chassis, and the shock towers once they are available. Aluminum CVD's may help in the rotating mass department but if they are anything like the TC3's they will be bent as soon as you have a good sized impact. The cars in my area have been in the top 3 ever since it was released and that is in a VERY competitive stock class.
On another note have any of you seen replacement arms showing up at your LHS? I would like to get my hands on a few just for spares and locally spares for this car are simply unavailable.
some people have been using TC3 front arms.
Jake's Performance Hobbies http://www.jphracing.com/
https://www.facebook.com/groups/757500284356171 Facebook Group for Pro 10
Taz_S is offline   Reply With Quote
Old 08-26-2001, 05:16 PM   #124
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
you should start seeing the spare parts within the next 2 weeks.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 08-26-2001, 05:48 PM   #125
I think spare parts are available if your LHS will order them for you. At least they look available according to Horizon's web page. Plan on ordering a graphite shock tower and some arms tomorrow. According to two shops I frequent they have been waiting on the Losi supports pack which includes many of the most common parts.
Saw the other post about Joel and Paul running this weekend at Englishtown. That would have been a sweet race to watch and I hope Joel comes out of retirement to run a few races for Losi in the future. He is a great ambassador for the sport.
Did a little racing this weekend with the car myself on another carpet track in the area. Car was absolutely dialed! Can't wait to get it on the track again next weekend. I used the 2 degree Associated caster blocks this weekend and they really helped the car get around tight turns. If you have not tried it you have nothing to lose
Schuie Driver is offline   Reply With Quote
Old 08-26-2001, 07:52 PM   #126
Trader Rating: 19 (100%+)
If your LHS doesnt stock the part you can always get it from Horizon. Order it on Monday and get it by the weekend.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 08-26-2001, 07:55 PM   #127
RCTech Member #2
TSR6's Avatar
Well, if you LHS has sold a couple XXX-S's, and they stock TC3 parts, i would venture to guess they will stock XXX-S parts within about 2 weeks from now. Parts are still hard to get, and losi doesnt have the shipping dept. straightened out on all the new part #'s ( we ordered a ton of arms, we got XXX arms... not XXX-S..lol )
Troy
RCTech Member #2
Old 08-27-2001, 01:39 PM   #128
mike_Webb's Avatar
Send a message via AIM to mike_Webb
What size e-clips fit the front and rear hinge pins on the outside of that arms on the xxx-s. Also how are you guys measuring toe-in on your touring cars? I don't want to get a Hudy but I already have the RPM Camber Gague and the MIP Tweak Station.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 08-27-2001, 03:19 PM   #129
Mike - I'm not sure on the size of the e-clips (just threw the package out) but I know they are gold in color and are used on the front end of the Losi XXX buggy. So far they have worked great for me and I have not experienced any wheel rubbing issues.
As for front toe I either eyeball it or I use a set of calipers to measure the distance between the front part of the tires and the rear part of the tires.
Old 08-27-2001, 03:31 PM   #130
RCTech Member #2
TSR6's Avatar
I guess the really small HPI clips work.. Although i will not use them on my car... bad karma or something
Troy
RCTech Member #2
Old 08-27-2001, 05:57 PM   #131
R/C Tech Founder
R/C Tech Charter Subscriber
That's good then, 'cause I went home with the two that you gave me! haha
I needed to put the clips on the rear because one of the set screws in my rear carriers wouldn't lock the pin down for some reason. I guess it stripped, which is odd, since I was never able to get it tight enough in the first place to strip it. Oh well, the clips work fine...
futureal is offline   Reply With Quote
Old 08-27-2001, 06:23 PM   #132
RCTech Member #2
TSR6's Avatar
...lol.. you owe me $0.02.. haha! j/k
I don't care... i bought like 3 packages when i got my Racer2... I played "flying e-clip" a couple times when rebuilding it.
Troy
RCTech Member #2
Old 08-27-2001, 07:31 PM   #133
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
The small Losi e-clips are 3/32"
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 08-27-2001, 09:04 PM   #134
mike_Webb's Avatar
Has anyone been running Mod with Sayno 3000 packs? If so how do they compare to the 3000SMH cells. Do you find that you can keep up with the SMH Cells? What tyepes of motors are you running with them. I am looking to get 2 Reedy TI Motors and then buy some armatures for the motors in the Single and Double low wind area.
Mike Webb
Old 08-27-2001, 10:34 PM   #135
Mike-
I run an 8x2 most of the time. I also run a 8x1, 9x1, or 9x2 on occasion. It really depends on the layout, available traction, and gearing gaps.
As long as you have a smooth throttle finger, you should have no trouble with running these motors with any pack with more than 475 sec of runtime @ 20A. The SMH will just have more punch with these winds, as they have a much lower IR, and the voltage seems to hold up better. My Sanyos lost a great deal of runtime and voltage after 30 or so cycles.
Good Luck.
Tim Davis
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
