Old 01-04-2006, 02:14 AM   #13426
EvilDriver's Avatar
Send a message via AIM to EvilDriver Send a message via Skype™ to EvilDriver
Originally Posted by anthony390
can the xxx-4 belt or anything else fit on to the xxx-s?
xxx4 belt do not fit xxx-s do the fact that xxx4 is slightly longer than xxx-s. the only belt that fit would xxx-s is the blue, yellow and upgraded black belt from team losi.
hope that help..
|Xcampus Team Driver |
|Tamiya | TRF | LRP | TEKIN | ORION | Sorex | Futaba| Echologygrafixx |Sweep |
EvilDriver is offline   Reply With Quote
Old 01-04-2006, 07:05 AM   #13427
anthony390's Avatar
Send a message via AIM to anthony390
then wouldnt it act like a black belt
anthony390 is offline   Reply With Quote
Old 01-04-2006, 07:48 AM   #13428
EvilDriver's Avatar
actually no. cause the chassis for xxx4 is slightly longer than the chassis for xxx-s..
the black belt for xxxs parts # [LOSA3280] is longer than the normal xxxs belt ( both blue and yellow)
black belt and it would fit the xxx-s cause it would come with a bigger pulley..
now cause overall chassis of xxx4 is longer the belt for it is would obviously longer.
hope that explain it.. I used to run xxx-s for carpet..
Old 01-04-2006, 02:21 PM   #13429
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
today i had a mis hap
i was drving and i hit some interferance (from my phone i think b/c as soon as i said hello the car was twichy) and then next thing i know, i hit a gun ball abd BAM! there goes my right axle carrier and i think my a-arm
does anyone sells alum. parts for the xxx-s?
thedudeaturdoor is offline   Reply With Quote
Old 01-04-2006, 02:52 PM   #13430
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
what ever you do, dont get aluminum arms or hubs or steering carriers. The reason for, is though they are stronger in stead of breaking something else will bend or those parts will bend instead. Plus it makes ur car lighter. If your doing it for bashing then go ahead and get plastic, instead of aluminum. Thats my opinion. If ur into racing and really care then get graphite. Ive learned from people telling me so thats why i dont have aluminum arms or anything, just the aluminum steering arms.
Hope this helps you out.
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 01-04-2006, 03:01 PM   #13431
anthony390's Avatar
what if i had the bigger idle pulley and the tension arm that goes with it?
also while i have my car open any tips or methods on freeing up the drivetrain?
Old 01-04-2006, 07:33 PM   #13432
You will have to consider limited space between Spur gear and chassis bottom (+ belt ribs height) if you want to make a bigger idler pulley
with black belt kit (+ special alum (longer) tensioner arm) actually the original size idler almost touching belt running under from front pulley,
always clean up all drivertarin bearing about every 10 run, then clean up dirt that may lodging between pulley gears (although xxx-s have enclosed
Do not ever run without original tiny ring (part of LOS A-9933) placed between wheel bearing A-6916, pin A-6401 and wheel hex A-3260, this ring ensure the hex surface only press on inner race surface of wheel bearing and not rub directly to outer race of bearing/hub surface,
IMO, free is relative terms due to xxx-s nature as its a belt driven car, shaft driven car will ALWAYS feels 'free' than belt drive.
Faiz is offline   Reply With Quote
Old 01-04-2006, 07:56 PM   #13433
anthony390's Avatar
well thanks for the info
and all i need to do for a clean smooth drivetrain is to clean the bearings and diffs and oil or lube everything right?
Old 01-04-2006, 08:21 PM   #13434
did u plan using one-way front?
Old 01-04-2006, 08:49 PM   #13435
anthony390's Avatar
nope just regular ball open diffs
Old 01-04-2006, 08:55 PM   #13436
I tried drift tyres before with one-way then diff, and find one-way front is much fun for driftin'
Old 01-04-2006, 09:07 PM   #13437
RCknight's Avatar
Default Are the rummors true that Losi's considering going...
back to the XXX-S one belt design with a cut out for the belt on a cf chassis version, new chassis flex design features and with a future updated molded chassis for the rtr kits. Boy, I hope!
RCknight is offline   Reply With Quote
Old 01-04-2006, 09:11 PM   #13438
EvilDriver's Avatar
when I was running my xxxs Competively on Carpet. I cut the teeths on the belt, not all of them just any other teeths.. ( I cut on teeth, then left the next one alone, then cut the next one after.. like that)..
I notice that i freed up the belts but I have to warn you that this would limit the age of the belt... and with the new black belt kit.. I noticed that you don't have to put a lot of tension on the belt, which in turn would automaticly free up the drivetrain.
hope that help..
Old 01-04-2006, 09:20 PM   #13439
anthony390's Avatar
actualy it did
and well i herd about cutting teeth off but ya i wasnt really interested it that method
maybe i can do some chores and get some money to buy a black belt kit...by the way how much is it?
Old 01-04-2006, 09:24 PM   #13440
anthony390's Avatar
LOL well ya dont have money to buy one-ways but i made my self a spool for myself and learned how to drift with it... i guess thats how im so good in drifting without the worry of changing set-ups but ya i just mostly drift with open diffs but if you give me any midship 4wheel drive car with a spool in the front or back i can drift it like a dream also
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
