Old 01-01-2006, 06:58 PM   #13411
anthony390's Avatar
Send a message via AIM to anthony390
woode up thedudeaturdoor havent seen you at the drift forum for awhile
anyway i would like to get the black belt but i would also like to know the hardest (stiffest) belt out there for losi xxx-s?
anthony390 is offline   Reply With Quote
Old 01-01-2006, 07:07 PM   #13412
thedudeaturdoor's Avatar
Send a message via AIM to thedudeaturdoor
who much is the black belt?
and how easy is it to put in?
thedudeaturdoor is offline   Reply With Quote
Old 01-01-2006, 10:18 PM   #13413
anthony390's Avatar
i dunno
i dont even have a belt but its not that hard to install it
donations still open PLEASE
Old 01-01-2006, 10:19 PM   #13414
Default Balance Weight buggy X-5 Style
Pls let me know, how many grams you all XXX-S/G+ owner put at our left side of chassis for L/R Balancing with these battery :
- GP3300, 3700, IB3600, and IB3800
I think balance weight will heavier, anyone ever split 2 cells on left side (such as Losi XX-4/XXX-4 based buggy X-5 style)?
Faiz is offline   Reply With Quote
Old 01-02-2006, 02:49 AM   #13415
RCknight's Avatar
Default What are you doing with it?
Originally Posted by thedudeaturdoor
ok i just got mine
and what should i up-grade first?
i have HPI cold weather tires
and i dono what i should get sway bars, a black belt or shocks
and how much is the graphite ^grade kit?
Are you racing or playing in the street? One of the first things I would get for racing or playing would be the black belt kit. If your just playing in the steet and you want to go faster, you need a faster motor and higher capacity batteries for longer run times. For a higher level of racing, try to lighten the car up with ti screws/hinge pins/ball studs, molded graphite kit, ceramic bearings/diff-trust balls are all high performace parts. JRX-S shocks are lighter and better. I have not mounted mine yet but I think they will work if you use AE springs and shock perches. Just my two cents.
RCknight is offline   Reply With Quote
Old 01-02-2006, 09:09 AM   #13416
im pretty much racing my step-dads TC4
im gona get the black belt,metal out drives, and sway bars
what is the part number for the G+ conversion?
or can u give me the link
please
Old 01-02-2006, 05:21 PM   #13417
anthony390's Avatar
THANK YOU SO MUCH xxxkat
Old 01-03-2006, 03:46 PM   #13418
i just put in a 13t speed gem by trinity
im using a 17 toon pinion and the stock spur
will this over heat my batterys
and what do u sugest to go down to?
i suck at the whole gearing thing
Old 01-03-2006, 05:32 PM   #13419
RCknight's Avatar
Default Are you running stock tires? Rubber or foams?
I would start with a 22t in 48p and go from there. After a few mins of running it, check the motor, see if it's too hot to put your finger on it for a second or two. It's an easy way of checking your gearing. It should be hot but not too hot that you can't touch it. It can get hot being under geared or over geared. It's not the best way, but it's the cheap and easy way to check. If so, go up or down a few teeth. If you tell me what tires you are running I can check and let you know. Hope this helps.
Old 01-03-2006, 05:39 PM   #13420
RCknight's Avatar
Default It's been awhile since I had one...but
the XXX-S seems to be light on the front tire/motor side of the chassis. I recommend putting your receiver ontop of the servo and move the speedo next to the servo. Hope this helps.
Old 01-03-2006, 10:34 PM   #13421
anthony390's Avatar
can the xxx-4 belt or anything else fit on to the xxx-s?
Old 01-03-2006, 10:41 PM   #13422
Oasis's Avatar
Trader Rating: 36 (100%+)
Not sure,I sent the stuff today so you should get it by the end of the week..
I didn't say it was your fault, I said I was blaming you.
Oasis is offline   Reply With Quote
Old 01-03-2006, 10:48 PM   #13423
anthony390's Avatar
ALRIGHT THANKS
Old 01-04-2006, 12:50 AM   #13424
Belt itself I think its slightly longer than XXX-S
Old 01-04-2006, 01:08 AM   #13425
RCknight's Avatar
Default Yes, I think the belt is....
longer yet.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
