Losi XXX-S
#1321
stef...i ran mine twice, the needle bearings fell out....i called losi, and they sent me new....i talked to lemiux and paul told me the composits seeem to be holding up pretty well....
#1322
I have run my one-way for over a month in both stock and mod without any parts problems.
Chad
Chad
#1323
Chad, have you taken it out and looked at the hubs closely?
The cracks in my hubs are hairthin and almot invisible, but they go all the way through. What's happening is that under load, they are going to spread slightly and the one way bearing will slip inside the hub.
This means no power to the front wheels.
Mr. Losi, I just sent Losi an e-mail, let's see what they say.
Regarding Lemieux's statement, be carefull with what team drivers tell you. First ,they simply cannot admit if there is a problem, second, those guys usually don't hit as much as we mortal people.
#1325
Can I remove 2 mm from my standard shafts rather than buying the short shafts? Seems like I could achive the same results. Is there something I'm missing that would make me buy the new shafts?
#1326
Stefan, I looked at it this weekend when I pulled it out and it was in perfect condition, the other good thing is when I bought mine there was an extra set of hubs with one-way bearings in the package. I was lucky to get a package error in my favor. In the same time I have been running my one-way people I race with have blown up one ways, 1 Losi, 1 TC3, and a poor guy lost 3 or 4 Schu. bearings. I have found that running the front one-way can be very fast but can also be very spendy as you tend to break a lot of fronteend parts. The trick seems to be not to be in the throtlle when you hit some thing.
Chad
Chad
#1327
Chad,
I have been running my one way in my Yokomo for two years w/o any problems.
I run a one way in my Mugen MTX2 and it holds up fine.
I just think, that a molded hub is not though enough for a 8 turn on carpet with foams...
#1328
stef...when paul tels me something it is the truth...he might say something different to someone else, but we are pretty good friends.....he dosnt shit me....
#1330
Did anybody else think the low roll center mod was a pain? I hope it does give me better corner speed.
#1332
Bones
Does anyone know if the TC3 composite or aluminum bones will work with the xxx-s's axle?
#1333
No they will not. Why would you want to do that?
#1334
MDawson- weight, thanks for your answer. That saves me a trip to the hobbyshop. I got a team losi gift certificate but it's only for $100.00 so I'm trying to get everything I can with the coupon.
#1335
A hundred can get you alot of stuff. Good deal.
