Old 10-26-2005, 09:42 PM   #13306
Hey guys nice to know there is a thread for the xxx-s. Its a great design. I have a spare one lying around and I wanted to know if anybody knew if there was a kit to convert it to a rally car or what parts I would need to turn it into a rally car. Any help would be great.
TQchaser is offline   Reply With Quote
Old 10-26-2005, 10:00 PM   #13307
Check this out buddy, hope it helps,
http://sixfoottiger.com/articles/xxxr/xxxr.cfm
Faiz is offline   Reply With Quote
Old 10-26-2005, 11:29 PM   #13308
Thank you this helps alot
Old 11-01-2005, 12:40 PM   #13309
imjonah's Avatar
Default Carpet Setup vs Asphalt setup
I been reviewing the carpet setups on LOSI site.
In general it seems like they go with
6 degree hub things upfront, the offset ones in the rear, and diffs on both ends and anti-sway bar up front.
Any other general rules or advice for stock class, medium size carpet track?
imjonah is offline   Reply With Quote
Old 11-06-2005, 11:05 PM   #13310
Fast XXXS's Avatar
Trader Rating: 48 (100%+)
Hey everyone,
It has probably been mentioned before but my CVD's seem to bind an awful lot when turning a corner. Is their any way i can fix this or even reduce the binding.
Thanks in advance.
Fast XXXS is offline   Reply With Quote
Old 11-08-2005, 01:25 PM   #13311
losi_g+'s Avatar
Originally Posted by Fast XXXS
Hey everyone,
Thanks in advance.
Firstly are your CVD's in good condition? If not, buy the rebuild kit.
Secondly, are they noisy on full lock? Plenty of team drivers used to glue a washer onto the front spindle to reduce chatter.
The noise can also be caused by the CVD's wearing a groove in the outdrive so try replacing these periodically.
Thirdly, the CVD can sometimes catch slightly on the castor blocks.
Try this link for tips on the castor block problem, i know it says it is a problem on the JRX-S but ive seen it on the XXX-S as well using MIP CVD's:
http://www.teamlosi.com/jrxs-page/trick%20tip%20pg2.htm
Hope this helps you. Just send me a pm if you have any more problems!
losi_g+ is offline   Reply With Quote
Old 11-08-2005, 01:59 PM   #13312
losi_g+'s Avatar
I prefer not to go with the front swaybar and use the heavier losi carpet springs but thats personal choice!
Use the long belt and pulley hop up kit as it frees up the drivetrain no end and means you dont have to remove every other tooth on the belt.
Dont use a gear adapter in stock, use losi spurs as the adaptor is too heavy for stock and adds to much rotating mass to the drivetrain.
If the carpet is smooth, stick to low pivot blocks and low roll mounts, either 0F & 0R or 2F & 2R.
Run about 5mm ride height (normally this is minimum for UK events!) and 2-3mm of droop.
Rest is personal choice
If you need any more help or if you want me to send you some good setups, just send me a PM. I have loads of setup info on the XXX-S!
Old 11-08-2005, 04:37 PM   #13313
hey what do you gear it at I have the 64 pitch yellow spur gear and also the 64 pitch blue spur gear, I'm running foam tires trued down super thin
badmojo13 is offline   Reply With Quote
Old 11-09-2005, 10:40 AM   #13314
Use the Blue spur gear, then try and figure out what you will need for a pinion by asking everyone else what they are running for rollout. What is Rollout you ask?
Check this out:
http://www.motortuningsecrets.com/rollout.html
Depending on the motor and track size, you can figure out what to run.
Hope this helps....
nickw is offline   Reply With Quote
Old 11-09-2005, 10:13 PM   #13315
Fast XXXS's Avatar
Thanks for that Losi_g+ i'll try them and see if they work.
Old 11-10-2005, 08:18 AM   #13316
JLMG1971's Avatar
How do you guys race the XXX-S G+ with IB3800? do you dremel the chassis, or they fit right in? I use to have a XXX-S and loved it......just wondering about the new batts domesions and the XXX-S chassis
J
JLMG1971 is offline   Reply With Quote
Old 11-10-2005, 08:24 AM   #13317
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
3x8 thrusts with carbide balls on special at www.axiommotors.com if anyone is interested.
dgullickson is offline   Reply With Quote
Old 11-10-2005, 11:27 AM   #13318
Euge's Avatar
J
I race my XXX-S with GP3700's no problem. Just tape them in. I've always taped in my batteries, even with 3300's.
Euge is offline   Reply With Quote
Old 11-10-2005, 04:40 PM   #13319
as far as gearing goes and roll out, not sure the exact size of tire, so can
t really calculate that, my track is relatively small, and the guys that still run the xxx-s use the yellow spur gear I believe its 108 tooth. I've ran anywhere from a 25 to a 30 tooth pinion with a monster and I still seem to get blown away in the straights, and also just in general. I just put a new comm in the motor, spaced it the best I could, and then I am using the trinity long life brushes, with red on the positive and green on the negative, I also have an epic, p2k2, p2k, to choose from
Old 11-10-2005, 04:53 PM   #13320
losi_g+'s Avatar
Me too. Although this isnt really a chassis where tweak is a problem. If you wanna use the strap, put a couple of spacers under the battery posts to raise it up a bit!
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
