Old 10-04-2005, 04:05 PM   #13291
Trader Rating: 195 (99%+)
How about just grinding the battery down. Its the problem. Not the car
Please become an organ donor.
www.donatelife.net
Custom decals and Sno-Tee'z, T-Shirts by Sno Camel
dodgeguy is offline   Reply With Quote
Old 10-04-2005, 04:41 PM   #13292
Default Battery fittage
One thing I did with xxx-s is raise the battery mounting posts up
with washers.
SrRC is offline   Reply With Quote
Old 10-05-2005, 03:04 AM   #13293
Buck Nasty's Avatar
I think I'll stick to the gp3300 for this car & the XXX4 for awile.
I'll run the IB3800's it the MF2 & BK2.
I think, therefore I'm single. Buck Nasty
Buck Nasty is offline   Reply With Quote
Old 10-17-2005, 04:41 PM   #13294
imjonah's Avatar
Default XXX-S and ROAR Nationals
I entered my XXX-S G+ in the Master class at the ROAR Nationals in Tampa last week. I searched all the pit areas, I did not see a single other XXX-S the only Losi cars I Saw were the JXRS. I may have missed one in one of the little trailers or tents but I looked real hard caus I was hoping to get some set up advice, I never found another one.
What is weird is that the one big race we had in Colorado this year, the Fall Classic, the stock class was won by a 50 year old guy driving an XXX-S G+ with a front diff.
So it seems the XXX-S is still competitive, but not no longer at the national level.
Since diving skill is my limiting factor the car is more than adequate for me.
Any advantage the JXRS might have is wasted on me.
imjonah is offline   Reply With Quote
Old 10-23-2005, 12:58 AM   #13295
RCknight's Avatar
Default imjonah...
the XXX-S is a fine car. It's the next marketing hype. The problem is new batteries will not fit in the car. Since Losi will continue to market the XXX-S in rtr kits, I would think the would continue to update the car. All those poor people buying the rtr can't use new loose made batteries packs.
Anyone know if 3800 STICK packs will fit into the XXX-S without mods?
I hope Losi will continue to keep the XXX-S around and update it. It's the best belted car for dirty tracks and street bashing.
RCknight is offline   Reply With Quote
Old 10-23-2005, 03:04 AM   #13296
T. Thomas's Avatar
THey use the same mold for the XXX-4 and just add one piece to it at the rear end to langthen it for this vehicle. So I would assume they would change the battery mount to accomidate the new cells, even though I thought the 3300's were already at MAX diameter for the cell, guess not.
T. Thomas is offline   Reply With Quote
Old 10-23-2005, 03:18 AM   #13297
RCknight's Avatar
Default tthomas...
I'm not sure I'm following. Do you mean that the 3800s fit in the XXX-4 and they whould fit in the XXX-S or do you have to buy the XXX-4 chassis to replace the XXX-S chassis? Thanks
Old 10-23-2005, 07:44 AM   #13298
The new IB's do not fit the chassis of the XXXs at all. The GP3300 was a larger cell also. They did not fit the Losi car very good either.
The IB3600 fit the car perfect.
www.donatelife.net
Old 10-23-2005, 09:33 AM   #13299
T. Thomas's Avatar
I know the GP3300's do fit the XXX-4 and XXX-S flush on the bottom, so no modifications are needed unless you run additional shrink wrap on the cells. With just the MFG shrink wraps, they fit.
No I am saying that the XXX-S and XXX-4 uses the same mold with the difference of the XXX-4 having an added 1/2 piece of mold added to make it longer. If the new cells do not fit either car, and they plan on continuin to sell the XXX-4, the it would be benifitial for them to have it retooled so the new cells fit.
Old 10-23-2005, 09:40 AM   #13300
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
GP3300's no matter how much shrink wrap you put on them fit, within reason. If you are faced with the delima of the newer cells not fitting, you can always raise the battery brace mounts, place an o-ring between the chassis and the mount, and the new cells should fit, if this doesn't work, space it some more. I have never had problems with double shrinkwrapped cells fitting in any of my G+ chassis's. If anyone is having problems with the car or are looking for a set-up feel free to contact me about it. Also, if anyone needs a list of good mods to the car, feel free to contact me on that too.
tc3stocker is offline   Reply With Quote
Old 10-23-2005, 10:19 AM   #13301
losi_g+'s Avatar
Thats one of the options, the other is to tape the cells in as i do!
losi_g+ is offline   Reply With Quote
Old 10-23-2005, 04:18 PM   #13302
losi_g+'s Avatar
BTW. Can someone tell me how long your front droop screws are as i think i have the wrong ones in my car. They stick out from the chassis way too much and catch on the carpet or tarmac!
Old 10-23-2005, 11:46 PM   #13303
Red RSX's Avatar
about 6 mm coreect me if I'm wrong,
yeah, this droop screw are often catch the ground,
I delete this one and put inside shock spacer, more consisten,
though hassle to set different setup,
Red RSX is offline   Reply With Quote
Old 10-25-2005, 02:06 PM   #13304
losi_g+'s Avatar
tc3stocker YGPM!
Old 10-25-2005, 04:59 PM   #13305
losi_g+'s Avatar
Think TBH, im just gonna either get my local hardware shop to order me some shorter grub screws or cut these down. They work well enough and are easy to set up so i dont see any reason to use shock limiters, although im not sure how you would use them to control droop!
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
