Old 09-28-2005, 10:13 PM   #13261
Still Bill's Avatar
Originally Posted by tfrahm
Anybody with any tips or ideas?
tfrahm,
I sincerely suggest that you start communicating with Todd Hodge on the Hodgimoto thread. Todd should be able to direct you to a setup for your conditions. Just give him as much detail about the track conditions as you can.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 09-29-2005, 02:02 PM   #13262
tfrahm's Avatar
Send a message via AIM to tfrahm
Originally Posted by Red RSX
tom, we have no idea the kind of your car setup is,
could you post your shock setup and front and rear geometry so it might any idea for yours,
* MODIFIED Class: LOSI XXX-S G+ Sedan
-- CS-27's
-- G. cl @ LF = 7.0 mm RF = 7.0 mm
G. cl @ LR = 6.75mm RR = 7.0 mm
FRONT:
-- #2F (Tri. RED Al) pivot support (Lower holes) w/red Tri. Al 'low r/c' blocks
('True' low roll center, not the LOSI "low"-medium roll center blocks)
Shocks;
-- .28 w/#57 piston, 40wt oil
-- PURPLE LOSI springs (14.6 #/in)
-- mounted in #1 hole in tower...
Sway Bar; 0.055 (officially 0.06?) FRONT sway bar
REAR:
-- #0R (Tri. RED Al) pivot support (lower holes) w/red Tri. Al 'low r/c' blocks
Shocks;
-- .36 w/#56 piston, 30wt oil
-- Silver LOSI springs (12.6 #/in)
-- mounted in #2 hole in tower, outside on arm...
* Stock Class: LOSI XXX-S with graphite conversion (1st generation)
-- CS-27GL's
-- G. cl @ LF = 7.75mm RF = 7.5 mm
G. cl @ LR = 8.25mm RR = 8.25mm
FRONT:
-- #2F pivot support (lower holes) w/red Tri. Al 'low roll center' blocks
Shocks;
-- #60 piston, 40wt oil
-- Blue LOSI springs (14.6 #/in)
REAR:
#4R pivot support (UPPER holes) with Low roll center blocks
(this produces pro-squat)
Shocks;
-- #56 piston, 30wt oil
Bodies vary -- Stratus 3.0 AP / Mazda 6 /LOSI Alfa depending on track conditions...
"If you cannot win, make the one ahead of you break the record."
Biff Racing Team #420 (Ah... The "good old days"...)
The local indoor Offroad Track: The RC Race Barn
TLR22-3.0, TLR22T-2.0, TLR22SCT-1.0
tfrahm is offline   Reply With Quote
Old 09-29-2005, 03:19 PM   #13263
Scottmisfits's Avatar
Does Losi make a spool for the XXXS? I have looked at their site and they have spool pads but I couldn't find the spool diff on the site anywhere.
A part number would be great as well.
Thanks,
Scott
Scottmisfits is offline   Reply With Quote
Old 09-29-2005, 04:06 PM   #13264
rivbluenoma's Avatar
according to the instructions for the xxx-s g+, you have to use the stock diff, remove the diff balls in the pulley and throw a spool pad on each side and tighten it down. probably not what your looking for, but its the only one that ive seen so far.
rivbluenoma is offline   Reply With Quote
Old 09-29-2005, 04:19 PM   #13265
I'm sure that will work just what I want it for.
Anybody have a pic of what the spool paads look like. Nobody around here really carries all that much in the way of Losi parts, let alone onroad parts.
Old 09-29-2005, 04:32 PM   #13266
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
the spool pads are really sand paper. You can just find a real rough sand paper and use that. I believe Losi is coming out with a newer version of the spool pads. Or you can do what I did. Which is use JB Weld, Epoxy, or Shoegoo. What you do is take the diff balls out of the pully, epoxy or whatever you use the diff ring to the diff pully. Then once that drives thats your spool. Then you just tighten the diff screw as much as you can. I made one this pas weekend and its very strong. I used JB weld and it will hold. IRS makes a spool for the XXX-S but you would have to call them or find out if your LHS has one. Though IRS doesnt make the spool anymore you can still check.
Hope this helps.
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 09-29-2005, 04:41 PM   #13267
So sand paper towards the diff rings or towards the gear? I have a couple of diffs so it really wouldn't be a big deal.
And to try and correct the understeer, could I use the overdrive pulley?
Old 09-29-2005, 08:40 PM   #13268
Red RSX's Avatar
I forgot which page, Todd Hodge setup mention about overdrive on 41 pulley up front and slightly adjusted overdrive via smaller diameter front tyre (foam tyre)...
I've tried it, give lots of front traction out of corner... but entering corner feels binding the drivetrain slightly, curious of possibility one-way spool for XXX-S consider no existence of layshaft pulley,
Red RSX is offline   Reply With Quote
Old 09-30-2005, 02:00 PM   #13269
I had it once but now I can't find it. I'm looking for the color coding for the XXXS gears. I had it saved on my laptop but it fried and I got a new one, and I couldn't go in and get all of my stuff from the old one.
If someone has this, that would be great.
Old 09-30-2005, 05:57 PM   #13270
wolfman76's Avatar
Is there any way i can get more steering out of my XXX-S g+. At my track i'm alright going through the sweeper, but when it comes to the hair pin or the other tight sections the XRAYS just blow me away Unfortunately it's getting to the point where i think i'm going to have to buy an XRAY to keep up with everybody else
wolfman76 is offline   Reply With Quote
Old 09-30-2005, 08:01 PM   #13271
48 pitch
90 tooth = orange
86 tooth = red/pink
88 tooth = yellow
sorry dont know what the 64 pitch colors are.
Old 09-30-2005, 11:14 PM   #13272
Thanks Riv. Exactly what I was looking for.
Old 09-30-2005, 11:26 PM   #13273
RLS
RLS's Avatar
IRS makes a nice 1 piece red-anodized spool for the XXX-S. Check out kthobbies.com, click 'closeouts' and look for part #IRS181. It's $23.99 and well worth it IMO. I had no luck with the sandpaper discs. KT Hobbies also has most of their XXX-S parts inventory in the closeout section. Happy shopping!
RLS is offline   Reply With Quote
Old 10-01-2005, 11:44 AM   #13274
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
anyone have feedback on ordering from kthobbies.com?
thanks =P
☆ Joe Tran ☆
tr1kstanc3 is offline   Reply With Quote
Old 10-01-2005, 11:47 AM   #13275
POOKYT's Avatar
thanks =P
I have used them in the past and they really seem to ship fast and keep you updated on the order a lot. On-line ordering was straight forward and easy. I'd give them an A. Good Luck!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
