Old 06-29-2005, 12:50 PM   #13201
POOKYT's Avatar
Originally Posted by Slow4dr
I suck at mounting touring car bodies. Does the Losi Skoda have dimples for the XXX-S?
Nope--Sorry just for the JRXS. Just put the clear body over the car before you paint it and mark the holes. I painted one for a buddy with a XXXS. The front wheels and the lines marked on the Skoda 2 fit just fine on the XXXS. Take your time and you can do it.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 06-29-2005, 05:29 PM   #13202
Send a message via MSN to Bigger Brother
My Skoda (mk 1) came with marks for the XXX-S ... I think the Skoda 2 only has marks for the JRX-S
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 06-29-2005, 05:39 PM   #13203
POOKYT's Avatar
You are correct.
Brant
Old 06-29-2005, 09:37 PM   #13204
Still Bill's Avatar
Yes, the Skoda 1 does have the dimples for the XXX-S. The Skoda 2 has them placed for the JRX-S.
The best method for me has been to mark the body before being painted. It also helps to not have looooooong body mounting posts. Mine only stick up a couple holes beyond the hole where I fasten the upper body clip. YOU CAN DO IT!
Bill
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 07-14-2005, 12:29 PM   #13205
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default Ride height
Hi all
I was running carpet the other day and had the tire diameters at 58.5mm and running Silver springs in the rear but I was unable to get a 5mm ride height in the rear. The threaded shock collars were at there maximum. The shock tower was at the 2nd innermost (standup) setting. I was able to get barley 5mm when laying the shocks down (4th outtermost hole) but again I had very little adjustment ability with the shovck collar.
Any thoughts?
rinkrat99 is offline   Reply With Quote
Old 07-14-2005, 12:33 PM   #13206
POOKYT's Avatar
Originally Posted by rinkrat99
Hi all
Any thoughts?
You can cut 1/8" off of the top of the lower shock shaft end to lower the spring keeper. This may give you just enough to get your ride height right. Good Luck
Brant
Old 07-14-2005, 03:54 PM   #13207
Buck Nasty's Avatar
Brant
What about running your bk/pk bars on the rear? won't that work?
I think, therefore I'm single. Buck Nasty
Buck Nasty is offline   Reply With Quote
Old 07-14-2005, 04:47 PM   #13208
Juan Valdez's Avatar
Hi all
Any thoughts?
Can you clarify if you mean you have too much or too little ride height? I assume you mean too little ride height.
Are you out of droop? If you lift your car up, will the rear tires stay on the ground until you reach 5mm ride height? If not, you don't have enough droop and need to back the droop screws off (if you use them) or unthread your shock ends a couple turns to increase your shock length.
If you've run out of room to crank down on the preload collars, maybe try using some spacers between the collars and springs for additional preload. Use something like the non-threaded Associated shocks use for preload adjustment.
Another thing you may want to try is a stiffer spring, as silvers seem soft to me for foams on carpet. When I was running foam/carpet with my XXX-S last winter, I ran orange (35 lbs) fronts and black (25 lbs) rears, much stiffer than the silvers (15.5 lbs I think ). But every track is different, so maybe that wouldn't work for you. The stiffer spring will require less preload, so you won't have to crank down on the collars as far, making it easier to make 5 mm ride height. That said, I think I ran silvers on the back of my car when I ran foams on ashpalt, and don't remember having any issues with making ride height. I'd just start by checking if anything is physically limiting you suspension's movement/droop and go from there. Hope this helps. Good luck!
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05 | Exotek F1R3
Juan Valdez is offline   Reply With Quote
Old 07-14-2005, 07:31 PM   #13209
POOKYT's Avatar
I dunno. If you do that then you will need to go to a softer spring like on the JRXS. Could be cool though. I would have to make sure they fit the XXXS arms as well.
Brant
Old 07-15-2005, 04:15 AM   #13210
Buck Nasty's Avatar
Hi all
Any thoughts?
Also you can use ball studs and long rod ends on the rear. I have seen carpet guy's run the rear shocks that way. You get much longer shocks. You can even cut down the rod ends to suite your needs.
Old 07-16-2005, 02:37 PM   #13211
harkonen's Avatar
Trader Rating: 18 (100%+)
I'm sure this has been covered somewhere in this thread at some point. But I didn't feel like going through 440 pages. I have a problem with my wheel nuts not tightening down to the locking part of the nut on my XXX-S G+. It's like the axles it came with aren't long enough. Has anyone else had this problem? I bought the Associated hexs thinking that's why everone recommends those, but it didn't change it at all.
harkonen is offline   Reply With Quote
Old 07-16-2005, 06:04 PM   #13212
Still Bill's Avatar
harkonen,
The Associated hexes are wider than the standard Losi hexes. Therefore, you have fewer axle threads available to fasten the nut to.
Buy "low-profile" (thin) aluminum locknuts so that the stub axle's threads catch more of the nylon material on the locknut.
Bill
Old 07-16-2005, 06:27 PM   #13213
also if you can get your hands on them without buying the whole drive shaft the assc tc3 stub axles(without the cvd) are longer and the same diameter as xxx-s.
Poppa Ray is offline   Reply With Quote
Old 07-16-2005, 07:05 PM   #13214
Still Bill's Avatar
Low profile aluminum locknuts are cheap and weigh less than standard locknuts.
Old 07-17-2005, 01:16 PM   #13215
Default 19T and stock gearing help
There's not enough hours in my one day off to search for the answer in this thread...
What are good places to start for both motors? I'm running an Epic stock motor (the ROAR legal version) and either a Chameleon or a Reedy 19T.
Slow4dr is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
