Old 05-09-2005, 08:04 AM   #13126
Still Bill's Avatar
Originally posted by STLNLST
I still feel that the sealed drive train was the best thing the XXXS had going for it.
Agreed. Keeping one running for now.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-09-2005, 08:16 AM   #13127
Buck Nasty's Avatar
Originally posted by Y.Bear
Not bad, it looks the part. but does all that milling help? and would it not take away the idea of a xxxs chassis runing a good clean driveline? i race indoors on carpet and bye runing a light speedie and foams my car is now only 5grams overweight ( we run at 1525grams ) and with a light 1700 stick pack im down to 1475grams. but you guys might run lighter than us. as for the car its looks like they have down a lot of work on it and as it says you can now add weight in the spots that will help the car most.
Good luck
thanks for the input. i have only raced on-road twice and really like it. just that the original xxxs i had seemed a little heavy looking and all the newer cars have open belts. were i race the cars come off the trace clean and they have a compressor so after every run i clean my car anyway. for the money it should be fun experimenting with it anyway.
Buck Nasty is offline   Reply With Quote
Old 05-19-2005, 01:51 PM   #13128
Post xxx-s+g setup Asphalt and Carpet
Thanks bill for you help and info. I have a another question.
Can you provide me with your Carpet and a Asphalt setups.
It seems to me that the car handles better with positive camber than negative.
What would you change to this setup and
what's the differents between your asphalt setup.
Anyone care to share their setup
Current carpet setups is: (XXX-S+G)
Front
Oil: 60 wt.
Piston: 56
Springs: Losi Blue
Diff: Standard (tight)
Camber: 1 degrees
Shock Position on towner: #2
Shock position on arm: Standard
Camber Link: #1
Ride Ht: 5mm
Toe: 0
Droop: 1 mm (spring play after proper ride height)
Caster Carrier: 4 degrees
Front Pivot Block: 2F
Low roll center
Rear
Oil: 60 wt.
Piston: 56
Springs: Losi Sliver
Camber: 1 degrees
Shock position on arm: Inside
Camber Link: B or hole closest to wheel
Ride Ht: 5mm
Low Roll Center
Toe: 2 1/2 degrees (1/2 degrees block in the correct way) Adding 1/2 degrees seems to lock down the rear so I can increase my cornering speed.
Rear Pivot Block: 2R
Motor: Monster Pro /Core stock 27 turn
Tires: CS
Traction: Jack the ripper
rob
Cup of Losi is offline   Reply With Quote
Old 05-19-2005, 11:33 PM   #13129
Still Bill's Avatar
Default Re: xxx-s+g setup Asphalt and Carpet
Hi Rob,
Got your PM too.
Not sure what you mean by the above. The rest of your setup seems plausible enough. Would like to see your car at the track sometime; but, I am getting ready to head off to the LA area to meet up with Todd Hodge about JRX-S setups and spectate at the Reedy.
Bill
Old 05-19-2005, 11:43 PM   #13130
POOKYT's Avatar
Default Re: Re: xxx-s+g setup Asphalt and Carpet
Originally posted by JRX-S Bill
Hi Rob,
Got your PM too.
Bill
Bill--Take your camera and note buddy!!! Hope you have a great time. Be safe.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 05-19-2005, 11:55 PM   #13131
Still Bill's Avatar
Default Re: Re: Re: xxx-s+g setup Asphalt and Carpet
Brant
Thanks Brant.
I be the guy cheering on the JRX-S drivers...
Old 05-20-2005, 03:22 AM   #13132
Coming out of tight corners i get oversteer and people are coming under me but entering a corner my car is very stable and fast. so would softer springs help ? or should i look further into my setup ?
im runing 540 siver can and dont have that much punch leaving a corner, so if i can mantain speed without the pushing out it would better my lap times bigtime. I run standard diff with the front a little tighter than the rear and use a standerd carpet setup off the losi site. with the standard rtr springs ( blue )
would the overdriver gear help in this case or maybe a oneway ?
any help would be apreciated
Y.Bear is offline   Reply With Quote
Old 05-25-2005, 08:56 PM   #13133
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default XXX-S Asphalt wheel rubbing front spindle
Hi all
I ran the XXX-S for the first time this past week on asphalt with Yokomo tires and wheels and noticed that the hex was imbedded into the front wheels and the arm and spindle were worn from friction.
I suspect that the hex went too deep into the wheel thus bringing the wheel closer to the spindle and arm. Is this caused by a wheel offset or something else?
rinkrat99 is offline   Reply With Quote
Old 05-25-2005, 11:56 PM   #13134
Fatboy Joe's Avatar
Originally Posted by rinkrat99
Hi all
Same thing happened to me before. Check the Yokomo rim, the inside stiffening ribs of the rim might be hitting the spindle and arm when you are cornering. Also, check for your car's steering EPA, you can adjust it in your transmitter.
Fatboy Joe is offline   Reply With Quote
Old 05-26-2005, 02:30 AM   #13135
highwayman's Avatar
i assume you oversteer on-power ??? if so... you're lacking rear forward traction... in my opinion you should try these out first :
1. check your ride height... make sure its level, then try raising the rear by 0.5mm
2. try standing up the shocks in the rear... one hole at a time...
3. 3 degree toe-in in the rear.
highwayman is offline   Reply With Quote
Old 05-27-2005, 12:20 AM   #13136
thanks for the input ill try out and see how i go
Old 05-28-2005, 04:46 PM   #13137
Buck Nasty's Avatar
any chance we'll see lcd's for the xxx-s?
Old 05-28-2005, 05:06 PM   #13138
POOKYT's Avatar
Hodge has posted a week or so ago that the LCD's are in the works for the XXXS. Shouldn't be too long.
Brant
Old 05-28-2005, 08:08 PM   #13139
Buck Nasty's Avatar
Brant
Sweet!!!!!
Old 06-07-2005, 10:34 PM   #13140
Default set up for dusty concrete
Hi guys do any of you have a good setup for dusty concrete ? Fast smooth track but very slipery. What type of tyres etc. Thanks for any input.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
