Old 04-18-2005, 05:22 PM   #13096
POOKYT's Avatar
Ditto for me too. I get daily updates to this thread and am happy when ever I can help anybody. Plus, untill the JRXS gets here I'm still running the ole G+!!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-23-2005, 07:33 AM   #13097
Default has anyone run the xxxs on carpet with a standard 540
Has anyone run the xxxs on carpet with a standard 540 J moter ?
I race in buget 540 class and im looking for any setup help on a medium but fast track. What gearing would be good and do you guys run foams? if so wat shore. All the set up sheets have been for a mod or stock moter. At my track silver cans are only down 2-3 laps on a stock moter. Is the graphite kit worth getting ? . next week is the first outing with the xxxs so i was hopeing to get gears to suit before hand. Thanks for any help.
Y.Bear is offline   Reply With Quote
Old 04-23-2005, 05:45 PM   #13098
POOKYT's Avatar
Default Re: has anyone run the xxxs on carpet with a standard 540
Our local 540 class ( parking lot with rubber tires) run a very tal gear ratio to make the siver can motors fast. When the regular stock motors are running a 6.58 final the 540 racers will be in the low 5.0's. Good Luck
Brant
l
Old 04-29-2005, 11:22 PM   #13099
Have run my RTR a couple of times and come up with gearing of a 37 pin and 88 spur with a silver can J moter hard wired to speedie i have put aside the novac speedy and put in my eco ( its seems better than the novac ). The car can still be geared up 1 to 2 teeth at the most before the moter gets to hot, ive cut out every second to from belt and that gave me an extra 1-2 min peek power with my batterys (1700 sanyo nicads.) the prob i have now is that i need to drop weight by 60grams ?. Any Help would be apreciated , also have u guys been happy with the novac that came in the car ?.
I think this car can be quit quik but needs some fine tuning the rolling department. Have you guys tryd the black belt kit ?
Old 04-30-2005, 03:09 AM   #13100
POOKYT's Avatar
The black belt is a must if you want a free drivetrain. Also, clean out the factory grease in the bearings and relube them with a light oil. Weight reduction is tough even with the graphite conversion. Good Luck!
Brant
Old 04-30-2005, 06:48 AM   #13101
Wicked's Avatar
HEy guys.
Well I don't really like my shocks on my xxx-s rtr so I was wondering if I can just buy the threaded collars or do I have to buy the complete G+ shocks?
thanks..
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 04-30-2005, 02:42 PM   #13102
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Correct me if I am wrong, but am I right in thinking that my rear toe is 2 degrees if I have the 0 degree hub carriers on the car?
ClemsonTigers
USVTA # 224
Team C Racing USA / TC 10 2015
ERC
RKeasler is offline   Reply With Quote
Old 04-30-2005, 03:01 PM   #13103
POOKYT's Avatar
Originally posted by Wicked
HEy guys.
thanks..
You can order just the threaded shock bodies and the adjuster nuts then use you shafts-pistons and hardware. If you choose to buy the complete threaded shock kits( fr and rr) you will also getr the nitride coated shafts which are expensive individually. Good Luck!
Brant
Old 04-30-2005, 03:03 PM   #13104
POOKYT's Avatar
Yes, total of 2 deg. toe. If you desire less toe-in then you can buy the 1/2 deg. hubs and use them on their opposite sides. IE-left hub goes on the right side and vice versa. Good Luck!
Brant
Old 04-30-2005, 05:06 PM   #13105
RCknight's Avatar
Default Wicked if your going to spend the money...
get the new JRX-S shocks. They are very nice and detailed. I'm also told they are as smooth as the Tamiya ones. I'm getting a set for my TC4 and XXX-S. The new HPI 05 spec went to the same design.
RCknight is offline   Reply With Quote
Old 04-30-2005, 05:14 PM   #13106
Ghost-Rider's Avatar
hello every body i'm new here, first message
Ghost-Rider is offline   Reply With Quote
Old 05-01-2005, 07:44 AM   #13107
Default testimonial
Just as a statement for how good this car is I'm in the middle of trading my backup car for an x-ray evo 2! And no I won't be getting rid of my primary xxxs any time soon, I'm just getting the xray 'cause, dang, those are some cool looking cars!
Poppa Ray is offline   Reply With Quote
Old 05-02-2005, 06:59 PM   #13108
I have a xxx-s that I got when they first came out. I have the first graphite upgrade kit that they offered, with the old style chassis. What upgrades should I look for first? I am going from running on concrete to carpet. Should I stick to a front diff, one way, or a spool, and what are the part numbers? What is the black belt kit for? Sorry for so many questions, but a new track is opening up in two weeks and I am trying to get my car whipped back into shape. Thanks Beau
THE GOOCH is offline   Reply With Quote
Old 05-02-2005, 07:37 PM   #13109
Still Bill's Avatar
Gooch,
You may want to start with a diff on carpet and graduate to a spool first; however, a one-way will likely be the ultimate setup. Takes a good bit of track time to get used to a one-way. A spool progresses you as a halfway measure.
The black belt kit (belt and longer arm) is the only way to go. It frees up the drivetrain significantly and is a major performance boost for the XXX-S over any previous belt system.
The part numbers are on the www.teamlosi.com website.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 05-02-2005, 10:49 PM   #13110
Got the black belt kit and instaled it, makes a big diferance, very noticable. I did find,while i had the diffs out, that the bearings on the diff arnt all that free . So id sergest replacing them or maybe losening them up, but the bearings ive put in other cars are heaps better than these. so i might just change them all for better ones.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
