Old 04-12-2005, 10:29 PM   #13081
Still Bill's Avatar
PookyT,
Where do I find EA Motorsports on the www?
Thanks.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 04-12-2005, 11:21 PM   #13082
jay5668's Avatar
Send a message via Yahoo to jay5668
Here you go Bill.....great guy & awesome motors...you will absolutely love them...I race with Pookyt & he really knows his stuff too...he is the one that taught me everything!
http://www.teameamotorsports.com/ea_home.html
jay5668 is offline   Reply With Quote
Old 04-12-2005, 11:32 PM   #13083
POOKYT's Avatar
Thank You Jay!! EA just changed his website addy also so some of the older links do not work. When I'm in a hurry lately I have gone to the EA thread and clicked on his signature line. Guess I could save it in my fav's huh? LOL
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-12-2005, 11:33 PM   #13084
Still Bill's Avatar
Thanks Jay.
Old 04-13-2005, 06:36 AM   #13085
jay5668's Avatar
No problem guys...that's what I ended up doing...was trying to post it for Bill & none of the links I had worked....I finally found it in his sig in the EA thread! I do have it in my favs now!
Old 04-13-2005, 06:47 AM   #13086
Trader Rating: 244 (99%+)
Post Rubber Tire Setup
Any one have a rubber tire, CS27's, setup for a tight track with a Diff?
***Team driver for Team Associated, Reedy, A-Main Hobbies, ProTek RC, AKA and Integy***
Fred Perkins is offline   Reply With Quote
Old 04-13-2005, 02:19 PM   #13087
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Here Ya Go!
Front Suspension
Toe: 0
Ride Height: 5.5mm
Camber: -1.5mm
Shock Oil: 40 wt
Shock Piston: 56
Shock Spring: blue
Droop: 3mm
Pivot Support: 2F
Arm Spacing: forward
Camber Ballstud: black
Shock Mount: 4
Camber Mount: 3
Caster: 4
Carrier: 4 deg.
Ackerman: back
Front Drive: diff (tighter than rear diff)
Pulleys: 42 F 41 R
Roll Center: low
Rear Suspension
Toe: ?
Ride Height: 5mm
Camber: -1.5mm
Hub Carrier: 0 deg
Shock Oil: 40 wt
Shock Piston: 56
Shock Spring: blue
Droop: 4mm
Pivot Support: 2R
Arm Spacing: middle
Shock Mount: 3
Camber Mount: 2A
Arm Shock Mount: outside
Arm Hub Mount: standard
Roll Center: low
Spur gear: Neon Yellow 88 tooth 48 pitch
Pinion: 22 tooth 48 pitch
Body: TL Alfa
Motor: EA Motorsports Binary 2
Tires: Take-Off CS-27
Battery Position: forward
Belt: yellow with every other tooth snipped
Note: belt run very very loose, Trinity MF Al. Hexes, long steering turnbuckle
tc3stocker is offline   Reply With Quote
Old 04-16-2005, 10:23 PM   #13088
RCknight's Avatar
Default Looking for the cheapest place to....
buy a new molded carbon kit and Ti screw kit?
Also anyone have a great rubber tire setup for cement street?
Anyone have the Speed Tech SSG CF shock towers? If so, what did you think of them? Do they flex?
RCknight is offline   Reply With Quote
Old 04-17-2005, 01:57 PM   #13089
tc3stocker's Avatar
Default Re: Looking for the cheapest place to....
You can get the molded carbon kit from Horizon, the Ti screw kit from Titanium Racing (Schumacher).
Look a couple of pages back and you can find the setup I posted.
As to the shock towers. they are great, you can get the combo kit and use the black ones for asphalt and cement, and then use the SSG ones for carpet, but they all work good for both.
If you can't get the screw kit you can try Lunsford. But if you aren't set on titanium, I would go with a kit of stainless steel screws from RC Screwz, that is what I use and they are great.
Old 04-17-2005, 08:14 PM   #13090
imjonah's Avatar
Default setting gear mesh 64 pitch 128spur
I am having a real problem lately setting the gear mesh accurately since I switched to 128tooth spur 64 pitch pinions It seems like I am geting the squealing sound even when I think I am not setting it too tight. I am also starting to put lots of wear on the spur. I have been using a pinion that has a slighly beveled edge on it.
It seems like the pinion and spur might be meeting at a slight angle. (The wear is much greater on one edge than another) Since there is no obvious way to adjust that angle
(the plane the rotate in) In other words the shaft of the motor is not perfectly parralel to the shaft of the spur.
Has anyone else come across this problem.
I tried the paper trick to set the mesh and it still squeels.
With the 48 pitch gears you could kind of eyeball it. You could rock the one gear back and forth and see if there was just a tin bit of play.
also I am using a spool for the first time. In the first heat today the pinion gear actually came off the shaft even though I am certain I had tightened it(it has two set screws and both were tight) is this just evidence for the extra strain the spool puts on the drive train?
Thanks in advance.
imjonah is offline   Reply With Quote
Old 04-17-2005, 11:43 PM   #13091
Still Bill's Avatar
imjonah,
The white plastic idler pulley wheel for the belt has a slightly larger flange on one side than the other. Which direction is the larger flange facing? Towards the spur gear or away?
I still use the "rock the spur gear" method with 64 pitch.
Gotta think that you didn't have either of the two set screws fully tightened to the flat surface on the motor's shaft.
Old 04-18-2005, 07:06 AM   #13092
imjonah's Avatar
The idler is black and the larger flange is next to the tensioner arm it self. The set screws are on opposite sides of the pinion so only one is on the flat part of shaft, I am not sure I even should be using the second set screw, possibly. It might be there to use just in case you strip the first set screw.
It is a bit discouraging to find so many pieces of technical knowledge required to race a touring car competitvly.
I bet I could together a 10 pages of notes from this forum concearning things not include in the instruction manuals.(and that is not including small details from the manual which are important but not emphasized or detailed in the manual as possible mistakes or causes of trouble)
Old 04-18-2005, 08:07 AM   #13093
Still Bill's Avatar
im,
I have seen so many idler wheels on backwards that I took a shot at that. Good you have the black belt setup.
My first graphite chassis had the holes for the spur slightly out of alignment. Spur gear sat at an angle to the belt.
What!?! It's not fun reading 437 pages of this thread? You are lucky that Randy Caster doesn't post so much these days...Then it would be a thousand pages...
Old 04-18-2005, 05:51 PM   #13094
imjonah's Avatar
Default This Thread
The information contained in this thread is an incredible resource, it is almost an "Encyclopedia of the XXX-S" .
On occasion I will just go back and read 3 -4 months of posts, I always almost learn something new.
I think if it had not been for this thread and the people who answer questions on it, I would have given up in frustration last year. I just do not know where else you could get more accurate information; certainly not from Losi Web site certainly not from typical LHS.
Thanks for quick answers and all the in depth knowledgeable help,
Please continue to drop by this thread after all your JRXSs arrive .
Old 04-18-2005, 06:19 PM   #13095
Still Bill's Avatar
Well put imjonah.
I will be keeping one of my XXX-S cars for future use; so, I expect to be on both threads.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
