Old 04-10-2005, 01:43 PM   #13066
POOKYT's Avatar
Always keep one thing in mind when dealing with a stock motor! They will NOT last forever and getting a lil hot is ok. Usually mine come off the track closer to 200 deg. 4wd touring cars are hard on stock motors so don't get to attached to them and plan on one day it taking a clomplete crap! Too, remember that over gearing a motor as well as under gearing a motor will make it get hot Good Luck!
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-10-2005, 07:02 PM   #13067
mudpuppy's Avatar
That may shy me away from running stock. What about 19 turn motors?
mudpuppy is offline   Reply With Quote
Old 04-10-2005, 07:58 PM   #13068
POOKYT's Avatar
LOL Well.........ask around and get others opinions but.....I have always run my 19 turn at either 1 tooth higher or at the same ratio as my stock on the same size tracks. Weird huh? But, that what the 19's seem to like for me. Good Luck
Brant
P.S. pop into the EA Motorsports thread and ask those guys their opinions on ratio's. They may be a better source than me.
Old 04-10-2005, 08:25 PM   #13069
mudpuppy's Avatar
Pookyt - Thanks for something to start experimenting with and I will ask around some more.
Also.... I've seen pics of the new JRXS with what looks like multiple schotky diodes mounted to the motor. Does any know if they are there to help keep the motor cool?
Another question... what does a lager spur gear give you compared to a smaller spur gear?
Old 04-10-2005, 09:55 PM   #13070
POOKYT's Avatar
I don't know about the diodes. But, as for the spur it, the larger spur actually creates less friction as opposed to a smaller one. And mentally for me I say it has more leverage than a smaller spur. I know..I know...gear ratio is gear ratio.....blah blah blah. But, I like the bigger spur and thats that! LOL
Brant
Old 04-11-2005, 12:40 AM   #13071
enggboy's Avatar
Thanks for the reply Pookyt, I'll give it a try. I am running 64p gears btw.
I've ran Monster HP motors before but I'm concerned about how hot they get. Do you think they are OK to come off the track at 160 -170 degrees?
I have been running a P2K Pro for about 3 months now, I comes off the track at about 160 F with my regular packs and about 190 F with my really good pack. I have not found this to be too hard on it. I just lightly touch the comm after every heat with a comm stick, and then cut it every month or so.
Most of the people I race with say that 160 F is the temp that gives you the best power vs. abuse. Hope that give a bit of insight.
Enggboy
enggboy is offline   Reply With Quote
Old 04-11-2005, 06:49 AM   #13072
mudpuppy's Avatar
I have ran P2K2s in the past but found them to be slow. Maybe I havn't figured out a good spring/brush combination yet.
Can you guys tell me how to get more on-power steering? My car seems to push badly when I am coming out of the corners and get back on the throttle.
Old 04-11-2005, 02:46 PM   #13073
dstyles's Avatar
had a chance to run the skoda2 body on my g+ this weekend on an outdoor asphalt/parking lot track and i must say it performed well
i had been previously running the yokomo stratus type-e and thought that it provided me with the most steering for my driving style. well, the skoda2 had more steering entering and exiting the turns. any others have a chance to use it yet?
dstyles is offline   Reply With Quote
Old 04-11-2005, 10:43 PM   #13074
enggboy's Avatar
The P2K Pro I am running was 'tweaked' by one of the local motor magicians. He aligned the brush hoods and located the arm in the magnetic field. I am not sure about the springs, but I am running Fantom 309 brushes.
With my car geared to a rollout of almost 29 mm (1.14 inches) I am just as fast as a properly geared XRay running a Fantom Monster Stock.
As for your power-on corner exit understeering, I found that a slightly stiffer rear spring with a tighter front diff (or in the extreme a one-way) helped me get more steering in general.
That is my 2 cents.
Enggboy
Old 04-12-2005, 11:14 AM   #13075
polesitter61's Avatar
What do I need to make my diff a spool? Just the spool pads? I glued the diff together this week and it worked but I broke a molded outdrive pretty quick. What is the part # for a steel outdrive or something stonger than the molded plastic ones? Your quick response is appreciated, I need to fix it for my nephew for Fri. night.
Slickzero R/C products, check them out, very cheap shipping!!!
www.slickzero.com
polesitter61 is offline   Reply With Quote
Old 04-12-2005, 11:24 AM   #13076
NVisible's Avatar
anyone have a good setup for a small, tight carpet track w/foams?
NVisible is offline   Reply With Quote
Old 04-12-2005, 11:27 AM   #13077
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
For both you guys:
Contact CHADK on here he is very knowledgeable on both your questions.
dgullickson is offline   Reply With Quote
Old 04-12-2005, 11:51 AM   #13078
POOKYT's Avatar
Polesitter--You need 2 of a LOSA3073 steel outdrive and 1 of a LOSA3072 diff. tube. Then use all your regular diff parts from the XXXS. Also, I personally use 60 or 80 grit sandpaper to make my own pads. The stock ones are almost too smooth to grip good. Be sure that when you reassemble the spool to put the outdrive grooves at 90 deg. to each other. Do not line them up straight across to each other. I dunno why but this just makes it work better. Then I run a bead of CA around the outdrive/ring/pulley area to hold R together. Tighten the thrust assy very good but do not stip out the diff nut. Lastly, after 3 sets of aluminum CVD's last year, I gave in and ran the steel ones from the XXXS in the front for durability. If you need a pic to help reassemble the spool, use the break down for the XXX4's rear diff assembly.
Good Luck
Brant
Old 04-12-2005, 01:12 PM   #13079
Thumbs up
Thanks Pookty, that's what I needed.
www.slickzero.com
Old 04-12-2005, 01:46 PM   #13080
POOKYT's Avatar
No Problem!! Tell your nephew to kick some booty Fri. night!
Brant
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
