Old 03-30-2005, 06:13 PM   #13036
POOKYT's Avatar
Wheel nuts= 11/32's
Inserts--If your track is smooth and slick I would start with the med. and then try a soft. A hard insert should help if the track is high bite. Also, here where I race most of us run the TakeOff CS 27's which also has a med. insert. Plus they are cheap. Good Luck
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 04-02-2005, 08:04 AM   #13037
primusblowsgoat's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to primusblowsgoat Send a message via Yahoo to primusblowsgoat
Question
im running the 48pitch yellow spur, with a monster stock geared at something like 19 or 20.
no matter how tall or how low i gear the thing the motor comes off smoking hot, ive taken the diffs out and checked that the belt tensioner isnt too tight, and with no pinion on the motor the drivetrain spins fairly free.
is my gearing way off?
or is something else wrong here?
Schumacher Racing
Schumacher Cat SX2
Schumacher Cougar SV
primusblowsgoat is offline   Reply With Quote
Old 04-02-2005, 08:08 AM   #13038
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Are you running the RTR or the G+?
tc3stocker is offline   Reply With Quote
Old 04-02-2005, 12:58 PM   #13039
RCknight's Avatar
Default Anyone know if the new....
JRXS shocks are going to fit the XXX-S with no mods?
RCknight is offline   Reply With Quote
Old 04-02-2005, 01:47 PM   #13040
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
primusblowsgoat: Check to see if all your solder joints are good. If not then the wires are shorting and it has to work harder to produce the power its suposed to. This happened to me. I had a bad solder joint on my esc and i fixed it and my motor never ran hot ever again. You might also want to check for any binding in bearing or anywhere. You might also want to check if theres something wrong with the ESC it self. You might of shorted it out and increased the internal resistance. Hope this helps you.
RCknight: I dont think the JRXS shocks will fit the XXX-S. Im not 100% sure. Ask on the JRXS thread just to make sure.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 04-02-2005, 05:04 PM   #13041
tc3stocker's Avatar
JRXS shocks will fit because they are only smaller. You have to use the top shock mounts from the JRXS though, and maybe shock towers like the PRP Megatune so you can raise/lower the shocks on the shock tower.
And I already got with primusblowgoat and discussed it with him, he was running the blue belt and it was too tight and also he has to degrease his bearing, it is a common problem with the car, when you don't know it too well.
Old 04-06-2005, 08:58 AM   #13042
Send a message via ICQ to piorc
Default front and rar susp arms
Hi, i was looking to buy new arms, and i have 2 questios.
1) Whats the diference betwen rear arms 9860 and 2221??
2) Whats the diference betwen front susp arms 9737 and 1214???
Thanks.
Marcelo.
piorc is offline   Reply With Quote
Old 04-06-2005, 09:08 AM   #13043
dstyles's Avatar
the 9's are the graphite versions, the others are plastic
the rear '9' arms have the offset mounting holes for the o/s hubs
dstyles is offline   Reply With Quote
Old 04-06-2005, 02:03 PM   #13044
losi_g+'s Avatar
[QUOTE]Originally posted by POOKYT
[B]
Originally posted by losi-sw
does any one kno whether i can use the xxx-s cvd' on a street weapon, so that i can use other manufacturer wheels??
No the XXXS are longer. If you only want to run the regular hex drive wheels then I would get the conversion kit made be RPM for the Street Weapon. It comes with the larger size hex's and the proper offset to run the more common wheels out today.
Brant
If you look at RPM site then youll see that the car will then be 200mm and as such, is not eligable to race! Just in case you are wanting to race it!
losi_g+ is offline   Reply With Quote
Old 04-07-2005, 06:27 AM   #13045
Post Tweaking
Help with tweaking,
After setting Tweak my ride height changes.
Is this right?
Cup of Losi is offline   Reply With Quote
Old 04-07-2005, 06:58 AM   #13046
losi_g+'s Avatar
Default Re: Tweaking
Originally posted by Cup of Losi
Help with tweaking,
Is this right?
Did you set the tweak by adjusting the spring collars as per the tuning tips on the losi site?
Old 04-07-2005, 07:27 AM   #13047
Still Bill's Avatar
Cup,
After setting tweak, I sometimes have to readjust f/r ride heights by raising or lowering the shock collars by equal amounts at both ends of the car. It's best to check tweak again after doing so.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 04-07-2005, 08:22 AM   #13048
Post tweak
Losi_g+: Yes, I,m adjusting using the threaded collers.
JRX-S Bill: I tried doing that but after readjusting the ride height the car needs to be tweak again.
I have a sway bar installed on the front should I remove it when setting tweak.
Thank for you help
Cup of Losi
Old 04-07-2005, 01:13 PM   #13049
losi_g+'s Avatar
How much is the ride height differing by when youve set the tweak?
If you remove the sway bar it will give you accurate tweak on both sides but when you refit it to race, the sway bar may affect the tweak on one side more than the other. I always leave mine on!
Old 04-07-2005, 09:12 PM   #13050
Still Bill's Avatar
Default Re: tweak
Thank for you help
Cup of Losi
Do you know what the swaybar is actually doing FOR you? If not, remove it altogether because you can reinstall it when you are looking for a different handling feature.
An alternative is to lay the swaybar on a flat surface (glass?) to determine if it is bent. You don't want a bent bar.
I get more handling attributes out of springs, shock oil, droop, shock angles, caster, camber, etc. than from a swaybar.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
