Old 11-30-2001, 03:18 AM   #1291
Regional Moderator
Addict sa RC's Avatar
rccarracer, thanks! Everything's clear now.
Increase droop = increase numerically on the droop gauge
Decrease droop = decrease numerically on the droop gauge
Addict sa RC is offline   Reply With Quote
Old 11-30-2001, 03:21 AM   #1292
R/C Tech Founder
R/C Tech Charter Subscriber
I think we should make the Todd Hodge XXX-S Tuning article required reading for all R/C racers period.
An excerpt:
"On low-bite tracks, add more droop to get the car to roll more through turns. This will let the car transfer more weight and will increase traction. Putting more droop into the car makes it a little more mellow and easier to drive. Just for clarification; increasing droop means adding more down travel. On high-bite tracks, take away droop to make the car roll less, thus making the car easier to drive."
(This is basically the same thing that Rog posted, just a little less detailed...)
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 11-30-2001, 03:35 AM   #1293
rccarracer's Avatar
Glad I could help, Happy racing!!
rccarracer is offline   Reply With Quote
Old 11-30-2001, 05:44 AM   #1294
Regional Moderator
Question: Doesn't adding more down travel mean making the shock shaft longer as measured from the bottom of the shock body/cover to the spring cup? If that's true (please correct me if I'm wrong), then increasing droop would mean going numerically lower on the droop gauge,....right?
Old 11-30-2001, 07:12 AM   #1295
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Then why on a carpet track do you want to run a rear droop of about 2? That then means that your car car chassis will be at a higher spot then a droop setting of 5 (chassis is lower to the ground then the 2). I thought that for Carpet you want the chassis to be close to the ground? I am wrong in thinking this?
Mike Webb
mike_Webb is offline   Reply With Quote
Old 11-30-2001, 07:20 AM   #1296
Rog
Ok, here is a link to the X-Ray setup book. They (Hudy) use a better terminology..."downstop."
http://www.teamxray.com/teamxray/pro...&kategoria=253
Addict sa RC - Adding more downtravel doesn't necessarily mean making the shock shaft longer. A better description would be to say that it increases the distance between the bottom of the shock body and the spring cup. The way I understand it, more downtravel has a lower number. I have Hudy setup tools so my droop gauge has negative numbers (hub carrier sits below the chassis line). When people tell me to "increase droop" I understand that to mean increase the droop value (ie from 4mm to 5mm) or giving the car less downtravel. That's why to me, "droop" is an oxymoron. It doesn't really matter what the definition is just as long as you understand the theory behind it and how it affects your car. The Hudy setup book is actually pretty good. Read through it and it will help you understand setting up your car a bit more.
Rog is offline   Reply With Quote
Old 11-30-2001, 07:30 AM   #1297
Rog
Mike, don't mistake ride height with droop. I can have anywhere between 1mm and 5mm of droop and have my chassis still sit 5mm off the ground at rest. Ride height is adjusted with spring collars. Anyone who uses droop screws to set their ride height is limiting the effectiveness of their suspension...most usually in a bad way.
Old 11-30-2001, 08:53 AM   #1298
Regional Moderator
Default Finally got it at last!!!
Rog, you're right. Downstop is a better term.
Old 11-30-2001, 04:36 PM   #1299
Send a message via AIM to ZER01
An excerpt:
Originally posted by proudwinner
More droop means more shock travel and visa-versa for less. If your at 5 and need less(less shock travel) go to 6. I run 3 in the front 5 in the rear(parking lot).
*TIP* dial in more droop for less bite surfaces(unprepared parking lot) and visa-versa for higher bite surfaces(permanent tracks that have high bite and carpet).
These two sound the same to me.
ZER01 is offline   Reply With Quote
Old 11-30-2001, 05:01 PM   #1300
Meaning go to 6 using your losi droop gauge.
I know it sounds backwards when decreasing droop means going up to a higher number on the gauge, but thats the way it is when measuring droop with a losi and even an associated droop gauge.
Old 11-30-2001, 05:48 PM   #1301
click below- 3 setups from the tc3 manual.
1)Bumpy track
2)Carpet with foams
3)Worlds 2000
The bumpy track setup sheet states to use 5 in the front 3 in the rear for droop.
The carpet track setup states to use 6 in the front 4 in the rear for droop.
The worlds setup states to use 5.5 in the front and 4 in the rear for droop.
In other words, use more droop(lower number on gauge)for less bite conditions and less droop(higher number on gauge)for more bite conditions.
TC3 manual-Look at shocktravel on page 26 in the manual.
Old 12-01-2001, 07:51 AM   #1302
Send a message via AIM to WHITESTER
Proudwinner! That eye really creeps me out!
WHITESTER is offline   Reply With Quote
Old 12-01-2001, 09:59 AM   #1303
Yeah, I'm trying to keep the darn thing still but it just keeps floppin around. I've made an appointment with an eye doctor next Monday to have it looked at.
Old 12-01-2001, 06:20 PM   #1304
R/C Tech Founder
Well, I just got done installing the Speed Tech parts on my car. I must say, the fit & finish of the parts are great and everything went on nicely. But man, Losi sure made it difficult to modify the roll center of the car with those blocks. Had to shave or cut the stock car in no less than 8 places, plus trim the droop screws down to size.
What's funny to me is, Losi included the lower mounting holes for the front and rear pivot blocks on the bulkhead caps, as if they were thinking ahead to this particular modification. But if they were, I am wondering why they didn't test this before the car shipped to eliminate the need for cutting the chassis itself, not to mention the front and rear bumpers. Hmmm...
The only problem I had with the low blocks is that it seems the most rear droop I can have is 4. Had my rear set to 3 before but I couldn't get the arms to pivot that low. Not a major problem, but anybody else see that? I figure a lot of you on here have made this modification already.
Stay tuned for an R/C Tech Review of the Speed Tech parts soon.
Old 12-02-2001, 02:38 PM   #1305
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Mike Webb
Mike, you are confusing ride height and droop. Ride height is how high the car sits when static, and droop is the distance the suspension is allowed to move down as it is unloaded. Changing ride height will affect the droop setting, however, changing the droop setting SHOULDN'T affect the ride height. I say shouldn't because if you set is so screwed up that it does, then you have a serious problem.
BigDogRacing is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
