Old 03-24-2005, 03:42 PM   #13006
Trader Rating: 40 (100%+)
Send a message via AIM to brians11
I also run the losi bumper brace, sorry i dont know the p/n off hand... but that has helped... just be sure to grind the bumper out to get it sitting flat with the tranny case bracket and it'll last a long long while...
Team Tekin | Superiorhobbies.com
brians11 is offline   Reply With Quote
Old 03-24-2005, 03:47 PM   #13007
RKeasler's Avatar
Location: A step closer to where I need to be a step further from where I was
Default Re: Re: Weight
Originally posted by tc3stocker
IT doesn't matter. Just buy the Graphite one because it is lighter and more rigid and better all around.
Yeah it does matter and btw I have 2 graphite chassis I have a reason for knowing the answer if you don't know thats cool.
ClemsonTigers
USVTA # 224
ERC
RKeasler is offline   Reply With Quote
Old 03-24-2005, 04:03 PM   #13008
POOKYT's Avatar
If you run the BRP lower bumper and the upper Losi lexan brace it will cut your broken parts down to a minimum. I promise!! I learned the hard way myself. One additional thing I did was to trace the outline of the lexan brace on some aluminum and made braces out of it as well. The lexan will eventually break but the aluminum never did. Plus I got to polish it and made it look very nice. But first the BRP lower brace will help the most.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 03-24-2005, 05:16 PM   #13009
Default breakage
I race with some tc4 and xrays and they break as much as or
more than my sss g+.I a running the stock g+ bumpers and
they give more than enough protection.
my $.02
thanks.
SrRC is offline   Reply With Quote
Old 03-24-2005, 10:01 PM   #13010
Still Bill's Avatar
Default Re: SICK OF IT
Originally posted by NinjaViper
Unless you guys can offer me something I can do differently I am afraid that I am going to switch to either a TC4 or T1FK05.
BRP makes an add-on bumper for the TC4 too...he, he...
Really, the BRP add-on bumper by virtue of its added width adds tons of protection to the front end of the XXX-S.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-25-2005, 04:12 PM   #13011
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
Does anyone know where I can get an editable set-up sheet? If so please post or send me a pm, thanks in advance.
tc3stocker is offline   Reply With Quote
Old 03-25-2005, 04:42 PM   #13012
tc3stocker's Avatar
Front Suspension
Toe: 0
Ride Height: 5.5mm
Camber: -1mm
Shock Oil: 40 wt
Shock Piston: 56
Shock Spring: green
Droop: no screw
Pivot Support: 2F
Arm Spacing: middle
Camber Ballstud: black
Shock Mount: 3
Camber Mount: 3
Caster: 2
Carrier: 2 deg.
Ackerman: back
Front Drive: spool (aluminum)
Pulleys: 42 F 42 R
Roll Center: low
Rear Suspension
Toe: ?
Ride Height: 5.5mm
Camber: -1mm
Swaybar: thinnest (only when traction comes up, my rear tends to lift and this flattens it)
Hub Carrier: 0 deg
Shock Oil: 40 wt
Shock Piston: 56
Shock Spring: blue
Droop: no screws
Pivot Support: 2R
Arm Spacing: middle
Shock Mount: 2
Camber Mount: 2A
Arm Shock Mount: outside
Arm Hub Mount: standard
Roll Center: low
Spur gear: Kevlar 128 tooth 64 pitch
Pinion: 32 tooth 64 pitch
Body: TL Lexus IS300
Motor: EA Motorsports Binary 2
Tires: Take-Off CS-27
Battery Position: forward
Belt: yellow with every other tooth snipped
Note: belt run very very loose, AE Hexes, long steering turnbuckle
Also, you may want to try AE shocks if you have them, I am going to try them with Tamiya Blue springs on the front and Tamiya Yellow springs on the rear. With 40 wt oil on all four corners.
Be sure to degrease all bearings before use. And it will help your setup if you dial in some droop. But I run on uneven asphalt so I donít.
Old 03-25-2005, 10:14 PM   #13013
imjonah's Avatar
Okay guys, thats it. I have had enough. I am throwing in the towel. I am tired of trying to keep my XXX-S G+ in one piece. I have broken more front carriers than I care to share as well as arms. I am lucky if I can even finish a race withouy breaking.
I will admit, I am not the greatest driver but I am not that bad. I see other guys taking worse hits than me and not breaking.
I felt the way you do last July. I did three things that helped significantly. I bought a brace like they are talking about that sits on top of the bumper and connects the two posts with the front diff cover, I also got that BRP wider lower bumper.
In addtion, I adjusted my transmitter to apply brakes when the trigger was at neutral(drag brake). This helped me take sharp corners without losing control because it automatically slowed the car significantly when I released the throttle cause I was approaching corner a little to fast.
You may be a better driver than me and this drag brake may be kind of a crutch or a hinderance . It helped me cause it forced me to slow down.
imjonah is offline   Reply With Quote
Old 03-26-2005, 03:54 PM   #13014
Registered User
losirunner's Avatar
Send a message via AIM to losirunner Send a message via MSN to losirunner Send a message via Yahoo to losirunner
i happen to have nvere broken anything on my xxxs. But i also have the BRp bumper and the lexan thing. Looks good too
losirunner is offline   Reply With Quote
Old 03-27-2005, 11:07 AM   #13015
here's an adobe version from losi http://www.teamlosi.com/pictures/jpe...xxsg_blank.jpg
Poppa Ray is offline   Reply With Quote
Old 03-28-2005, 07:45 AM   #13016
dstyles's Avatar
does anyone know who still carries the steel outdrives?
dstyles is offline   Reply With Quote
Old 03-28-2005, 02:42 PM   #13017
tc3stocker's Avatar
Thanks but I am looking for one that is editable online.
Old 03-28-2005, 02:44 PM   #13018
tc3stocker's Avatar
Steel outdrives can be found through Horizon Hobbies.
www.horizonhobby.com
You can use the new ones if you like just be sure to CA the spool when it is built together. I have an extra one that I might be able to sell you if you want it.
Old 03-28-2005, 04:17 PM   #13019
dstyles's Avatar
i tried looking there earlier but couldn't find it. is it a xxx-s specific outdrive or non-specific steel outdrive for losi vehicles.
yeah, i'm building a spool
i came across the one from irrgang, but they're hard-coated aluminum.
Old 03-28-2005, 04:56 PM   #13020
SCML's Avatar
XXX-S, XXX-T, and XXX BK use the same outdrives. Gen II cars (MF2, BK2) use the newer outdrives.
I belive the part number is LOSA3073 for the steel outdrives.
I'd go with the IRS Racing outdrives, but they are a bit spendy.
Mike
SCML is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
