Old 03-01-2005, 07:37 AM   #12931
Post set up/shocks
bill,
Question about setup,
I run carpet and aphalt. I think the carpet track at Gilroy ca. is mid size. I'm using a monster stock pro.
I have 128 t 64p spur and using 30t pinion.
On your xxx-s are you use low center blocks in front and back?
Are you using sway bars front and back, what size
What is you final drive ratio?
and finally, when refilling the shocks with oil can't seem to get them set right. I either have too much oil or not enough
Is there some trick or just practice.
any advice will be very helpfull
Rob
Hobby World Gilroy, ca. Carpet track
Cup of Losi is offline   Reply With Quote
Old 03-01-2005, 12:04 PM   #12932
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by JRX-S Bill
All show...No go...
Like altezza lights on a civic... only those are ugly
Old 03-01-2005, 01:23 PM   #12933
EricF's Avatar
Randy,
Are you running on asphalt? If so, care to share your setup. I've been thinking about getting the xxxs off the shelf and put the TC4 in its place.
Thanks,
E
EricF is offline   Reply With Quote
Old 03-01-2005, 01:51 PM   #12934
Originally posted by EricF
Randy,
Thanks,
E
Im on really high grip asphault with oval banking on the outside lanes, pretty much a one of a kind track, and running modified, if the setup will help ya, I can share it.
Old 03-01-2005, 03:05 PM   #12935
EricF's Avatar
I've been to socal before. The track I race at only has about half the traction of socal but, it may still prove helpfull for SRS (Phx. AZ.) for when I make it up there to race.
Thanks.
Old 03-01-2005, 08:28 PM   #12936
primusblowsgoat's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to primusblowsgoat Send a message via Yahoo to primusblowsgoat
so i finally got some time, and i tore apart the rear diff, most of the holes in the pulley were now two balls wide, melted to crap.
the thrust bearing seemed ok, but when i would loosen it and turn the wheel to check how tight, it would just spin, the other wheel wouldnt move, and the only way i could get the other to move(this is before it was trashed) was to tighten it all the way, anyone have any idea what caused this?
the thrust bearing seemed to be intact but all the beval washers were facing the same way, arnt 3 supposed to go one way and 3 the other?
Schumacher Racing
Schumacher Cat SX2
Schumacher Cougar SV
primusblowsgoat is offline   Reply With Quote
Old 03-01-2005, 09:51 PM   #12937
Still Bill's Avatar
Default Re: set up/shocks/ETC.
ROB,
PLEASE SEE THE BELOW COMMENTS (IN CAPS)...Bill
Originally posted by Cup of Losi
bill,
- ME TOO ABOUT CARPET AND ASPHALT. GILROY HAS THE LONG BACK STRAIGHT BUT SOME OF THE AREAS ON THE TRACK ARE QUITE SLOW; THEREFORE, I AGREE WITH "MID-SIZED". ME TOO ABOUT THE MONSTER PRO.
- I AM USUALLY IN THE 31-33T PINIONS WITH THE 128T 64P SPUR. IT TAKES TIME TO WORK UP TO THE HIGHER PINIONS BECAUSE I GRADUALLY LEARNED TO CARRY MORE SPEED THROUGH THE CORNERS.
- YES. I HAVE THE MF ALUMINUM BLOCKS WITH A THIN ADDED SPACER ON THE FRONT BLOCKS TO GET THEM BACK TO WHAT LOSI CALLS LOW. ALSO USE THE "2F" FRONT PIVOT SUPPORT (STRAIGHT) AND THE "0R" REAR PIVOT SUPPORT. THE ARMS ARE MOUNTED IN THE FORWARD POSITIONS ON MY CARPET CAR. NOT SO ON MY ASPHALT CAR.
- NO SWAY BARS. THEY SEEM TO TWEAK THE SUSPENSION SETTINGS.
- HERE ARE SOME STARTING POINTS
31T IS 7.56 (FOR A TIGHT CARPET TRACK)
32T IS 7.32 (TYPICAL CARPET)
33T IS 7.10 (TYPICAL ASPHALT)
34T IS 6.89 (FOR A LONG FLOWING TRACK WITH NO SLOW TURNS)
and finally, when refilling the shocks with oil can't seem to get them set right. I either have too much oil or not enough. Is there some trick or just practice.
- I JUST FOLLOW THE INSTRUCTIONS IN THE XXX-S OWNER'S MANUAL. PUSH SLOWLY ON THE SHAFTS TO LET THE AIR OUT. I HAVE SPACERS INSIDE THE SHOCKS TO ELIMINATE THE NEED FOR DROOP SCREWS.
- STARTED WITH DIFFS, PROGRESSED TO THE SPOOL AFTER SEVERAL MONTHS AND THEN TO THE ONE-WAY FOR CARPET RACING. TAKES SOME TIME TO "GRADUATE" TO USING THE SPOOL AND ONE-WAY IN MY MIND.
HAVE FUN PLAYING WITH THESE. SEE YOU AT THE TRACK.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 03-01-2005, 10:00 PM   #12938
Still Bill's Avatar
That's what happened to me when I accidentally put one of the overdrive/underdrive 41T pulleys in my car?
Old 03-01-2005, 10:07 PM   #12939
well i looked at it, and tried to count teeth and came up with 42, but who knows if i was right.
i also couldnt find any markings on it to see if it was differnt than a regualr one
Schumacher Racing
Schumacher Cat SX2
Old 03-01-2005, 10:27 PM   #12940
Still Bill's Avatar
The 42T pulley has a raised ridge at the side of the flange. The 41T doesn't. Otherwise, if you place them side-by-side to each other, you will see that one is very slightly larger than the other.
Old 03-01-2005, 10:41 PM   #12941
a ridge around the outer ring?
on both sides?
if thats the case than it was a 42
Schumacher Racing
Schumacher Cat SX2
Old 03-02-2005, 12:08 AM   #12942
Still Bill's Avatar
on both sides?
What about the other one? I had the 41 in the front and the 42 in the rear when my failure occurred.
Old 03-02-2005, 01:37 AM   #12943
The 41 tooth should have 2 black marker marks on the side of the gear as well.
Old 03-02-2005, 07:41 AM   #12944
Still Bill's Avatar
Agreed, but I have a couple with one black mark and another one with none...Losi isn't perfect about that...he, he...
Old 03-02-2005, 11:10 AM   #12945
I think all the new ones have the marks on them.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
