Old 02-26-2005, 10:57 AM   #12886
NVisible's Avatar
all i used to do with my xxx-s graphite parts was take a ball stud and crank them into each hole, then assemble the car.
A ball stud is really hard to strip, plus you know its the right thread. As for fixing your problem... maybe switch to a slightly bigger thread? maybe something metric
NVisible is offline   Reply With Quote
Old 02-26-2005, 11:30 AM   #12887
Still Bill's Avatar
Thanks NVisible.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-26-2005, 11:43 AM   #12888
RandyB's Avatar
Originally posted by Thai3g_Eclipse
Sorry if this is a repetitive question, but is the black belt conversion worth it and is it effective?
one of the best upgrades for the car ever!!!
RandyB is offline   Reply With Quote
Old 02-26-2005, 11:45 AM   #12889
RandyB's Avatar
Originally posted by JRX-S Bill
I just purchased a replacement chassis for one of my XXX-S Graphite Plus cars and need to tap 4-40 threads into it for the diff cover screws.
Both of my chassis are pretty well stripped out in those holes on both ends.
I understand that all 4-40 taps are not alike. Some are tight and some not so. Not sure what I actually have; but, I would have to call the new tapped holes on the "loose" side. Have used both stainless steel and titanium screws which may lead to that loose feeling.
I also know about using CA in these holes to entend their useful life. Have been doing that since the problem developed.
Anyone got any suggestions on how to do this so the threads in the graphite chassis stay intact for as long as possible? Thanks.
Billget some 4-40 inserts like tubing but the inside is threaded drill the hole big enough and CA it in you'll have to prob' use machine screws to go into the inserts.
Old 02-26-2005, 12:13 PM   #12890
Still Bill's Avatar
RandyB,
Are you talking about doing this to the NEW chassis that I am preparing?
Otherwise, looks like a good solution to resurrect an OLD chassis.
Thanks.
Old 02-26-2005, 04:39 PM   #12891
RandyB's Avatar
either i guess if you have problems with thm stripping all the time just take care of it from theget go!
Old 02-26-2005, 04:43 PM   #12892
RandyB's Avatar
Originally posted by SPC Racer
how much do ceramic bearings help this car and how long will they last and how much will they take and any other secrets to free up the drivetrain and how to take the slop out of the steering.
ceramics make the drive train smoother but i would only use them for the internals. The bearings in the hubs are just to easy to damage! for me at least.
Ceramic bearings are not neccesary fora fre drive train though just anadded touch that helps.
where is the slop coming from?? bell cranks?? lots of points to look for
randy b
Old 02-26-2005, 05:27 PM   #12893
Still Bill's Avatar
Ceramics all the way...ceramic bearings at all points and ceramic balls for the diff/thrust areas.
Makes for free and smooth drivetrain.
Old 02-26-2005, 07:06 PM   #12894
KSI
KSI's Avatar
Send a message via AIM to KSI
Originally posted by NinjaViper
Here are the side foams mentioned. And now that I see what a Buds bumper is I realized that I got them on one of my XXX-S's I got off ebay and took them off, I will have to get them back on if they are that good.
how does that brushless run in there? Im looking into getting one of those this summer.
KSI is offline   Reply With Quote
Old 02-26-2005, 11:50 PM   #12895
Thai3g_Eclipse's Avatar
Thank you for the answer RandyB and RBLove.
HPI Savage Flux HP | Tamiya TB-03
Thai3g_Eclipse is offline   Reply With Quote
Old 02-27-2005, 12:00 AM   #12896
Randy Caster's Avatar
Trader Rating: 46 (100%+)
And lightweight drivetrain
I've been running the XXXS again for the past couple weeks, just waiting for the JRXS to arrive, I'm excited for it!
Old 02-27-2005, 06:41 AM   #12897
fire929's Avatar
Default shocks
Does anyone have a suggetsion for the leaking shocks-xxx-s- ie for a replacement by another company that will fit?
Trex 450
Trex 600
EFL Heli's
Futaba 8fg
Align 3gx
fire929 is offline   Reply With Quote
Old 02-27-2005, 08:13 AM   #12898
Still Bill's Avatar
Default Re: shocks
Just get new o-ring seals for now (#A-5015) and maybe new shafts (if not smooth). The new high tech JRX-S shocks will fit the XXX-S with modified shock towers.
Old 02-27-2005, 08:15 AM   #12899
Still Bill's Avatar
And Randy KNOWS how to lighten a XXX-S.
Old 02-27-2005, 10:18 AM   #12900
This may very well be the lightest yet
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
