Losi XXX-S
Hey people, one more thing.
I need your help.
I wnat some molded thrust bearings for my xxxs. Do you know where I can get some.
Stormer's are out of stock for the moment.
Antonis
I need your help.
Antonis
Antonis
Antonis
Another alternative to consider is to upgrade your diff and thrust balls to ceramics. Makes for an ultra smooth diff.
Best source I know of is Bill Riggins in USA at [email protected]. Last time the cost was $1 per ball. Bill also has an excellent thrust bearing grease he includes free with a full set of balls.
anyone know if the RTR II motor is rebuildable?
according to teamlosi.com: Yes.
would it be worth rebuilding it or just getting another motor?
i woud probably be best to just get another motor. Motors that come with kits usually arent that great in quality.
Well I just use talcum powder, I got some really nasty burns with the AE stuff.
P.S. No offense TSR
P.S. No offense TSR
Are you satisfied with the motor's speed? is it still in good shape?
If so, stick with it until you burn it up.
I know Troy, I just thought it was funny enough.
Cheers.
Cheers.
Originally posted by JRX-S Bill
Antonis,
Antonis,
I 've already send him an email.
Antonis
Antonis,
You will also find that Bill Riggin's ceramic balls are grade 3. Most others seem to sell grade 5 balls. The lower the number the better their tolerances.
So Bill,
The only thing that I will need to be changed, will be the washers. What's their size?
Anywhere where I can buy from?
So Bill,
So Bill,
I have never figured out the size of those washers. I use the standard washers from Losi Part No. A-3099 which is the "Full Compliment Thrust Bearing Set" and just toss the balls.
Someone else may have figured that out; but, you would also need to get them in the same grade of material.
I 'll send Bill Riggins an additional email. Prob he knows something.
what are the best ceramic bearings for this car?
Ceramic bearings and balls
Using ceramic balls in the diff/thrust area is another high end mod to consider. My diffs go forever.
FYI...I have a "diff" car and a "one-way" car. Otherwise, their setups are pretty similar. The "one-way" car currently gets the nod for most situations.
