Old 02-04-2005, 07:38 PM   #12781
macnkitty2002's Avatar
the design on the hood is a carbon graphite design. it is similar to an external decal except it goes on the inside of the body, and the glue is on the opposite side of the vinyl aswell.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 02-04-2005, 09:23 PM   #12782
NVisible's Avatar
Nay, that body is 100% painted. there is a method to get it uniform like that, i believe James mentioned one way, another is to use drywall tape. This painter is quite talented.
NVisible is offline   Reply With Quote
Old 02-05-2005, 06:45 PM   #12783
i'm sorry, but i cant believe that.
Losi Rock Rey
Old 02-05-2005, 06:57 PM   #12784
The trick is to use the foam no slide mesh that you use to line a shelf with but you have to find the square pattern type. Spray silver on very low pressure so it doesn't blow under then lift off the foam and spray black. You end up with the checkerbord pattern where the edges of the silver are blured and the corners don't touch!
Poppa Ray is offline   Reply With Quote
Old 02-05-2005, 07:03 PM   #12785
Wicked's Avatar
The carbon is painted, its not a decal.
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 02-06-2005, 09:17 PM   #12786
Redalert's Avatar
Originally posted by POOKYT
Redalert-- I used the spool pads in my spool this past year with these exceptions. First, I used the steel outdrives as I kept shattering the plastic ones. Second, I bought 60 grit sandpaper to make my next set of pads and after assembling the spool I used CA glue to glue the diff halves to the diff gear. MAKE SURE WHEN YOU BUILD THE SPOOL TO OFFSET THE OUTDRIVE SLOTS 90 DEG. I.E. When you look at the spool you can only see one set of outdrive slots at one time. I cannot tell you why this works just that every time I built a spool with the slots evenly spaced I ended up toasting the spool. Some of my Losi buddies in Tulsa turned me onto this trick and it worked.
This is just my opinion but I would suggest you get a milder mod or even a 19 turn motor to start with so you can get used to the car and tuning it plus driving it instead of spending your time repairing it. An 8 turn is heaps of power and very hard on the car. Good Luck!
Brant
Thanks a bunch! I am off to the races with my solid axle-
8 turn is really hard on the car. That why I bought 2 kits My experience shows that the XXX is a very hardy car. I haven't broke the car yet with the 8T except for shearing the rear diff. spool.
Redalert is offline   Reply With Quote
Old 02-06-2005, 09:17 PM   #12787
karter's Avatar
Send a message via AIM to karter
Anyone have a good set up for a xxxs G+? I race on ozite mod and stock foam.. track area is 40x80 or so.. Oils mounting postions degree of hubs etc etc etc would be awesome..!!!
Let me know ASAP as I need to change mine pretty soon
Josh
karter is offline   Reply With Quote
Old 02-07-2005, 03:16 PM   #12788
when i put the 1 deg. hubs on backwards why am i only getting 1 deg. toe in isnt it supposed to be 0 deg.?
SPC Racer is offline   Reply With Quote
Old 02-07-2005, 03:21 PM   #12789
There is two degrees per side factory so ones backward give you one degree per side. There is no way to get zero with factory parts.
JimMcClure is offline   Reply With Quote
Old 02-07-2005, 03:30 PM   #12790
the 1 deg hub per side gives you a 2 deg change when you run the 1 deg hub backwards i should give you 0 deg toe, right?
Old 02-07-2005, 07:49 PM   #12791
Still Bill's Avatar
SPC,
Jim said it right already.
By default, you start with two degrees of rear toe-in on each side of the XXX-S. When you use negative one degree hubs (placed backwards), you end up with one degree of toe-in on each side.
When we are talking toe-in, the norm is to refer to the amount of inward angle (toe-in) on each side as opposed to the cumulative for both sides.
Hope this helps.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 02-07-2005, 08:25 PM   #12792
karter's Avatar
Josh
Anyone have a good set up?
Old 02-07-2005, 08:31 PM   #12793
STLNLST's Avatar
Trader Rating: 19 (100%+)
Originally posted by JRX-S Bill
SPC,
Hope this helps.
When are you going to get the car that matches your name.....LOL It's okay to change it back for a while
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 02-07-2005, 08:41 PM   #12794
KSI
KSI's Avatar
Send a message via AIM to KSI
do TC3 wheels fit on the XXX-S? Anyone know cause I will probably trade for some.
KSI is offline   Reply With Quote
Old 02-07-2005, 08:46 PM   #12795
KSI
KSI's Avatar
its true, and its very easy to do. you just take of that dashboard padding, you know the stuff they sell at meijers so your crap doesnt slide around on top of your dashboard. just lay that over the aread you want to paint, paint over it with black, remove it, then paint with silver, voila! instant CF.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
