Old 01-18-2005, 08:28 PM   #12676
Send a message via ICQ to piorc
Thanks a lot for your quicky reply.
But i saw in matt francis xxx-s and he had red ball cups, somebody knows from what manufacturer are them made from??
and if possible with links!!
Thanks.
Marcelo.
piorc is offline   Reply With Quote
Old 01-18-2005, 08:47 PM   #12677
Still Bill's Avatar
Thanks.
Marcelo.
They are the RPM Heavy Duty - Red.
Matt's aluminum parts by Trinity are also red. He is in to red.
Same sites I gave you.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 01-18-2005, 08:53 PM   #12678
but i cant find the red ball cups.
if you find somewhere, please tell me...
Thanks.
Marcelo.
Old 01-18-2005, 09:30 PM   #12679
No, they are Red Losi Ball Cups. LOSA6014. HD30deg Plastic Rod Ends (RED)
James Nguyen is offline   Reply With Quote
Old 01-19-2005, 05:30 AM   #12680
POOKYT's Avatar
Thanks.
Marcelo.
PIORC--I personally take the plastic bag from a parts bag, and cut a 2 mm square from it. You then take the square and poke it in the ball cup and then snap onto the ball. I have used this for years in off-road and the past 2 years running my XXXS. This small piece of plastic inside the ball cup will tighten up the joint but not cause any bind. My $.02. Good Luck
P.S. I have seen other racers in my area using RPM ball cups and they always seem to rup the front wheels.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 01-20-2005, 11:39 AM   #12681
Hi Jrxs Bill, Indoors on wooden floors tend to be very slipppy and it is normally Schumacher Yellow mini pins ( 21mm narrow ones ) and the car set soft with some roll.
Hope this helps
Bryan D is offline   Reply With Quote
Old 01-20-2005, 06:40 PM   #12682
Wicked's Avatar
Hey guys,
I was going to ask about ball cups also. The rpm website shows the xxx-s needing the long ones. Yet when I look at mine they sure don't look long.
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 01-20-2005, 10:01 PM   #12683
Still Bill's Avatar
Hope this helps
Thanks Bryan. I appreciate your input. Soft settings make a lot of sense. Will be at the track to spectate on Monday, January 31. Hope to be able to come back in a couple months for a longer stay and have a go at it. Thanks again.
Old 01-22-2005, 09:24 PM   #12684
ok i have the black belt i have cleaned the bearings out and took the unexposed sheild off and shimmed the drive train and it sucks, i spin the tires and they stop spinning as soon as i let go and i have to spin it with some force to get it going. what can be causeing this and how can i fix it?
SPC Racer is offline   Reply With Quote
Old 01-22-2005, 10:39 PM   #12685
Run the belt tension as loose as you can without it skipping. I personally run my belt tension pretty tight in stock and 19t to get a bit of extra rip off of the corner. But in mod I set it only as tight until it doesn't skip too much under mild to heavy braking.
Old 01-23-2005, 08:07 AM   #12686
Still Bill's Avatar
Is your motor (and pinion) in place?
Old 01-23-2005, 08:54 AM   #12687
no
Old 01-23-2005, 10:04 AM   #12688
Still Bill's Avatar
no
Then, what does "shimmed the drivetrain" mean?
Old 01-23-2005, 10:05 AM   #12689
put shims on the out drives so they dont move side to side
Old 01-23-2005, 10:32 AM   #12690
Still Bill's Avatar
Interesting...I haven't been concerned about that side play. Could the shims be placing a side load on your outdrive bearings and/or rubbing internally?
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
