Old 01-04-2005, 02:23 PM   #12616
Wicked's Avatar
Hey thanks tc3stocker.
I finally ordered my car today. Paid to have it shipped express so I should have it by the end of the week. I also ordered my rc screwz kit today also.
I use to have an xxx-s that was converted to all graphite awhile ago. But I had got it in a trade and allot of the upgrades were already done. The only thing I had done was the screw kit.
Heres a few pics.
Baja 5B Flux, Baja 5T, HPI Savage Flux XL, Brushless Erevo, Summit, X Maxx, Arrma Big Rock, Tamiya Bruiser, & Hi lux, Slash, Skully,
Blade 200qx, Inductrix 200, Nano qx2 fpv, Cx, Proto X SLT
Wicked is offline   Reply With Quote
Old 01-06-2005, 01:35 PM   #12617
Wicked's Avatar
Is there not that many xxx-s owners anymore??
Old 01-06-2005, 03:50 PM   #12618
RCknight's Avatar
Default One ting I was thinking they need...
to update. On carpet the material around the bearings wears out quickly, diffs get really sloppy and you have to buy a whole new chassis. Maybe if they made an softer insert to go around the bearings, something that's not so hard and that wears out fast. Just a thought.
RCknight is offline   Reply With Quote
Old 01-06-2005, 05:12 PM   #12619
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
All I can say is that if your diffs become sloppy or grindy its time to clean them or replace the bearings. You would have to take the bearings apart clean them out with motor spray then oil or grease the bearings. Oiling them will make them smoother cause there is less friction and then lets them spin faster. But you just have to clean and replace the oil more often. Like once every other month. There are alot of other things to make better diffs.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 01-06-2005, 05:42 PM   #12620
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I am running the xxxs, with prp towers and tamiya shocks. The care to me feel so much better and definitely more consistant. The extra adjustments for camber on the prp towers are very nice too. The tamiyas are super smooth, I hope the shocks on the jrxs are just like them.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 01-07-2005, 08:22 AM   #12621
dstyles's Avatar
hey guys, quick question about front caster...
i have using the kit 4' spindles on the front on a large flowing track, i recently got the 6' spindles. which would benefit me more? large, flowing track = more or less caster?... can't really track test them now because it's been raining...
dstyles is offline   Reply With Quote
Old 01-07-2005, 08:35 PM   #12622
Wicked's Avatar
Hey mann I wish I could help ya but I have no clue about cars. I just got into them. However I am looking for a set of prp towers if anybody has some forsale.
Old 01-09-2005, 12:51 AM   #12623
I was just looking at some of the carpet setups on Losi's website. It looks like alot of the guys lately are running their ackerman setting "forward (flipped)". Could anyone explain to me what the "flipped" means???
Thanks!
JeffC is offline   Reply With Quote
Old 01-09-2005, 06:43 AM   #12624
Thanks!
Jeff C........ Flipped, as in 180*s. The Short end of the arm is now facing the front of the car.
What it changes, is the akerman setting of the front wheels. It will now increase the turning radius of the inside wheel and lessen the outside wheel.
I personally do not like that set up on my car. I have found the regular ackerman setting is better, because it does not scrub the inside tire as bad. Especially in tight 180* turns.
I run on indoor carpet with foam tires and high traction.
I hope I was able to make you understand the concept a little more. Someone else may have different results, but that is what I have found.
Tracy
doorman is offline   Reply With Quote
Old 01-09-2005, 11:48 AM   #12625
doorman, thanks bud. I understand ackerman very well, just wasn't sure what part they were flipping, and which way. They're just getting more ackerman effect than the standard settings will allow is all. I'm on a super high bite carpet track with foams as well... I might try this on Thursday just to see how it is. I'd guess more mid corner steering, and may want to hook a little more coming out? I could be way off though, so I'll just have to try it and find out!
Old 01-09-2005, 12:17 PM   #12626
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
I have 4 or maybe 5 XXX-S's for sale. PM me or send me an email if you are interested. My email is nodnarBllerk@hotmail.com
all of the cars are in great shape and some are new. I also have one lot of parts (over $400 worth) that I am going to sell for cheap. I am switching manufactuerers, and need to get rid of these cars, so they are going cheap ($160-$200) $200 for a brand new car never been run, with lots of hop-ups. send me an email if you are interested.
tc3stocker is offline   Reply With Quote
Old 01-09-2005, 02:34 PM   #12627
Wicked's Avatar
hey guys will the xxx-s fit 28mm foams all around comfortable?
Thanks J
Old 01-09-2005, 03:33 PM   #12628
Thanks J
Wicked, use the ASC hexes with 28 mm foam tires and you will be OK. The Losi hexes are narrower and cause a rub in the shock when you turn sharp.
Tracy
Old 01-09-2005, 04:14 PM   #12629
Wicked's Avatar
Hey mann thanks.
SO add these and I should be fine?
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old 01-09-2005, 10:51 PM   #12630
Still Bill's Avatar
Hey mann thanks.
I use the AE graphite hexes. Far cheaper and lighter than those aluminum ones.
They also make a plastic set...So, there are three different versions available.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
