Old 12-25-2004, 07:18 PM   #12586
POOKYT's Avatar
Originally posted by SPC Racer
is there any way to fix a warped chassis?
As far as I know there is no reliable way to re-tweak it. Your best bet is to find one on Ebay or check on the sale forum and see if anybody has a spare or a good used one. Good Luck.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 12-26-2004, 01:29 AM   #12587
RCknight's Avatar
Default Yes....
some small improvements would be great! Only a few things, I would like to see better droop screws, extra front shock tower hole for the camber link mod, the newer shocks and lvd. I would take anything they could do, but that would greatly please me. I would buy another one for outdoors.
RCknight is offline   Reply With Quote
Old 12-26-2004, 01:25 PM   #12588
Losifreak's Avatar
Send a message via Yahoo to Losifreak
Default Uh?...Motor
Has Anyone had any motor problems with the XXX-S Stock Motor...well mine works, but after a minute it stalls, so im looking for a replacement for it, im going to start racing in a 19 turn class, so any idea's?
Losifreak is offline   Reply With Quote
Old 12-26-2004, 01:37 PM   #12589
microrcdude's Avatar
Trader Rating: 70 (100%+)
Send a message via AIM to microrcdude
Sounds like your motor is getting a lil old. Replace it with a reedy quad mag: http://www2.towerhobbies.com/cgi-bin...?&I=LXGCH1&P=7 or get a Orion Element: http://www2.towerhobbies.com/cgi-bin...?&I=LXDUN0&P=7
Kyle @ Top Gear Hobbies
MayorRC.com
microrcdude is offline   Reply With Quote
Old 12-26-2004, 01:39 PM   #12590
RCknight's Avatar
Default has anyone tried....
cutting out material on the bottom of the chassis where the belt rubs? I think you could cover the hole with tape or something. mayby you could get a mm or two of extra space to keep it from rubbing. Just wondering if it's been done.
Old 12-26-2004, 01:40 PM   #12591
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
it shouldn't be that much of a problem, you can just tighten the belt a little
tc3stocker is offline   Reply With Quote
Old 12-26-2004, 02:53 PM   #12592
CWank23's Avatar
Send a message via AIM to CWank23 Send a message via Yahoo to CWank23
New to this thread but i have a pretty simple queston. I bought a XXXS RTRII what are some of the first hop-up parts some of you guys did to your XXXS? Any little tricks or secrets that would be helpful to know about? Thanks for your help.
CWank23 is offline   Reply With Quote
Old 12-26-2004, 03:39 PM   #12593
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
probably the best thing to get is the Graphite chassis and graphite parts. It will make the car lighter. But if your a beginner then stay with plastic until you become a better driver so u wont break as much parts. Theres other parts too but not quite sure what ti-nitride parts come with the RTRII.
Hope this helps
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 12-26-2004, 07:50 PM   #12594
RCknight's Avatar
Default CWank23...
Only things I would get would be full graphite kit, black belt kit, a kevlar spur, AE aluminum wheel hexes, ti hinge pins and some Ti screws. That will lighten up the car a lot. When the new JRXs comes out I would get the new smaller shocks.
Old 12-27-2004, 09:54 AM   #12595
If you have trouble setting the droop on your suspension, do it by shortening or lengthening your shocks. It seems that the droops screws that are located in the bumpers are prone to inconsistant adjustments because of bumper flex. The bumper's flex enough to move the droop screws up and down from where they are mounted.
The Black belt kit is one of the best hop ups I have. Graphite chassis and suspension, Titanium turnbuckle rods are a plus for less weight and ease of adjustment. I'm not sure how compatible the new shocks with the JRX-S will be with the XXX-S since those shocks are different sizes. The other option would be Losi's ti nitride threaded shocks and shock shafts. I've seen some people use Tamiya's threaded shocks from the TRF 415.
Trinity Matt Francis low roll center blocks (f/r) are also a big improvement. They have an actual true low roll center setting. I have heard that Losi's stock low roll center setting is more of a mid roll center setting. Depending on your driving/racing track, a one way front diff would be the only other thing that comes to mind. If your RTR II comes with full bearings you are ok. If there are bronze bushings in the center of the diff, hubs, steering, etc, replace them with bearings. Using bearings is probably the single best hop up there is. If you can afford it, Ceramic bearings are the best to go with, but they are spendy for a full set.
wcoyote is offline   Reply With Quote
Old 12-27-2004, 02:39 PM   #12596
RCknight's Avatar
Default wcoyote...
ya the droop screws suck on the XXX-S and that's one thing I wish the would have fixed. I hate putting spacers in the shocks, takes too much time when setting droop is so much easier.
Old 12-27-2004, 05:25 PM   #12597
imjonah's Avatar
Cwank
Leave the car alone, its fine. Work on your driving. Biggest mistake I made with this car is focusing on buying things for my car instead of focusing on track time driving it.
imjonah is offline   Reply With Quote
Old 12-27-2004, 05:29 PM   #12598
RCknight's Avatar
Default Yes it's a great car, but...
like anything it can always be improved. Not much to improve, but a very few small things could be done. I can't wait to try the new shocks out. They look to be a good design.
Yes, I agree, work on driving until you can get around the track without hitting things. Then start thinking about upgrades. I'm assuming your new to the hobby.
Old 12-27-2004, 06:06 PM   #12599
CWank23's Avatar
Thanks everyone for your suggestions. I am not exactly new to Rc cars i have been racing for 2 years, i have a mini t, nitro stampede, and a rustler, But this is my first 4wd road car. So far i love. Thanks again for all your help
Old 12-28-2004, 05:53 AM   #12600
Core Creations's Avatar
Trader Rating: 95 (100%+)
Send a message via AIM to Core Creations
Hey Chris....good to see you got a sedan! Come see me at the track when we start racin outside again. We'll have you dialed in a blink
Core Creations paint thread
Mini Mafia Kansas Chapter - where the monster minis grow!
Core Creations is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
