Old 11-28-2001, 09:30 AM   #1246
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
kraig beat sammy..oh my...sammy i got a pretty good setup form the horizon website...it is pauls....i think it should be slightly stiffer, but it works pretty good.....
Matt M. is offline   Reply With Quote
Old 11-28-2001, 10:46 AM   #1247
SpeedTech's Avatar
Hi Guys,
As you all know, the electric racing season is upon us, and we just recently did a huge update on our electric section:
Matrix P2K2 based Dyno tuned motors
Matrix Ver.II MVP based dyno tuned motors
Reedy Ti based Modified (8x2-12x2)
we also updated our brushes section with new brush compounds, and our batteries section with the new matched Sanyo 3000HV cells. Check them out on our website
Also, our Team Losi XXX-S Hop-ups are moving fast. All parts are available right now!!
Thanks!
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline   Reply With Quote
Old 11-28-2001, 11:26 AM   #1248
We'll let Kraig churp! He squeeked into the main and I made drastic changed to try to get the car faster. I made it too loose. Did he tell you he only turned me around twice???? He knows who was faster!
MK
I'm not far off on setup. I went real stiff and had the car pretty close.
SamIAm is offline   Reply With Quote
Old 11-28-2001, 11:29 AM   #1249
Administrator
Matt M.'s Avatar
oh boy.....sammy...hwo stiff, black and purple????i was thinking trinity purple and trinity blue.......
Old 11-28-2001, 02:09 PM   #1250
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
MK
Sounds like you are
I turned you once when I caught you and I got hung up on the sandbag and you got away. I caught right back up to you and I passed you when you put yourself into a wall. Besides, qualifying 7th out of 8 cars is not squeeking into the show.
Losi, I think he was running black in the front and rear but front for sure.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 11-28-2001, 02:27 PM   #1251
Administrator
Matt M.'s Avatar
thanks kraig...
Old 11-28-2001, 06:22 PM   #1252
Regional Moderator
kansasracer's Avatar
I know this question has been answered somewhere else, but I can't find it...
How loose should the belt be? I am running stock class with a MVP geared at 90/23. My belt seems real loose after the races last weekend...
Any help would be appreciated, it just seems real loose to me.
kansasracer is offline   Reply With Quote
Old 11-28-2001, 08:12 PM   #1253
Rog
I run mine just loose enough so that it doesn't or hardly skips during breaking. It's pretty loose.
Rog is offline   Reply With Quote
Old 11-28-2001, 08:54 PM   #1254
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
Got a group of xxx-s at our local track. There are 3 of us that are working together to get these things to the front of the pack. Car 1 has had a ton of steering since it was new, 2 and 3 are pushing withthe same set up on them. The only true difference is that the 2 pushers are running front bumper braces . All 3 havce the shortened shock shafts, Alum rear cvds, comparable high end servos, ect. Two of us are frustrated and the third is winning races..lol Any tips on getting more steering out of the cars or things to look for that could be causing the difference....did he just get a hot one from the factory or what???
Jeff
Jeff Werner is online now   Reply With Quote
Old 11-28-2001, 09:04 PM   #1255
Regional Moderator
Jeff,
Where are you racing in Wichita?
I am down there often (from KC) and I didn't think there was a place to race...
Have you tried putting the bearings in the steering?
Old 11-28-2001, 09:06 PM   #1256
Send a message via Yahoo to Doug Gaut
Has anybody built a front bumper/body mount brace and had it reduce the front roll in the car? I built one for my car the day I got it and my car has always had a push no matter what I do to the setup.Changing droop, ride height, etc. A friend of mine let me drive his and his car is night and day different. Much more responsive and stable. We then changed "everthing" on my car to his setup (even servos)and it still exibited the same characteristic.It will not turn in and/or carve the center of the corner. The only thing we could come up with on the trip home from the track is that he does not have a brace.The local track is 2 hours away so I cannot go and check this idea out but I was wondering if too stiff of a brace will act like a swaybar and reduce front roll somehow and also tweak the car? Sounds crazy but I am grasping at straws! This car will not turn!! Help!!
Doug Gaut is offline   Reply With Quote
Old 11-28-2001, 09:13 PM   #1257
Kenneth Tan's Avatar
Seems like the brace is causing the understeer... but how is it possible?
Kenneth Tan is offline   Reply With Quote
Old 11-28-2001, 09:23 PM   #1258
Registered User
KeNelson03's Avatar
Send a message via AIM to KeNelson03
I made one out of carbon-Fiber which would be the stiffest out material out there and I have no problem. Your probably over looking something. And the stiffer the bumper got wouldn't effect the steering charecteristics since it doesn't touch the suspention and since the chassis doesn't flex at all.
KeNelson03 is offline   Reply With Quote
Old 11-28-2001, 09:23 PM   #1259
Regional Moderator
Where are you guys racing down in Wichita? OKC?
Old 11-28-2001, 09:29 PM   #1260
We have been racing at Enid,OK and OKC both. Enid has a website. enidrcracing.com
As far as missing something, we have set the droop,rideheight,camber,caster,tires,wheels,insert s and even changed to the same brand of shock oil with no results.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
