Old 12-19-2004, 03:22 PM   #12571
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
tc3stocker is offline   Reply With Quote
Old 12-19-2004, 07:41 PM   #12572
Originally posted by Eazy
does anyone know how many teeth does a xxx-s belt have? if u do pls tell me thanks in advance
I dont know about the # but the standard belts (yellow and blue) have an even # and the HD black belt has an odd #. If your looking to cut every other tooth on the black belt you will end up w/ two teeth next to eachother in one spot.
Poppa Ray is offline   Reply With Quote
Old 12-20-2004, 06:01 PM   #12573
Default Steering Knuckle spacer
Hello, can anybody tell me how thick of a spacer should be glued to the steering knuckle to stop the wheel chatter at full lock? Thx
Charles is offline   Reply With Quote
Old 12-20-2004, 07:06 PM   #12574
RCknight's Avatar
Default Anyone see Losi updating the XXX-S?
Since they are still keeping it in production. It has just a few things that could be made better. Upgrade to the new shocks and maybe some of those Lvds. That would be nice. One in my area wins all week on a tight carpet track.
RCknight is offline   Reply With Quote
Old 12-20-2004, 07:50 PM   #12575
Still Bill's Avatar
Default Re: Anyone see Losi updating the XXX-S?
Yes, that would be a nice 'wish list' for our XXX-S cars...And some slick looking shock towers to support the new shocks...Simple!
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 12-20-2004, 07:55 PM   #12576
Trader Rating: 21 (100%+)
Charles- Use the Losi #4 washer. Part # 6215, .030 thick.
RCknight- Not sure on the shocks, but I would guess you should be able to adapt them. I find my car works best running the standard shocks on carpet. I think there will be LVD's for the car. Losi plans on making them for other makes in the future, so I am pretty sure they will be available for the XXXS.
Losi-sw-You may be able to come up with something if you have the MIP cvd's for the car. You should be able to find a axle that would except the hex. I thought we had something figured out, but that was a long time ago.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 12-21-2004, 07:51 AM   #12577
Regional Moderator
Exterminator's Avatar
Does anyone have a Carpet Oval setup for the xxx-s?
Got a fun race coming up with Kasey Kane of Nascar fame next week and would like to have the car at least close to set up for a small runline flat oval.
Retired from sponsored racing, Now just having fun.
Exterminator is offline   Reply With Quote
Old 12-22-2004, 04:21 PM   #12578
Send a message via ICQ to Bad-Attitude Send a message via AIM to Bad-Attitude Send a message via Yahoo to Bad-Attitude
I am new to RC and was thinking about getting a xxx-s rtr2 just to start with. Would this car be good to learn with and would it be competitive?
Bad-Attitude is offline   Reply With Quote
Old 12-22-2004, 05:52 PM   #12579
I think it would be a perfect first car. The radio is what sells it for me.
stumper is offline   Reply With Quote
Old 12-22-2004, 07:01 PM   #12580
Since they are going to keep it in prod I think they might make some small improvements. It actually seems practicle to me since the jrxs apears to be aimed at the hardcore racer while I think the xxx-s is more club level friendly while still being fairly competitive. What's found out after reading 72 pages of the tc4 thread the AE guys are still using Losi parts on their rides!
Old 12-23-2004, 08:59 AM   #12581
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
I've been reading this setup guide from Todd Hodge how to setup the XXX-S. And i was reading and i noticed something about the XXX-S that i never knew you could do.
On the 1/2 degree hubs for the rear for toe-in. It really gives you like 2 degrees of toe-in. Usually for mod you want that much. But for stock you should really only need 1 degree or so. So what it says is to flop the hubs backwards. So instead of having that camber link position facing outward of the wheel it will be facing into the wheel.
I just thought it was interesting and thought i should post it to those who might want to know.
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 12-23-2004, 11:01 AM   #12582
Well tl xxxs racer, you might want to reread that. You use the left hub on the right and the left hub on the right. By swapping them side to side you remove toe instead of adding toe.
JimMcClure is offline   Reply With Quote
Old 12-23-2004, 06:25 PM   #12583
Still Bill's Avatar
Yes, I think you got it.
If you place a 1/2 or 1 degree hub on the other side of the car from how it is marked ("R" or "L"), you get that much taken out of the standard 2 degrees of toe-in (per side) that is built-in to the hubs on the XXX-S. I use the 1/2 degree hub on the other side to get 1-1/2 degrees of toe-in for both my stock cars as was wisely recommended to me by Matt Francis some time ago.
Otherwise, if you place them on the same side of the car as they are marked ("R" or "L"), you will gain that much over the 2 degrees of standard toe-in (being 2-1/2 or 3 degrees).
Old 12-25-2004, 05:57 PM   #12584
is there any way to fix a warped chassis?
SPC Racer is offline   Reply With Quote
Old 12-25-2004, 06:19 PM   #12585
buy another chassis
ProMatchRacing
Team Corally
Superior Hobbies
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
