Old 12-15-2004, 01:38 PM   #12556
Default Nitro Kid
Nitro Kid-
What is your tire size? Need to know that to figure out what you should should be running for a pinion. Are you using foams or rubber tires. If foams you always need to change your pinion size to keep your final ratio the same.
What size track? The final drive always changes depending on what type of track your racing that week. And last question are your mains 4 or 5 min. And what amp are you charging your battery at?
visit Hurricane Motorsports: www.teamhurricane.net | RCAmerica www.RCAmerica.com | HUDY | JACO
bigdog xxx-s is offline   Reply With Quote
Old 12-15-2004, 01:42 PM   #12557
Ty
Ty's Avatar
Trader Rating: 25 (100%+)
7806K53
Miniature Steel Metric Ball Bearing For 3 mm Shaft Diameter, 8 mm Outside Diameter
$ 9.40 Each
search mcmaster.com for that part #. This is a PM I received from Hodge.
Ty is offline   Reply With Quote
Old 12-15-2004, 01:54 PM   #12558
Taxxas has a thrust bearing that is the same part as the McMaster Carr one, it sells for $10 in shops( I do not know the part#). Also there is a thrust by Neotech that is better then the other 2. The Neotech bearing you can get online fron Axiom racing motors or call Rc/Plus hobbies(link in sig) and they will ship them out. Also Boca bearings has one but I think it is more $$. I hope that helps.
Chad
ChadK is offline   Reply With Quote
Old 12-15-2004, 02:11 PM   #12559
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
The traxxas one is part number 2729
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 12-15-2004, 02:56 PM   #12560
Trader Rating: 59 (100%+)
Send a message via AIM to nitro kid
26mm
rubber tires
amp 4.5
nitro kid is offline   Reply With Quote
Old 12-15-2004, 02:56 PM   #12561
dgullickson's Avatar
Trader Rating: 45 (96%+)
Send a message via AIM to dgullickson Send a message via Yahoo to dgullickson
We have a very high qualtiy thrust assy. and in our opinion is better than the Traxxas style. We have had many people love our thrusts. For more info and pricing go to www.axiommotors.com thrusts are on special on homepage and are in stock!
dgullickson is offline   Reply With Quote
Old 12-15-2004, 03:03 PM   #12562
i do not know the size but here is a pic
Old 12-15-2004, 06:32 PM   #12563
Default Nitro Kid
With a 128 spur gear I'd start with a 31 tooth pinion, if you find the battery is dumping then go to the 32 tooth, if you have plenty of batter left go to the 30 tooth.
As far as the 88 spur start with a 20 tooth, I'm assuimg this is 48 pitch, then go to a 21 if the battery is duming early if plenty of life then drop to a 19.
And thanks to everyone else for the thrust brg info. Axiom looks good I wish you had some 767 in stock as well.
Old 12-15-2004, 09:52 PM   #12564
I have a limited amount in stock how many you looking for?
Old 12-16-2004, 08:48 AM   #12565
bigdogg xxxs do i need to use a 128spur or 108spur with that motor i will like to run 64p
Old 12-16-2004, 09:33 AM   #12566
Default Nitro Kid
I would use the 128.
Old 12-19-2004, 05:53 AM   #12567
is it possible for me to use xxx-s hex's on a street weapon?
please reply
thanks
losi-sw is offline   Reply With Quote
Old 12-19-2004, 05:59 AM   #12568
does anyone know how many teeth does a xxx-s belt have? if u do pls tell me thanks in advance
Eazy is offline   Reply With Quote
Old 12-19-2004, 09:34 AM   #12569
Still Bill's Avatar
I know it has been posted here long before now; but, you would have to tell us which belt...blue, yellow (same) or black.
Seems that they all had an odd number of teeth; so, you have to compromise when cutting out every-other tooth.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 12-19-2004, 09:43 AM   #12570
i actually dont mind which ever belt will do cause i just need e number of teeth for reference anyway thanks for e reply
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
