Old 12-04-2004, 08:36 PM   #12541
rinkrat99's Avatar
Send a message via AIM to rinkrat99
Default Setting Droop
Hi all,
I am having major difficulties getting my droop set correctly with the droop screws so I think its time to try the limiter method per Todd Hodge.
I just want to be sure I get this right so please comment.
Fronts - Use a 0.060" shock limiter on the piston and then adjust the eyelet for exact measurments.
Rear - I have not seen much on using a limiter and I guess this is because you need more droop. So no limiter here and adjust by the eyelet.
I plan on using 3mm Front and 5mm Rear for a high bite Ozite track.
Second question - Do I need to reset droop everytime I cut the foams down to size?
Any comments? Thanks
rinkrat99 is offline   Reply With Quote
Old 12-04-2004, 10:18 PM   #12542
huskerfreak's Avatar
The trouble that people had with setting there droop on the xxx-s was caused by the front and rear bumpers being to flexible and bending as you screwed the droop screw in. Losi solved that by coming out with the ultra rigid bumpers. Thses bumpers are much stiffer and won't flex when adjusting the droop screws.
The ansewer about adjusting the droop when cutting you tires is yes. When ever your ride hight is adjusted or camber or shock placement is change you must adjust everything acordingly.
People mistake droop and down stop as the same thing. The droop screws are really just down stop screws to limit your shock travel. The way I figure my droop is by setting my car on a flat surface holding the car down at the tires and lifting the shock tower. You see how much space you have in between your springs and you shock collar and adjust from there.
huskerfreak is offline   Reply With Quote
Old 12-09-2004, 07:03 PM   #12543
Gutter Ball's Avatar
Default Roll out for 19T
I might move into the 19T "Super Stock" class, but I have no idea what rollout to use on a Reedy 19T Spec. I looked up Hodge's 19T setup and he's using a 36 pinion on a 128 spur. WOW! Seems large (but what do I know? ) Track is pretty open with ozite carpet. I'll be using TRC foams, 60mm. Since this is a relatively new class, nobody really has any tried and true tips yet.
Any help appreciated. Thanks!
Gutter Ball is offline   Reply With Quote
Old 12-09-2004, 09:11 PM   #12544
POOKYT's Avatar
I can't speak for carpet but this past outdoor season when we ran 19 turn we typicaly geared them the same or only 1 tooth lower than our stocks. Hope this helps. Also, go to gearchart.com for a roll out calculator to help with your foam tires and gears. Good Luck.
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 12-09-2004, 10:42 PM   #12545
Default "SuperCooler"
Hey guys, I read a few posts ago, that there were questions about the Team Pharriswheel "SuperCooler". Heres a pic on a XXX-S...Let me know if anyones interested?
TeamPhariswheel is offline   Reply With Quote
Old 12-10-2004, 05:07 AM   #12546
Heres another pic of both versions of the --Team Pharriswheel "SuperCooler" & "SuperCoolerX". The original clamps on motors from the top where motor access is not obstructed, XXX-S,TC3, etc. The "X", motors sit in the "saddle" for cars that have the motor buried within the bulkheads, like the X-Ray or JRSX.
These units are good for aprox. a 60 degree temp drop (80 degree air temp, 20 degree motor temp).
Old 12-10-2004, 05:44 AM   #12547
Thanks Pookyt. I was glancing through the Losi manual and following the pattern of motor/pinion, it looked like it was going to end up being the same
I'm still using my Super Cooler as well
Old 12-10-2004, 05:46 AM   #12548
Default Re: Roll out for 19T
We have ben running 19t around here this season. We usually run at least two teeth bigger than a monster stock. I know it seems weird but that is what everyone in 19t is doing.
Ted
Ted Flack is offline   Reply With Quote
Old 12-10-2004, 05:48 AM   #12549
On a nineteen turn you have to gear it higher to get the same top speed. They have lower rpm but more tourque than a stock 27 turn. They are real stump pullers so you can get them to pull big gears. I run a 36/128 on my local track with 58mm tires with the reedy quad mag and it really rips. Just a suggestion.
JimMcClure is offline   Reply With Quote
Old 12-10-2004, 07:19 AM   #12550
Trader Rating: 59 (100%+)
Send a message via AIM to nitro kid
hey i have a monsterstock motor what gear do i need to use do i need to use a 88spur are a 128spur and what pinion do i need to use i'am looking for runtime and speed i will be race it in stock sportman with a 1500battery pack i want to here from everyone thank
nitro kid is offline   Reply With Quote
Old 12-10-2004, 07:24 AM   #12551
I think I will start with a 128/34 on 60mm, approximately a 27mm rollout. Thanks for the help/posts
Old 12-10-2004, 11:08 AM   #12552
any help will be good
Old 12-10-2004, 03:48 PM   #12553
POOKYT's Avatar
Nitro- I would always use the 128. It gives better excelleration over the other spurs. If you are running rubber tires I would start between 33 and 35. It really depends on the track. If you are running foams, some of the other guys have more experience with gears so I will let them help you.
Brant
Old 12-15-2004, 12:46 PM   #12554
Default McMaster-carr diff thrust brg part #
Does anyone off hand have to part number from McMaster-carr for the changing the front and rear diff from loose balls to a caged ball set up and wahsers.
I know I've heard about it, looking for the part number.
Thanks.
visit Hurricane Motorsports: www.teamhurricane.net | RCAmerica www.RCAmerica.com | HUDY | JACO
bigdog xxx-s is offline   Reply With Quote
Old 12-15-2004, 01:04 PM   #12555
any help
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
