Old 11-04-2004, 09:57 PM   #12451
kidDynomite's Avatar
Default Modified XXX-S for Sale
Hey guys, incase you're interested in another kick@ss car... I'm posting mine for sale. Click here for more info and pix.
kidDynomite is offline   Reply With Quote
Old 11-06-2004, 01:18 AM   #12452
BatMan99's Avatar
Post xxx-s setup for carpet oval
hey guys i just bought a used xxx-s .i race it on outdoor asphalt and since the season is over i want to race at our local track on the carpet oval.i dont know anything about setting up a car for oval or carpet.if anybody could help me with the setup such as to what tires to use and what kind of spring and anything else you could help me with would be much appreciated.i looked at losi's website and they dont have any oval setups that i could see. maybe you guys know of a website i could get a setup from to start with. thanks for any help you can give.
Brad Pederson
EGTC General Manager - Rules
TORC Trucks | F-1
BatMan99 is offline   Reply With Quote
Old 11-06-2004, 08:51 AM   #12453
Where can you get those shock towers?
Ted Flack is offline   Reply With Quote
Old 11-06-2004, 09:10 AM   #12454
Trader Rating: 17 (100%+)
Here you go Ted http://64.70.208.72/speedtechrc/89.html
429racer is offline   Reply With Quote
Old 11-06-2004, 11:42 AM   #12455
Thanks, but I am am not a fan of that silver color. The other ones at Speedtech don't have the extra row of holes.
Ted
Old 11-06-2004, 12:22 PM   #12456
Ted,
We can order a pair for you at larrys if you want.
Tony Szep is offline   Reply With Quote
Old 11-06-2004, 08:18 PM   #12457
rocketron's Avatar
Trader Rating: 16 (100%+)
the ones pictured just above i believe are PRP
rocketron is offline   Reply With Quote
Old 11-07-2004, 10:09 PM   #12458
rinkrat99's Avatar
Send a message via AIM to rinkrat99
I am running the XXX-S on Ozite carpet with the manuals stock setting but replaced the springs to White Fr, Silver Rr. Shock oil is 30W.
The outisde edges of the front tires is wearing/rounding. Camber is set at neg 2 degress alla round.
Should I go to 3 degrees or if I go to 60W oil i/o 30W this should fix itself?
rinkrat99 is offline   Reply With Quote
Old 11-08-2004, 03:05 AM   #12459
Default Im thinkin that melting pullys is not good.
Im not a pro like most of you guys but im guessing pullys melting is not a good thing. My car was driving really crappy today so i pulled it apart for a cleaning and saw that the back diff pully was all messed up - all the balls are melted way up into the plastic. So how did i do that ? It wasnt overley tight or loose or dirty. I dont get it. Any info on this would be great. Thanks. D.J.
D.J. is offline   Reply With Quote
Old 11-08-2004, 03:31 AM   #12460
Default Re: Im thinkin that melting pullys is not good.
Usually when you cook a diff, it's from slipping. I would say it loosened up on you or it was set on the loose side.
Try running it just a little bit tighter and see how long it lasts.
Tracy
doorman is offline   Reply With Quote
Old 11-08-2004, 05:08 AM   #12461
I dont think it was slipping cause I check it after every 2 packs. I was thinking about it more and there was no lube in there when i took it apart - could that be it? Also i pryed the little balls out, do you think it would be ok to use them again or should i grab new ones, they look ok and roal on glass ok.
Old 11-08-2004, 05:15 AM   #12462
Trader Rating: 194 (99%+)
Your diff was loose if your diff balls are melted into the gear. That is the only way it happens. Check to make shure it was assembled correctly.
dodgeguy is offline   Reply With Quote
Old 11-08-2004, 06:56 AM   #12463
Still Bill's Avatar
One other way to melt the rear diff wheel is when you are using the overdrive/underdrive pulley wheels on a high traction surface. The 42/41 wheel combo is what I am referring to.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 11-08-2004, 02:47 PM   #12464
2Fast4U2's Avatar
Try this link TFLack
http://www.teamprpracing.com/xxxs.html
2Fast4U2 is offline   Reply With Quote
Old 11-08-2004, 04:13 PM   #12465
Default Tightening Diffs
I bought a xxx-s used, it was already assembled, and I have scoured the manual on how to tighten the diffs. Is there a way to tighten them without dissasembling them?? I know with my xxx-t there was a detailed description with tightening the slipper, putting a hex wrench in the outdrive, yada yada yada, but the xxx-s does not have a slipper.....me confused. Can anyone help??
Ryan_B is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
