Old 11-01-2004, 08:28 PM   #12421
akrcracer's Avatar
I used purples in front & blues in rear. But I think I might try yellows in front & purples in rear. If our club starts to race this season...
akrcracer is offline   Reply With Quote
Old 11-01-2004, 08:42 PM   #12422
Default Re: Congo springs for carpet
Originally posted by XXX-S Bill
At the close of last winter's carpet season, I was using the Trinity Congo Yellow springs (44 lbs rate) and the Trinity Congo Purple springs (33 lbs rate) on the front and rear of my XXX-S carpet car with very good results. I race at Stockton carpet which is smooth with high grip.
Is anyone else listening using these high spring rate Trinity Congos for their carpet setups?
Thanks.
That is too high of a spring rate for rubber tires.
James Nguyen is offline   Reply With Quote
Old 11-01-2004, 08:55 PM   #12423
Still Bill's Avatar
Default Re: Re: Congo springs for carpet
James,
So the Congos are applicable to foam tires?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 11-01-2004, 08:57 PM   #12424
Still Bill's Avatar
akrcracer,
Is that for foam tires?
Old 11-01-2004, 09:08 PM   #12425
akrcracer's Avatar
Yes, I'm using foams. Jaco purple fronts & double pink rears.
Old 11-01-2004, 09:12 PM   #12426
Default Re: Re: Re: Congo springs for carpet
James,
Yes, I only use them when running foams.
Old 11-01-2004, 09:13 PM   #12427
Still Bill's Avatar
Thanks...I am running expert stock on rubber tires...Which James knew.
Old 11-01-2004, 09:15 PM   #12428
Still Bill's Avatar
Thanks guys!
Old 11-01-2004, 09:16 PM   #12429
Thanks guys!
No problem.
Old 11-01-2004, 09:16 PM   #12430
akrcracer's Avatar
XXX-S Bill What type of carpet is on your track? Which brand of rubber tires do you guys use? ( the most popular ones)
Old 11-01-2004, 09:19 PM   #12431
It's Ozite I believe. Most popular are Sorex 28R/24R, then Pit Shimizu 27R/22R, then TakeOff CS27/CS22. Pits have been hard to find though but work pretty good next to the Sorex tires.
Old 11-01-2004, 09:20 PM   #12432
Thanks guys!
Are you running 12th scale at the Regionals this weekend?
Old 11-01-2004, 09:23 PM   #12433
akrcracer's Avatar
Thanks James.. How about traction compound for rubber?
Old 11-01-2004, 09:33 PM   #12434
Our indoor carpet track only allows TQ Max Orange traction compound so that is all we can use. Otherwise I would be using paragon.
Old 11-01-2004, 09:39 PM   #12435
Still Bill's Avatar
Yep with a stock motor...So you can have at me...
Trying to identify another fast stock motor to use. My really fast Monster ended up as junk on its last comm cut. Got some reasonable torque Monsters for TC Stock; but, want RPMs for 1/12 stock.
Will be at Stockton Wed, Fri, Sat & Sun.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
