Old 10-21-2004, 11:08 AM   #12406
Super Moderator
Trader Rating: 17 (100%+)
Chad if you run your front tires smaller than the rears you are adding more overdrive...the front tires will spin more rpm than the rear. Can anyone give me some feedback on running the 2R blocks front and rear.....what does this do to the car?
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 10-21-2004, 11:20 AM   #12407
Running a smaller tire does under drive that end of the car. Another way to think about it is to calculate the roll out, smaller tire = less rollout.
Running the 2R block up front takes out the inner hinge pin angle, this will make the frontend dive less. I do not run this on carpet.
Chad
ChadK is offline   Reply With Quote
Old 10-21-2004, 11:31 AM   #12408
Super Moderator
then smaller diff gear means less roll out too...think about it. Anyone else see what i mean or am i just not getting it.
Old 10-21-2004, 12:12 PM   #12409
Here is the math:
Roll out=(tire size*Pi*pinion)/spur/internal gear ratio
58mm Tire with 42 pulley
(58*3.14*28)/128/1.83=21.78
58mm Tire with 41 Pulley
(58*3.14*28)/128/1.73=22.39
57.8mm Tire with 41 pulley
(57.8*3.14*28)/128/1.73=22.31
BTW the center pulley has 23 teeth
42/23=1.83
41/23=1.78
Chad
Old 10-21-2004, 01:00 PM   #12410
Super Moderator
can't argue with math!! i stand corrected. now the setup that all the losi guys around here are running is basically 2R front and rear version of bobby flacks setup. heres a dumb question...whats the 2 stand for....like 2R 4F 0F etc etc
Old 10-21-2004, 01:07 PM   #12411
The 0,2,4 is the amount of kickup/antisquat the block has. The F or R is for front or rear. Now you have to remember that the blocks were made for high or low roll center and the Losi front low blocks are really mid roll center. So if you use the front Losi low block with a 0F or 0R you get -2deg kickup a 2F or 2R will give you 0deg kickup.
Chad
Old 10-21-2004, 01:11 PM   #12412
Super Moderator
ok cool so i am using the losi low roll centers with the 2R front and rear.
Old 10-21-2004, 01:14 PM   #12413
Super Moderator
you have to forgive me Ive been running Schumacher for the past 3 years and that car is in a world of its own
Old 10-27-2004, 03:14 PM   #12414
imjonah's Avatar
Default Diff and thrust bearing greese
Anyone know what kind of clear greese comes in the little tube for the diffs, and the other tube for the thrust bearing.
also what the red greese MIP uses for its CVDs
I would like to buy these in a little larger quantity.
imjonah is offline   Reply With Quote
Old 10-28-2004, 08:14 PM   #12415
thedominator's Avatar
Send a message via AIM to thedominator
Sorry if this has been asked before, but will 30mm foams fit on the back without mods?
thedominator is offline   Reply With Quote
Old 10-29-2004, 07:33 PM   #12416
I think they will but you should use AE hex on the rear and on the front.
Tony Szep is offline   Reply With Quote
Old 11-01-2004, 02:53 AM   #12417
Sleighty's Avatar
Default RPM
i know this question has been asked before but i cannot find it.
Could somebody please tell me what the part nuber is for the rpm ballcups for the xxxs.
cheers
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 11-01-2004, 06:19 AM   #12418
akrcracer's Avatar
RPM ball cups: 73372 Black
" "81 White
" "75 Blue
" "77 Yellow
" " 78 Purple
akrcracer is offline   Reply With Quote
Old 11-01-2004, 11:03 AM   #12419
Sleighty's Avatar
" "81 White
" "75 Blue
" "77 Yellow
" " 78 Purple
thanks
A1-RC.com
Team Scream
Xray
Old 11-01-2004, 08:03 PM   #12420
Still Bill's Avatar
Default Congo springs for carpet
At the close of last winter's carpet season, I was using the Trinity Congo Yellow springs (44 lbs rate) and the Trinity Congo Purple springs (33 lbs rate) on the front and rear of my XXX-S carpet car with very good results. I race at Stockton carpet which is smooth with high grip.
Is anyone else listening using these high spring rate Trinity Congos for their carpet setups?
Thanks.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
