Old 10-14-2004, 03:39 PM   #12376
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
I tried both this past weekend in 19t and I must say I liked cyan/magenta a lot more the plaid/purple. The plaid/purple just seemed like it had really weird sidebite. Hard to explain but the car just didn't feel happy. Went back to cyan/magenta and it was dialed again.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 10-14-2004, 06:36 PM   #12377
POOKYT's Avatar
Default Re: Steering Slop?
Originally posted by SPC Racer
I have a bunch of slop in the front wheels , how can i fix it?
I have usually found 2 things causing slop in my steering and linkages. #1 check and make sure your ball joints are all tight. #2 is usually there will be slop between the ball and the cup. To fix this I will use the plastic from like a parts bag and cut a 3mm square from it. Then pop off the ball cup and put the plastic in the cup. Pop it back on and the slop should be removed without putting the cup/ball in a a bind. Hope this helps
Brant
EA Motorsports--B-Main Motorsports--Blizzard Concepts--Loose Nuts Racing--BigDog Graphics
My Carbon Footprint is Larger than Yours! :p
POOKYT is offline   Reply With Quote
Old 10-14-2004, 07:06 PM   #12378
Originally posted by 429racer
Anyone ever tried Bobby Flack setup from Losi's website on Ozite carpet yet, If so what where your thoughts on how it handled? TX
It works great i have been running it for a while with a few minor changes.(shock position moved 1 more space up)
Tony Szep is offline   Reply With Quote
Old 10-15-2004, 08:14 PM   #12379
Default Foam Setup?
Whats a good starting point for a foam setup?
SPC Racer is offline   Reply With Quote
Old 10-16-2004, 10:00 PM   #12380
huskerfreak's Avatar
Personally I think that you want a little slop. If you make your ball cups to tight your suspendsion will not work as well causing the care to feel tweak.
I think a lot of the sloppiness is due to the stock servo saver. If you have a bullet proof servo go with a regular servo horn that does not have a built in servo saver. Or be like me and a lot of other guys I have seen and run the kimbrough servo saver arm. This will help quite a bit.
huskerfreak is offline   Reply With Quote
Old 10-17-2004, 12:25 PM   #12381
Trader Rating: 17 (100%+)
Well guys, I tried the Bobby Flack setup today and let me tell you it was nothing short of just plain fast. It had plenty of steering. I used the new Parma tires and must say I was very impressed with them.
429racer is offline   Reply With Quote
Old 10-17-2004, 08:40 PM   #12382
Still Bill's Avatar
Does anyone have the McMaster-Carr catalog order number for the 3x8 thrust bearings that the Losi team drivers are using in their XXX-S cars?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 10-17-2004, 09:41 PM   #12383
R32GTR's Avatar
Can anyone point me to a set-up sheet for the XXX-S G+ that is good for a hotmix outdoor hi-speed track. We have to use Take Off CS27 tires and I am running a 9x1 motor. I just cant get rid of understeer! By the way temps are about 25c. Thanks.
"Speed has never killed anyone - suddenly becoming stationary....... That's what gets you!"
R32GTR is offline   Reply With Quote
Old 10-17-2004, 09:54 PM   #12384
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
Hi Daly,
1) Kill the spool
2) http://www.teamlosi.com/setups/xxxs_plus/index.htm
v0rtex is offline   Reply With Quote
Old 10-18-2004, 12:46 AM   #12385
Timmy_G's Avatar
Send a message via MSN to Timmy_G
Just to add to the description a bit - the track temp would have reached 95degree farenheit.
Losi, JR Propo ,Spektrum, Novarossi, AT Racing Fuels
Timmy_G is offline   Reply With Quote
Old 10-18-2004, 04:26 PM   #12386
imjonah's Avatar
Default Melted rear diff pulley again
I assumed the first time I did this it might have been a frozen bearing, second time probably did not have the diff tight enough.
This time the bearings all seem ok and the diff was tight without being overly tight. There was enough diff grease.
Is there another common cause for the plastic in the center part of the pully to melt.
I was runing stock motor 23/88 gearing with rubber tires on asphalt.
Any ideas?
imjonah is offline   Reply With Quote
Old 10-18-2004, 04:49 PM   #12387
imjonah's Avatar
Default Reliability and lower maintainence
Asphalt racing has ended here an I am thinking of running my XXX-S on a medium size indoor carpet. I have been a little frustrated my first year with all the problems with my car and with my own absent mindedness/simple mistakes.
My plan is to make a few changes to my car in order to make it a little more reliable and require a little less maintain. My plan is to work on driving skill in the off season instead of trying to make the car itself as fast as possible.
I am replacing all my bearings with rubber sealed ones. I am going to switch to longer life brushes and gear my stock motors a little lower. I am also going to get the wider front bumper(I already have the brace) I am going to use some of the clear duct tape and shoo goo to reinforce my body. I am going to try to do something to protect the rear axles. (It seems like hitting the wall whenever the car gets loose and the rear wheels even tap the wall I break a rear suspension part.)
I am going to charge my batterys at 4 amps and do a better job rotating my packs instead of depending on one or two good packs.
I am also going to try an test run the car out in the street the day before a race to help prevent nasty surprise on race day.
Does anyone have any tips for improving reliability and reducing maintainence on the XXX-S.
Old 10-18-2004, 06:06 PM   #12388
POOKYT's Avatar
Default Re: Melted rear diff pulley again
Any ideas?
I have persoanlly only seen diff pulleys and ceter diff gears melt from the diff being too loose. When I rebuild a diff and have it back together, I gradually tighten the diff untill it feels about right. After that I use 2 of the Losi flat kit wrenches and place one on each side in the outdrive slots. Then I put the 2 wrencheson the edge of a table with the diff hanging off the table so I can hold the diff in place and try to move the pulley to see if its loose or tight. Hope that helps
P.S. If you get to a point that the pulley is loose but the diff is as tight as you can get it, then refer to the manual as you may be leaving out some of the diff parts.
Brant
Old 10-18-2004, 07:26 PM   #12389
Still Bill's Avatar
Default Overdrive/Underdrive
I melted a rear diff pulley when I mistakenly used one of the 41 teeth pulleys on the rear end. I don't use a combination of overdrive/underdrive pulleys (42T/41T) anymore.
My problem also occurred using stock motor on asphalt.
Old 10-18-2004, 07:39 PM   #12390
Still Bill's Avatar
Default Re: Reliability and lower maintainence
imjonah,
Guess I don't have any suggestions to "push the envelope". Sounds as though you are retreating to safe ground.
Are you running plastic or graphite parts on your XXX-S?
Does the indoor track have "friendly" barriers?
What amps were you charging at previously?
Don't consider carpet racing to be the "off season". It is a whole season unto itself and can be just as rewarding as asphalt. I know people that only race on carpet.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
