Old 10-11-2004, 04:27 PM   #12361
Default slow
One thing that I have had problems with is the radio/rec'v/esc? Don't know what's causing it but a few times I've turned on my radio, turned on the car, and the throttle runs in reverse... or runs on what seems half throttle??? Only solution is to turn the car off and on? Kind of weird... This only happends to me on occassion, but since I don't expect top of the line electronics, I just figure I can live with it.
ZoomZoom
zoomzoom is offline   Reply With Quote
Old 10-11-2004, 05:23 PM   #12362
Cardboard's Avatar
Send a message via AIM to Cardboard
Originally posted by TL_XXX-S_racer
What you can do is then try droping the car mabye about knee height and see if the brush is free again.
or you could just pull back on the shunt and let the brush snap back.
Cardboard is offline   Reply With Quote
Old 10-11-2004, 05:49 PM   #12363
Cardboard's Avatar
i've found an excellent solution to the gear cover screw stripping problem. using this method, you can remove the gear cover with the flick of a nut. it also holds the gear cover quite securely. you will need CA glue if the screw holes are stripped.
you will need- a drill, CA glue, proper size allen drivers,one 4-40x1/2" (front diffcase)screw, two 4-40x3/8"(front shocktower to chassis) screws, and a normal nut(i used one of the nuts that goes between the shocktower and the shock bushing). do not use locknuts.
remove the bottom cover and gear cover, along with any mounting screws. get your two 4-40x3/8" screws. if the gear cover screw holes are stripped, coat the screw with ca. thread it through from under the car into the rear gear cover holes. the screw heads should be right next to the belt. repeat for other 4-40x3/8" screw and other rear gear cover hole. this should give you two posts to mount the gear cover on.
next, get out your drill and drill out the front gear cover screw hole. if you look at it, you'll see the stock screw hole only goes halfway through the chassis. drill it out so the hole goes all the way through. repeat the above steps with a 4-40x1/2" screw and the front gear cover screw hole.
mount the gear cover on the three posts you have made. you may have to enlarge the gear cover holes with an xacto.
thread the nut onto the front gear cover screw "post". do not use a driver, only use your finger or you may crack the gear cover.
there you have it. you can remove your gearcover with a flick of the nut!
Old 10-11-2004, 08:40 PM   #12364
Still Bill's Avatar
hung brush is when the brush on the motor is hung up. It doesnt get the full contact to the comm. It sometimes touches it for a few seconds then it doesnt have contact. What you can do is then try droping the car mabye about knee height and see if the brush is free again. We do this at my local track so its ok to do it. This usually frees the brush up. Then if that doesnt work try to get someont to cut the comm for you and put some new brushes in it.
If you have any more questions PM me and ill answere them
Hope this helps you understand more.
Just a bit of dirt in the brush hoods can hang a brush. Don't know about dropping the car to cure a hung brush. Usually just need to pull on the brush's shunt wire a tad and let the spring snap it back into position. Also want to make sure that the shunt wire allows the brush to move inward as the brush wears.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 10-11-2004, 09:29 PM   #12365
Default Bout to give up...
Checked for a hung brush - there fine... Basically im thinking that this setup is just slow so you pros please tell me. What do i have to do to this thing to make it go 35 - 40 ? Like what motor should i get ? My Esc can go down to 15 turn safely. Thanks in advance...
D.J. is offline   Reply With Quote
Old 10-11-2004, 10:45 PM   #12366
Send a message via AIM to Rod May Send a message via Yahoo to Rod May
Wink Losi xxx sg +
Losi xxxsg with chase by R Schure
Novak GT 7
Airtronics M8
Losi Alfa
Rod May is offline   Reply With Quote
Old 10-12-2004, 09:07 AM   #12367
Yo Rod. Post that in the buy/sell forum.
wcoyote is offline   Reply With Quote
Old 10-12-2004, 04:21 PM   #12368
Trader Rating: 17 (100%+)
Anyone ever tried Bobby Flack setup from Losi's website on Ozite carpet yet, If so what where your thoughts on how it handled? TX
429racer is offline   Reply With Quote
Old 10-12-2004, 06:33 PM   #12369
Administrator
Matt M.'s Avatar
Trader Rating: 25 (100%+)
i have run bobbys setup....it is great i am currently using it with some minor tweeks....i very good setup for a high traction track....
Matt M. is offline   Reply With Quote
Old 10-12-2004, 07:06 PM   #12370
Do you run the magentas in stock or in mod/19t or if you run stock are you using purple and plaids for stock?
Old 10-13-2004, 05:40 PM   #12371
From what I can tell Plad fronts seem to be the rule. For the rears, it's usually between Magenta or Tan.
Old 10-13-2004, 07:14 PM   #12372
For some reason I like to run that guy Bobby Flack's set-up. We use JACO double pink/orange fronts and double pink rears most of the time in stock, 19t and mod.
Ted
Ted Flack is offline   Reply With Quote
Old 10-13-2004, 08:10 PM   #12373
I figured running magentas and cyans in stock, the car would be too stuck for carrying corner speed. I ordered magentas with cyans and purple with plaid tires just in case to try them both out. I have never tried double pink/orange and double pink tires. Some of the local guys just said that it wasnt as planted ("like sliding around more") as the magentas with cyans and it just had a better feel and do not wear as much. I am guessing it is probably due to their setup, but still question their judgement.
Old 10-13-2004, 10:11 PM   #12374
J.Filipow's Avatar
Trader Rating: 14 (100%+)
429- I have never had too much luck getting the cyan/magenta combo to work with stock and/or 19T; I always go back to purple/plaids...and I don't have much experience with JACO's, so I can't comment on those.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
Reedy / RC America/XRayUSA / Hudy / Avid / JConcepts / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 10-14-2004, 04:26 PM   #12375
Default Steering Slop?
I have a bunch of slop in the front wheels , how can i fix it?
SPC Racer is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
