Old 10-08-2004, 01:12 PM   #12331
rinkrat99's Avatar
Send a message via AIM to rinkrat99
I do not think there is a stock out of the box setup. I needed it for a staring point
rinkrat99 is offline   Reply With Quote
Old 10-08-2004, 01:29 PM   #12332
"I know this probobly sounds like a stupid question but im trying to copy Paul Lemiuex's setup from the 2003 US indoor championships. He uses .090 limiters on the outside of his front shocks and .060 on the outside of the rear. What does this mean, where do you put these limiters and what do you use as limiters?
Also how would you go about lowering the rear block .060 to lower roll centre?
and finally when he says .060 does that mean inches? im from the UK so i work in metric."
Yes that is in inches
Losi makes low roll center mounts "the little blocks your hinge pins go into"
take apart your shock and the outside limiter goes on first, then the cartridge, then e-clip, shock piston e-clip. So when your done the outside limiter is between the cartridge and the shock end. Internal limiters are between the cartridge and the eclip (that holds the piston in place).
Losi makes a shock kit with spacers and such. and it comes with .030, .060 and .090.
RandyN is offline   Reply With Quote
Old 10-08-2004, 01:31 PM   #12333
Default A Wierd Noise?
actually its a horrible noise, its like a clicking or a ticking noise only when i and on the track under power is when it makes the noise. just wondering if anyone has had this problem or what i can look for?
SPC Racer is offline   Reply With Quote
Old 10-08-2004, 02:47 PM   #12334
Sleighty's Avatar
thanks 'Randy N'
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
Old 10-08-2004, 02:48 PM   #12335
Sleighty's Avatar
Default Re: A Wierd Noise?
this sound i think is your belt slipping, perhaps try a tighter setting?
A1-RC.com
Team Scream
Xray
Old 10-08-2004, 09:27 PM   #12336
BCOLEMAN's Avatar
Default SHOCK SHAFTS
I keep breaking shock shafts front ones is there anything I can do to help this problem besides stay out of the boards (I know that already )
BCOLEMAN is offline   Reply With Quote
Old 10-08-2004, 09:33 PM   #12337
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
I had the same probs, you will just have to stay off the boards and make sure that the front of your body is strong and close if not touching your body
tc3stocker is offline   Reply With Quote
Old 10-08-2004, 09:42 PM   #12338
Still Bill's Avatar
Default Re: SHOCK SHAFTS
Get the BRP add-on lower bumper for the XXX-S at $8-9. It is as wide as the front track. Saves shock shafts, arms and carriers. Adds maybe 3/4 ounce to your car.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 10-08-2004, 10:31 PM   #12339
BCOLEMAN's Avatar
Default THANKS
THANK I WILL TRY TO FIND THE BUMPER AND STAY OUT OF TROUBLE
Old 10-10-2004, 12:45 AM   #12340
Default please help make my RTR faster!
Hey - First off HOLY CRAP 400 pages of info on the XXXS- perfect.
I just came over from the RC Zone forum on the XXX and my eyes are too wasted from that 35 + pages to read any more tonight so ill just ask. I have a XXXS rtr and i really like it but it was way to slow, what can i do to make it faster? FYI - I never plan to race, I threw in a Reedy Quad mag - Still slow and im using NiMh 3000s. Ill break down my Q's to make it easy.
I have the Reedy Quad Mag in but im still running the stock gearing. What Pinion should i get ?
Should i cut every other cog of my belt or get the black belt ?
What other cheap or free tricks can i do to go faster? Any info is welcome. Thanks in advance. D.J.
D.J. is offline   Reply With Quote
Old 10-10-2004, 09:42 AM   #12341
imjonah's Avatar
Default Mounting ESC and Receiver
I have seen the ESC mounted both in front of or behind the Motor. Does moving the ESC closer to the receiver increase the danger of glitching.
I have also seen the receiver mounted on top of the servo.
Does that increase the danger of glitching (I have 27mhz FM)
What would you reccomend?
also
I connect my batterys to my ESC using a deans connector.
Could I just do away with the little ESC on/off switch and just power the car on by pluggin in the battery or will that produce some kind of damaging surge.
imjonah is offline   Reply With Quote
Old 10-10-2004, 09:53 AM   #12342
imjonah's Avatar
Default Using non-Losi Shocks
All the published setups use Losi Shocks, I believe.
If you use non-Losi shocks is their any rule of thumb you can use.? I would guess they all perform somewhat different.
I just was given some XRay shocks that have threaded collars, my current shocks are the stock Losi non-threaded shocks.
The Graphite kit comes with shorter shocks for one end of the car should I assume all the XXX-S Graphite setups assume you are using those shorter shocks?
also
is their a simple test for when shocks need to be rebuilt?
Old 10-10-2004, 09:48 PM   #12343
Default Re: please help make my RTR faster!
Alllllllllright....
Old 10-10-2004, 09:52 PM   #12344
Send a message via ICQ to v0rtex Send a message via AIM to v0rtex Send a message via MSN to v0rtex
DJ - Define slow.. Are you getting beaten every time by your friends or what?
Also, dont re-post so quickly. Someone will see your post and reply to it usually within a page. Try to keep reposts a few pages apart, and perhaps rephrase your questions again if you dont get any replies..
v0rtex is offline   Reply With Quote
Old 10-10-2004, 10:23 PM   #12345
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
DJ Driving practice practice practice..
Like barry baker says it ain't the arrow dude! its the Indian!
BadBoyRC is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
