Old 11-26-2001, 06:25 PM   #1216
Trader Rating: 19 (100%+)
Marvi,
The link below should answer some of your questions.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 11-26-2001, 07:07 PM   #1217
Regional Moderator
kansasracer's Avatar
Believe me, I can personally attest to the strength of the parts on the car.
I hit about a million walls, and didn't break anything!!!
kansasracer is offline   Reply With Quote
Old 11-26-2001, 07:15 PM   #1218
Kenneth Tan's Avatar
I tried to weigh the xxx-s last night. I weighs 1600kg with body and electronics. Dosen't that weigh too much? Has anyone encountered sluggish acceleration when using stock motors? Thanks.
Kenneth Tan is offline   Reply With Quote
Old 11-26-2001, 07:44 PM   #1219
The car stock, out of the box, is heavier than its competitors but can be lightened with the correct upgrades.
We can spend countless hours bench-racing with what is lighter, stronger, faster or others but where it really counts is the track.
The car works well out of the box and with the right tuning and driving - you can really make a strong run.
TEAMORCA.SHOP
Old 11-26-2001, 09:56 PM   #1220
kevink2's Avatar
Trips-
Thanks for the response regarding the upside down shock thing...
kevink2 is offline   Reply With Quote
Old 11-26-2001, 10:05 PM   #1221
ottoman's Avatar
R/C Tech Charter Subscriber
Is anyone running stock motor on carpet? I am the only one left running the XXX-s in stock at trackside (A main). I just dont have the punch the TC3's have. If I gear to keep up on the straights I really loose in the tight stuff and if I gear down for more snap I just get eaten on the straights. I have done all the usual stuff with the bearings and checking for binding etc. Most of the guys here only run there XXX-s in mod now and tell me its because they had the same problem. Anyone have any ideas?
ottoman is offline   Reply With Quote
Old 11-26-2001, 10:07 PM   #1222
ott,
what is your setup? that might be a good start.
TEAMORCA.SHOP
Old 11-26-2001, 10:11 PM   #1223
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
ott....i am kind of finding that in madison also....but not as bad...i can stiil keep up....sort of..i am running pauls setup, with 1\2 deg of toe added, f-2 front and r-2 rear, with the camber links as long as possible...let me know what you have...btw, who are you??
Matt M. is offline   Reply With Quote
Old 11-26-2001, 10:19 PM   #1224
ottoman's Avatar
I am still playing with setups. Have tryed all the team ones. Right now I am running the one way, no kickup, 4 degree carriers, asc. reds and blues, 80 weight stock pistons. It seems to be working well and I cant complain too much, last week I qualified second and took second in the A and Sunday I qualified third and took second in the A also. But if I could just close the acceleration gap somehow......
Old 11-26-2001, 10:20 PM   #1225
motors and batts?
TEAMORCA.SHOP
Old 11-26-2001, 10:26 PM   #1226
ottoman's Avatar
tried P2K-P2K2-GM3 all with good dyno numbers, in fact they fly in my TC3. Smh and sanyo hv with good numbers, ran GM3 sunday with 22 and 23 pinion with 88 spur
Old 11-26-2001, 10:31 PM   #1227
Did you try the FDRs you are using with the 90T instead.
TEAMORCA.SHOP
Old 11-26-2001, 10:38 PM   #1228
ottoman's Avatar
Not yet, I picked up a 90 today and I figure it will split the diff between the two pinions. I really like how the car works but it hurts to see the TC3's pull me. If I could just get the best of both in one car, nice dream huh? Well I am going to pull it apart again and see if I can see anything wrong. I have to find some more speed before the Novak race in Feb or I will be forced to go back to mt Asc.
Old 11-26-2001, 10:41 PM   #1229
Some would argue that a ratio is a ratio but.... try the 90. I have found it to be a keeper. The FDR should be close to the same. Let me know what you find.
TEAMORCA.SHOP
Old 11-26-2001, 10:45 PM   #1230
ottoman's Avatar
Thanks I will. How tight are you running your belt? On ttt some one said to tighten the belt for more punch, I havent tied it tight, I thought running it loose was better.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
