Old 09-08-2004, 10:15 AM   #12166
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I made a steel spool with an overdrive pully and a set of steel out drives JB Welded. Works great.
Jon Kerr is offline   Reply With Quote
Old 09-08-2004, 10:29 AM   #12167
The only Losi spool parts are the sand paper pads, which you can use for either steel or plastic outdrives.
ChadK is offline   Reply With Quote
Old 09-08-2004, 01:47 PM   #12168
rocketron's Avatar
Trader Rating: 16 (100%+)
Selling a near new TECH Racing Alum one-way for the XXXS here if any one maybe interested.
Tech Racing One-Way XXX-S
rocketron is offline   Reply With Quote
Old 09-08-2004, 08:01 PM   #12169
Cardboard's Avatar
Send a message via AIM to Cardboard
I have a bunch of the new beefed-up and old losi rear hubs. Will mixing and matching them on my car result in any handling problems?(they are all the same offset, of course) I was under the assumption that the arm angle remains the same and therefore droop remains the same, but I would like confirmation.
Also-Which one should I measure droop to?
Cardboard is offline   Reply With Quote
Old 09-09-2004, 10:22 AM   #12170
tom235's Avatar
hey all i have a rouned out cvd will the ae cvds work
tom235 is offline   Reply With Quote
Old 09-09-2004, 01:53 PM   #12171
EricF's Avatar
No. One of 'em is longer or shorter than the other.
AE 12R5.2 & R6(x2) - TC7.1 convert, F6 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 09-09-2004, 02:40 PM   #12172
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
that is correct in some ways, the outdrives on the TC3 are smaller than the outdrives on the XXX-S, they may work with some major mods however you should justt replace it with the Losii part
tc3stocker is offline   Reply With Quote
Old 09-09-2004, 02:46 PM   #12173
Jon Kerr's Avatar
I'm not sure if that's going to change anything or not. As long as they are the same offset and the same toe angle I don't see why it would. But I'd personally just ditch the old ones and replace them with the graphite ones.
Old 09-09-2004, 03:58 PM   #12174
tc3stocker's Avatar
if you run the old hubsthat are not beefedupyou will have a higher percentage of them breaking, it would be an advantage to you to go ahead and buy some new ones, you will be suprised, Losi doesn't beef something up just for the heck of it
for everyone who will use MF low roll center pivot mounts in the rear, you will have to add some extra shims for there to be no play, just thought you would like to know because I tried to mount mine and every time I would hit the throttle my arms would twitch from front to back, and I had to find some extra shims
Old 09-09-2004, 07:26 PM   #12175
utracer's Avatar
Wow Randy 270!!! right on nice sell how did you get that many extra parts just out of curiosity????
utracer is offline   Reply With Quote
Old 09-09-2004, 08:28 PM   #12176
Cardboard's Avatar
The old ones I'm talking about are the original graphite rear hubs. They sit flush to the arm and aren't reinforced in the hingepin area.
But, the new ones, since they are reinforced, hang under the arm, so won't that mean that the droop readings will be off? I noticed that when measured from the revised hub, I had a good 2 degrees less(numerical) droop than the arm.
Just wondering...
Old 09-09-2004, 08:31 PM   #12177
Jon Kerr's Avatar
I'm pretty sure any of the setup sheets you reed are for the revised hubs so I'd say go with the measurement from that, check the shock length for that droop setting and make both sides equal.
Old 09-09-2004, 08:32 PM   #12178
Jon Kerr's Avatar
Randy, you got $270 for all the spares? Nice!
Old 09-09-2004, 09:55 PM   #12179
Randy Caster's Avatar
Trader Rating: 46 (100%+)
270 for 2500 worth of parts is good
I guess I wont complain, eh Jon?
Old 09-10-2004, 08:26 AM   #12180
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Bling Bling lol
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
