Old 08-28-2004, 10:09 AM   #12061
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I guess you werent joking James...
We'll have to start hanging out at the car shows instead of the RC tracks now.
Old 08-28-2004, 03:46 PM   #12062
Send a message via AIM to rayray2030
I tried to run some premounted HPI Foams on 26mm mesh rims today and while the hex seemed to be the right fit apparently it's too deep and causes the front wheels to bind against the spindles. Is there some sort of spacer I need to run these wheels? TIA
Ray
rayray2030 is offline   Reply With Quote
Old 08-28-2004, 03:53 PM   #12063
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
yes, you will need to run the AE hexes for the TC3, they are wider and space the wheels out further, you will need to run them on front and rear, you will also need to get some low profile locknuts to run, because there is not as much threads to threads the lock nut on when you run the AE hexes
tc3stocker is offline   Reply With Quote
Old 08-28-2004, 06:37 PM   #12064
utracer's Avatar
I am so frustrated I am tired of trying to push my xxx-s harder and faster. It seems like there is always something I have to do to my G+ to make it faster to keep up. I think I might have to go get me a x-ray T1FK
utracer is offline   Reply With Quote
Old 08-28-2004, 06:49 PM   #12065
STLNLST's Avatar
Trader Rating: 19 (100%+)
See ya in October. It should be pretty fun from what I'm hearing.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 08-28-2004, 07:05 PM   #12066
Still Bill's Avatar
Default TC3 hexes
Yes, a perfect recommendation stocker.
The TC3 hexes come in either plastic and graphite to add about 1/16" to each side of the car. Get a set of the graphite ones for something like $3-4. You may likely spend $4-5 for the low profile aluminum locknuts.
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
Still Bill is offline   Reply With Quote
Old 08-28-2004, 07:47 PM   #12067
Cardboard's Avatar
Send a message via AIM to Cardboard
If you run 28mm wheels you'll also need to add some shims between the wheel and hex to stop the wheels from rubbing the shock eyelets.
Cardboard is offline   Reply With Quote
Old 08-28-2004, 09:08 PM   #12068
Cardboard's Avatar
What would be the minimum amount of servo torque needed for an xxx-s?
Old 08-28-2004, 09:18 PM   #12069
tc3stocker's Avatar
there is a simple solution to that problem too, put ball cups on the shock shafts instead of the eyelets, you also use the TC3 CVD stub axles, they have more threads, hit me with more
Old 08-28-2004, 09:20 PM   #12070
tc3stocker's Avatar
you don't need that much torque, unless you are talking about carpet, a S9541 servo is a good choice, as to a minimum, you would have to test alot on all diff. surfaces with all diff. setups
Old 08-28-2004, 09:22 PM   #12071
Suspended
This summer i raced an XRAY FOC and had a XXX-S G+ as my backup...well I raced the Losi for the first time this today! Damn, the Losi is now my main car...the XRAY is now my backup.
403forbidden is offline   Reply With Quote
Old 08-28-2004, 09:26 PM   #12072
tc3stocker's Avatar
that's what I like to hear, the words XRay and Backup in the same sentence
Old 08-28-2004, 09:55 PM   #12073
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Jon Kerr is offline   Reply With Quote
Old 08-28-2004, 11:23 PM   #12074
Still Bill's Avatar
That's another point for the XXX-S...But lately finding the Xray FK to be a formidable opponent.
Old 08-29-2004, 02:31 AM   #12075
Region 12 champs right? I'm forgetful..
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
