Old 08-26-2004, 06:04 AM   #12031
Send a message via MSN to Bigger Brother
Yes I snapped one too, but that was only because I did a quick gear change and dropped a washer into the drive train .....
Most of the Losi drivers in the UK use the black belt, FYI though Spashett sometimes uses a cut (every other tooth) blue belt - and hardly ever the yellow.
Also talking to one of the guys at Helger (UK importer) yesterday, apparently Losi are changing the colour of the long belts from black to yellow???? Anyone else know anything?
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 08-26-2004, 09:51 AM   #12032
tom235's Avatar
im glad im not the only one.
i have a bad on power push what is the best way to get rid of it? i went to a bigger hole piston with 70 wt in the frt 40 wt with 57 in the rear purple frt blue rr
med size outdoor track good grip
tom235 is offline   Reply With Quote
Old 08-26-2004, 09:55 AM   #12033
More Caster = More on-power steering
The Black Kat is offline   Reply With Quote
Old 08-26-2004, 11:02 AM   #12034
utracer's Avatar
ggrrrrrrrr! I can not bet my car to hook up. I think I am going to get the hudy tweek station. I know I can beat the guys at my track if my car would just hook up like everyone else. I am so addicted to racing this car HAHAHAHA
utracer is offline   Reply With Quote
Old 08-26-2004, 11:02 AM   #12035
utracer's Avatar
yeah............that should have said I can't get my car to hook up good
Old 08-26-2004, 12:01 PM   #12036
NVisible's Avatar
save your money. i got my G+ to hook up straight without a tweak station. If you havent already, look at the Losi website for tips on how to adjust the tweak on your car... unless of course your heart is set on getting a station, fill your boots.
NVisible is offline   Reply With Quote
Old 08-26-2004, 01:35 PM   #12037
utracer's Avatar
I think that poeple like me who are a little slow hahaha need the extra help
Old 08-26-2004, 01:59 PM   #12038
Send a message via AIM to rayray2030
What modifications do I need to do to the G+ in order to run tamiya shocks?
Also after finally getting my car to hook up a bit better on my local track I am noticing uneven tire wear with the inside of the tires developing a bit of a "lip" of excess rubber. Is this normal? If not how can I get my tires to wear evenly?
Ray
rayray2030 is offline   Reply With Quote
Old 08-26-2004, 02:03 PM   #12039
mwcet8k's Avatar
How much camber are you running? You generally want to run about -1 degrees all around. Your camber setting is probably what is causing that to occur.
mwcet8k is offline   Reply With Quote
Old 08-26-2004, 02:05 PM   #12040
I am running -1 degree all around. Would the layout of the track have something to do with it? I believe only the tires on the left side of the car are exhibiting this symptom.
Ray
Old 08-26-2004, 02:17 PM   #12041
mwcet8k's Avatar
Two other causes I can think of:
1. Your car may not be balanced regarding the weight of the left side vs. the right side. Consequently, more stress is being put on the left side tires when cornering. You can check the balance (aka "tweak) of your car with a setup/tweak board.
2. You may also be running tires that are too soft. If you run on asphalt in hot weather, softer tires can't handle the heat and will wear out prematurely and in some cases deform. Make sure the tires you're running are rated to handle the surface temp of your track.
Old 08-26-2004, 02:40 PM   #12042
raving-monkey's Avatar
Send a message via MSN to raving-monkey
our tyres always wear more on teh left than the right..
this is because 3 of the fastest corners are right handers (going onto the straight, coming off the straight and corner after the sweeper) and all the weight is going onto the left wheels.
if they are slicks/foams keep swapping them over with the right, this will keep tyre wear even on both sides.
if they are treaded, and are directional then i guess there isn't a solution.
raving-monkey is offline   Reply With Quote
Old 08-26-2004, 02:48 PM   #12043
Losifreak's Avatar
Send a message via Yahoo to Losifreak
Default True
Yes that is so true, anyone no some good replacement tire for some racing, or should i just stick with the stock because they are not completely worn out...
Losifreak is offline   Reply With Quote
Old 08-26-2004, 03:07 PM   #12044
utracer's Avatar
Thumbs up
sorex tires are awsome
Old 08-26-2004, 03:49 PM   #12045
Sleighty's Avatar
hey guys,
I know this has most likely been gone over loads of times but, i was thinking about getting an XXXs G+ and i hear you can fit the Tamiya shocks on the car?
firstly which ones exactly?
do they fit without any modifications?
are they as adjustable?
pretty much what are the pro's and cons?
cheers guys any help is much appreciated!
A1-RC.com
Team Scream
Xray
Sleighty is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
