Old 08-24-2004, 12:56 AM   #12001
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by Griffin
Randy: What bit and speed do you use when milling your chassis? Do you use any fixturing to control the depth?
I use a downcut spiral bit, and the only thing controlling the depth of my cut is a steady hand on my dremel. I've seen most of the cars that you guys get pics of with the milled chassis' and I gotta say they are much better in person.
Hey Steve, the pic of a sedan with dirt in the background, is that your greek car, or did he do something similar?
Old 08-24-2004, 05:38 AM   #12002
HarshGuy's Avatar
Originally posted by rice
harshguy,
looks great. dude how much weight is taken off or whats the total weight of the car with body,tires,esc,servo and batt?
I weighed this and my other Losi which has all the same electronics, this is almost 3.5 ounces lighter!!
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-24-2004, 07:43 PM   #12003
raving-monkey's Avatar
Send a message via MSN to raving-monkey
hi guys.
i just been hunting around for a pretty cheap TC so i can get back into it (ignore my sig, i dont have an xray t1r no more)
i came accross this on another forum i go on, i wondered if you guys thought it was a good buy
Team losi g+ for sale it has
2 chassis
Titaniam screws
Titaniam drive shafts
Alll the springs
20 wishbones
20 hubs
10 c hubs
spur gears
belts
1 way diff
diff
shock towers
Titaniam hing pins
Alfa body shell
all in mint condition only 4 100 (GBP)
imo, it is very very very cheap, as G+ chassis' gof or 100 alone over here.
so do you think i should go for it, and get it?
Matt
raving-monkey is offline   Reply With Quote
Old 08-24-2004, 08:21 PM   #12004
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
how much is that in USD?
Jon Kerr is offline   Reply With Quote
Old 08-24-2004, 08:33 PM   #12005
mwcet8k's Avatar
That's about $180 U.S. dollars. If it's all in mint condition as he says, then it's a heck of a good deal.
mwcet8k is offline   Reply With Quote
Old 08-24-2004, 08:41 PM   #12006
Jon Kerr's Avatar
$180 for all that? Go for it. And yes, get the black belt, it's worth the money
Old 08-24-2004, 09:13 PM   #12007
utracer's Avatar
interesting so basically all your doing for a spool is looking the fron diff????
utracer is offline   Reply With Quote
Old 08-24-2004, 09:45 PM   #12008
mwcet8k's Avatar
Yeah, it's just a solid axle. Not sure why it's called a spool - calling it a solid axle would eliminate some confusion. Because a spool is a very simple design, they're lighter than diffs or one-ways, so acceleration is improved.
Old 08-25-2004, 06:23 AM   #12009
just waiting for the guy to reply with his paypal address...wooooohooooooo
i think some people call them spools because some companies started calling them spools, while other companies called tehm solid axles.
but everyone knows what we are on about when peeps say spool
Old 08-25-2004, 07:53 AM   #12010
Hey Mantis,
I just recently built a XXX-s and ran into the same problem. It seems i didn't have my belt tensioner snapped completly onto the bearing/bushing and i may have had one of my diffs in backwards. Once i changed both of those things, my belt never wandered.
HTH
Karen
KBailey is offline   Reply With Quote
Old 08-25-2004, 08:58 AM   #12011
The Evicerator
Randy, I believe that one is his...
Steve Weiss
TEAM ASSOCIATED -- REEDY -- SANWA -- PROTOFORM -- P1 BRAND -- TUNING HAUS -- TEAM KINWALD -- TEAM STEVE INTERNATIONAL
Steve Weiss is offline   Reply With Quote
Old 08-25-2004, 09:01 AM   #12012
Juan Valdez's Avatar
Foam tire asphalt setup?
Hey Losi experts,
My local track is planning a big (or bigger than usual) on-road race. This is a large asphalt track, and most all of the classes are set to be foam tires. Does anyone have a good foam/asphalt set up? Would the foam/carpet setups on Losi's page be a good starting point? How about tires? Jaco Purple/Plaids acceptable? Thanks for helping out a foam newbie.
TLR 22 3.0 | TLR 22-4 | TLR 8ight-E 3.0 | Tamiya TA07 | Tamiya TA05
Juan Valdez is offline   Reply With Quote
Old 08-25-2004, 09:08 AM   #12013
The Evicerator
Actually, it's best if your belt wanders a little bit when your drive train is spinning...
if it's stead fast against one side that means that it's more than likely binding against the retaining wall of the pulley and causing more drag in your drive train...
Steve Weiss
Old 08-25-2004, 01:52 PM   #12014
Send a message via AIM to Roberto Falcon
is it a waste of time to cut(every other tooth) on your yellow belt .
and just buy the black belt kit ? ..
Roberto Falcon is offline   Reply With Quote
Old 08-25-2004, 02:16 PM   #12015
The Evicerator
Yeah, I'd say it's easier to get the black belt right than it is to cut the yellow belt
Steve Weiss
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
