Old 08-25-2001, 09:29 AM   #106
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
i set my mesh by looking throught the hole....
fut, shawn wernick has one to...i have two pair of rear arms, one graphite, one not, a pully set, and the optiona. .5 and 1 deg rear hubs...i will sell you the non graphite rear arms...if you like...
Matt M. is offline   Reply With Quote
Old 08-25-2001, 10:00 AM   #107
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
As for the gear mesh,
Just peek in the little window, and rock the rear tires back and forth. You can also take the tip of your small .050" allen wrench and rock it, or the tip of you X-Acto, or a golf tee, or a toothpick, or a hair pin, or a .........
You get the point.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 08-25-2001, 12:21 PM   #108
R/C Tech Founder
R/C Tech Charter Subscriber
Hey guys here's a Q for you...
I want to make sure I have the right selection of pinions when I go down to the track tomorrow. I haven't really had a chance to test stock with the car yet.
I'm going to be running GM3s and P2Ks (depending on the track configuration). What range of pinion sizes do I need to bring? What's a good starting point?
Thanks!
futureal is offline   Reply With Quote
Old 08-25-2001, 12:29 PM   #109
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I have been hearing that the stock 26 tooth pinion has been leaving the motor kind of hot. Some people have suggested 24 and 25 tooth. On a side note, What have you all been using for the Pinion Gear. I could have sworn on the old board that someone was having problems with the mesh using Trinity Pinion Gears. What inion Gears do you guys recommend and has anyone seen or heard of a conversion kit so that we can use any Spur gear matched with the Losi pully gear. I would love to get this conversion so that we can use 64 pitch gears.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 08-25-2001, 03:32 PM   #110
Thanks for the help guys. Sir Speedy your post had me cracking up
As for the gearing I would suggest starting in the 22-25 gear range depending on the size of the track. I usually use between a 22 and a 24 but my track is somewhat small at 72 x 42. I'm using Robinson 48 pitch pinion gears but I can't wait for somebody to come out with a 64 pitch adapter. Seems like going up or down one tooth in 48 pitch can be too much sometimes.
Schuie Driver is offline   Reply With Quote
Old 08-25-2001, 03:55 PM   #111
R/C Tech Founder
Yea, I agree, I have always run 64 pitch in just about every touring car I've run; I started with an HPI RS4 Pro which of course came with 64P gears, and I never looked back... had to go out today and stock up on some 48 pitch pinions specifically for the Losi. I should be all set though.
Thanks for the advice guys...
Old 08-25-2001, 04:24 PM   #112
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Thanks!
Shane - Last time, with GM3's, i was running 24... jason was running 25. I dont know what Matt was running.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 08-25-2001, 05:47 PM   #113
Trader Rating: 49 (100%+)
Yeah, for GM3, use either a 24 or 25. I went down to a 22 this weekend becuase I thought the motor was a little to warm and it was the wrong move.
I still haven't found out the optimal gear for a p2k though.
rodneybarrett is offline   Reply With Quote
Old 08-25-2001, 06:10 PM   #114
Trader Rating: 19 (100%+)
27 and 28 for P2K.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 08-25-2001, 07:16 PM   #115
What size spur gear are you guys using with these pinions? thanks
petersiu007 is offline   Reply With Quote
Old 08-25-2001, 07:20 PM   #116
Running the 88.
TEAMORCA.SHOP
Old 08-25-2001, 07:46 PM   #117
RCTech Member #2
TSR6's Avatar
The optional spurs arent all that availible yet.
Troy
RCTech Member #2
Old 08-25-2001, 08:10 PM   #118
Trips's Avatar
Trader Rating: 16 (100%+)
Just got home from the Trinity Shootout at Englishtown. The Mod A main was an INCREDIBLE race between Joel Johnson and Paul Lemieux. They just flat drove away from everyone. Their XXX-S's looked like they were defying the laws of physics. Corner speed was incredible, and acceleration that looked like the Enterprise going into warp.
Joel led for the first half of the race, then nipped a board and left just enouigh room for Lemieux to get through. Once he got past, Lemieux drove away.
WOW.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 08-25-2001, 08:14 PM   #119
good to see that Joel is racing again, and in fine fasion. hope to see joel setup as well.
rcspeed is offline   Reply With Quote
Old 08-25-2001, 08:17 PM   #120
I think Joel is but the first of the veteran guards to return back to racing. This should get interesting....
TEAMORCA.SHOP
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
