Old 08-05-2004, 02:52 PM   #11836
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You should be able to splice a plug onto your fan and plug it into the batt plug on the receiver. Make sure the positive and neg wires are going into the right spots on the receiver. The third wire on the ESC and servo are signal wires. I wouldn't run the wires to the motor. That won't do any good.
Jon Kerr is offline   Reply With Quote
Old 08-05-2004, 02:57 PM   #11837
tom235's Avatar
but then the fan will run allthe time
tom235 is offline   Reply With Quote
Old 08-05-2004, 03:05 PM   #11838
Jon Kerr's Avatar
That's a good thing. These fans draw very little power. You'll never notice it and you want the fan to blow full power all the time, not just when you're at full throttle down the straight.
Old 08-05-2004, 03:08 PM   #11839
tom235's Avatar
i see that makes sence
Old 08-05-2004, 04:58 PM   #11840
Cardboard's Avatar
Send a message via AIM to Cardboard
What's the difference with the off-set rear hub mounting positions on carpet? Every carpet setup i've seen uses them.
Cardboard is offline   Reply With Quote
Old 08-05-2004, 05:13 PM   #11841
JayBee's Avatar
Trader Rating: 31 (100%+)
OK, let me get this straight, when I splice a plug onto my fan<------ what kind of plug? and where do I get something like that? and what about that 3rd signal wire, is that something to worry about or do I need to splice something like that in too? This is all a bit remote to me, so guys please be patient
THANKS
- jAYbEe
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-05-2004, 05:16 PM   #11842
DavidAlford's Avatar
Send a message via AIM to DavidAlford
I'd just wire it like you would a personal transponder and plug it in the RX. That would seem like the easy way to do it and make it look clean.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 08-05-2004, 05:18 PM   #11843
Cardboard's Avatar
Your probably better off directly soldering the wires to the prongs or to the motor, because splicing wires into a new reciever plug requires a specific crimper($25, It's made by MIP).
You need a batt reciever plug, it's found on nitro car's battery boxes.
Old 08-05-2004, 05:20 PM   #11844
Or you can just use an old broke servo and solder the leads on.
Old 08-05-2004, 05:31 PM   #11845
I have a jr xs3 but all my channels are fillrd up, what if i put it in the battery slot?
Tony Szep is offline   Reply With Quote
Old 08-05-2004, 05:33 PM   #11846
Any slot should work.
Old 08-05-2004, 05:35 PM   #11847
thanks
Old 08-05-2004, 08:13 PM   #11848
Trader Rating: 21 (100%+)
The offset hub takes away rear traction. Carpet has so much bite and this is a way to free up the rear end a little.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 08-05-2004, 11:53 PM   #11849
JayBee's Avatar
Post
I just soldered the fan's wire terminals to the motor terminals and I like the way it works actually; I figured that you can't have the fan running continuously anyway when you change batteries. But what do I know?
I will get another one though and try to hook it up the other way.
BTW, what I'm looking for though is the bracket that holds the motor plate down; I've heard that there is one that's an actual heat sink made for the XXX-s. Anyone know of this?
- JaYBeE
Old 08-06-2004, 05:22 AM   #11850
yes there is a heat sink it is from trinity it works real well it cost about 12.00
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
