Old 11-19-2001, 09:41 PM   #1171
Send a message via AIM to ZER01
Futureal-I've been using the servo saver that came with the kit on my Futaba 9404 ever since September and the only problem I've encountered is that the servo saver screw backed out on it a couple of weeks ago. This car has very little "slop" in steering.
ZER01 is offline   Reply With Quote
Old 11-19-2001, 10:14 PM   #1172
Trips's Avatar
Trader Rating: 16 (100%+)
Originally posted by seaball
if you fill em full, bleed the excess out, and then tighten, a vaccum will be created when the shaft is extended. this would draw the shaft back in and the point of equalization would be when it's compressed. is this how you do it?
My shocks suck the shafts back in when they're built. Not completely, but close to it, like between 3/4 and fully in.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 11-19-2001, 10:22 PM   #1173
MauiBuilt Racer's Avatar
Does anybody know the total weight of the xxx-s with all the graphite hop ups?
MauiBuilt Racer is offline   Reply With Quote
Old 11-19-2001, 10:26 PM   #1174
Trips
Isn't that suppose to happen when you rebuild shocks? I'm pretty sure your doing it correctly.
Old 11-19-2001, 10:36 PM   #1175
Trips's Avatar
I'm pretty sure too... I was answering seaball's question.
Trips
MARSHAL!!
Old 11-19-2001, 11:53 PM   #1176
Oh ok lol...my bad
Old 11-20-2001, 06:51 AM   #1177
mike_Webb's Avatar
Send a message via AIM to mike_Webb
My Car weight with all Graphite except for Battery Strap, Tunnel and Bottom Belt Cover is 51oz. I have a Quantum Comp Speed Controler, KO receiver for EX-1, KO 2943 FET Servo and P2K motor, all 3000SMH cells. Foam Tires, No Aluminum Screws yet.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 11-20-2001, 02:59 PM   #1178
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
trips and fellas,
ok thanks again for the posts. that's news to me. some of the other shock manufacturers suggest that they do the opposite and return out to almost full lenth when equalized. i'm gonna give it a try. does the suction adversely affect droop effects? 'cause there is no spring force at the very bottom of the travel if you run alot of droop. what do ya think trips? later.
seaball is offline   Reply With Quote
Old 11-20-2001, 03:04 PM   #1179
Trips's Avatar
I suppose it could, but I think the weight of the arms, CVD shafts, and hubs would easily overcome the slight suction in the shocks.
Also bear in mind that you'd have to run a LOT of droop to get the shocks out to their full extension.
Trips
MARSHAL!!
Old 11-20-2001, 03:11 PM   #1180
seaball's Avatar
i run so much droop it hurts!
whatever that means.
Old 11-21-2001, 06:34 PM   #1181
Suspended
Thumbs down A Pile of Junk???
I am not satisfied with this piece of junk.!!
I raced it twice and both times I broke an arm, I am not that bad a driver!!
I have raced a TC3 for an entire season and never broke anything!!!
I am going to remove all the electronics and use it for a fishing weight I think...
Jamracing 1 is offline   Reply With Quote
Old 11-21-2001, 08:31 PM   #1182
HarshGuy's Avatar
Interested in selling the fishing weight?
HarshGuy is offline   Reply With Quote
Old 11-21-2001, 08:51 PM   #1183
Send a message via ICQ to SirSpeedy Send a message via AIM to SirSpeedy Send a message via Yahoo to SirSpeedy
Nice.
Tim Davis
SirSpeedy is offline   Reply With Quote
Old 11-22-2001, 01:49 AM   #1184
STLNLST's Avatar
Trader Rating: 21 (100%+)
I had a KILLER run tonight with the car. I ran the Matt Francis set up with the following changes.
1) Changed the pistons to 56 all the way around
2) ran a blue spring in the rear with the shock in the 2nd hole from the inside.
3) Ran a Yokomo green spring up front with the shock in the 2nd hole from the inside.
The reason why I went with the Yokomo spring was because I only wanted the front end slightly stiffer than the rear and going from blue to purple was too big a jump IMO. The Yokomo green is right in the middle of the two. The car had excellent steering and great rear traction. If you guys have some practice time I would give this set up a try.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-22-2001, 07:10 PM   #1185
Has anyone encountered any problems with running the 1-way. I heard that someone was snapping the cups on the bones where the cvd pin goes. The reason for this question is, if you turn the steering fully left or right(with the car on a stand) the cvd's will bind up and make the wheels bounce terrible bad. The sound of it definately tells you the cvd's are binding up right at the joint. I've tried moving the wheelbase on the front up, but it seems like that does'nt help solve the problem.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
