Losi XXX-S
Re: WHEEL CHATTERING
Originally posted by Tony Szep
it is most likely to be the wheel hitting the shock this has been hapining to me since i have had the car put AE hexes on the front and rear, this should solve all your problems
Thank you for that anyhow
- JayBee
do you have a pic of this mod? Is the gold washer glued on the spindle where it hits the c hub?
Originally posted by RichO
I agree with earlier assessments. If you grab your front wheel and turn it, you will notice that there is play on the inside wheel (generally quite significant). This play is what causes the CVD's to chatter. If you put the gold washer on the spindle, that play will be removed and you shouldn't get the chatter anymore.
Yep, you glue it to where it just can't get to full lock.
R/C Tech Elite Member
Originally posted by JayBee
Where on the steering spindle
Have you encountered this problem? And what's wrong with the CVD's-- are they too long, bent slightly, ???
- JayBee
- JayBee
Glue a gold washer on the little nub on the spindle where it hits the caster block.
diffs
has anyone used only half of there balls in the diff to cut down the rotating mass and if so does it work
Any word on the short white natural ballcups ive seen all the team drivers using them,but i guss i could cut them down but i would not like to spend all that time measuring and cutting.
I don't see the point in that.
Re: diffs
Todd said it was something they are working on. I just run the cut down ones on mine.
thanks
i cut my rpm yellow it wasnt that bad.
i have even seen people cutting the black belt and when that gets worn in its amazing
Anyone have a link to Ray Darroch's set-up from this years snowbirds??
Thanks in advance!
Kevin
Thanks in advance!
Kevin
Thanks in advance!
Kevin
Thanks in advance!
Kevin
DavidAlford
You've got PM
