Old 08-05-2004, 09:04 AM   #11791
What set up do all you guys run for stock carpet (Tight)?
I have been experimenting with Bobby Flacks trackside and David Spashett Cleveland indoor chapms from 2001. Amy more sugestions?
Tony Szep is offline   Reply With Quote
Old 08-05-2004, 09:07 AM   #11792
Originally posted by DavidAlford
Those bumpers break way to easy. Just set the droop by the shocks. Its a pain at first but once you get it down its really pretty simple. You'll never have a problem with droop after that.
Thanks, but i just bought the bumpers so i guss when they break i will try the limiters.
Old 08-05-2004, 09:07 AM   #11793
jrighter's Avatar
If you set droop by uptravel your droop does indeed change.
jrighter is offline   Reply With Quote
Old 08-05-2004, 09:12 AM   #11794
I know this is somewhat off topic but any one know where i can sign up for clevland 2004?
Old 08-05-2004, 09:26 AM   #11795
Tech&Tuner's Avatar
Default Reedy 19T Gearing
Originally posted by Jeff Werner
Those Reedy 19t make you tink you are crazy for putting that gear on them but they work. I was getting 3 quality runs during practice at the Nats with that gearing (5.80). Think it will make your motor work a bit better for you.
Let us know how it goes with it.
Jeff
I must say that gearing works well for that motor even at the 2 tracks I run here in the Philippines... Seems high, but it makes the motor come alive!
Tech&Tuner is offline   Reply With Quote
Old 08-05-2004, 09:37 AM   #11796
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Yep, I thought Todd was crazy when he told me that gearing. The only problem was coming up with a 41 tooth pinion.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 08-05-2004, 09:38 AM   #11797
Randy Caster's Avatar
Trader Rating: 46 (100%+)
For droop, just put more inner limiters than you need and adjust it by unscrewing the shock eyelet, much easier than changing limiters every time to get different droop.
Old 08-05-2004, 09:38 AM   #11798
JayBee's Avatar
Post
stupid steering
I've been trying to fix this problem for about a month now, AND IT WON'T GO AWAY .
When I turn the wheels either left or right, there's alot of wheel chatter. I've cut back on my left and right steering throw, EPA and whatever else I could adjust on the radio, I did it. I mean, I turned my radio all the way down to 60 and I still get shake & chatter. I put on new RPM ball cups <----- didn't help a bit! The only thing that did help substantially is putting o-rings (the ones that goes in the stock RTR shocks) over the bstuds underneath the bcups as cushions . But as I later investigated, that did nothing but bind up the movement in my suspension . I absolutely love this car, but dealing with this problem for so long is making me think of moving on (like to my Yoke)
I don't know how the G+ is, but I should've gotten that in the 1st place 'cause this RTR..........
Can someone think of anything else before this car's a hasbeen
- JayBee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-05-2004, 09:38 AM   #11799
wannabee's Avatar
Originally posted by HarshGuy
Droop doesn't change with tire wear, ride height does and for that if you have threaded shocks that's a piece of cake to change.
The Up-travel will change as you crank down on the shocks! I normally use that method vs's the droop gauge!
Thanks everyone for your input, I'll limit the shocks...
wannabee is offline   Reply With Quote
Old 08-05-2004, 09:43 AM   #11800
JayBee's Avatar
Post
Yeah I've broken 2 of those DAMN THINGS already
- JayBee
Old 08-05-2004, 09:45 AM   #11801
Originally posted by JayBee
stupid steering
- JayBee
Thats in your CVD's, not your ballcups. They are binding up and thats what causes the sound. Try rebuilding them and see if that helps. You can also glue a gold washer to the steering spindle to limit the movement.
Old 08-05-2004, 10:00 AM   #11802
JayBee's Avatar
Where on the steering spindle
Have you encountered this problem? And what's wrong with the CVD's-- are they too long, bent slightly, ???
- JayBee
Old 08-05-2004, 10:03 AM   #11803
tom235's Avatar
Default xxx-s
i think cutting every other tooth helped my car ,but i am looking to free it up more. are there any heavy friction points that i can free up.
tom235 is offline   Reply With Quote
Old 08-05-2004, 10:32 AM   #11804
Default WHEEL CHATTERING
it is most likely to be the wheel hitting the shock this has been hapining to me since i have had the car put AE hexes on the front and rear, this should solve all your problems
Old 08-05-2004, 10:39 AM   #11805
RichO's Avatar
I agree with earlier assessments. If you grab your front wheel and turn it, you will notice that there is play on the inside wheel (generally quite significant). This play is what causes the CVD's to chatter. If you put the gold washer on the spindle, that play will be removed and you shouldn't get the chatter anymore.
RichO is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
