Old 08-04-2004, 09:51 PM   #11776
RichO's Avatar
Is anyone still messing around with teeth cut off of the black belt for 19T Rubber? I switched back to the full belt and the times were pretty even, but with the NORRCA nats coming up I was wondering if anyone one else has an opinion on the drive train drag of a cut vs. non-cut black belt?
-Rich
RichO is offline   Reply With Quote
Old 08-04-2004, 10:19 PM   #11777
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I've always run the black belt cut. I run modified and not once had any problems with it.
Jon Kerr is offline   Reply With Quote
Old 08-04-2004, 11:02 PM   #11778
mwcet8k's Avatar
Hey Jon, what kind of modifieds are you running? Just wondering.
mwcet8k is offline   Reply With Quote
Old 08-05-2004, 09:08 AM   #11779
Jon Kerr's Avatar
I've been running Orion but I'm going to try Team BrOOd this weekend. Eddie is a good guy and I've seen some of the motors he's sent Randy and I've been really impressed. I'm getting a KR based motor from him for this weekend. I like the Orions but they just don't have any bottom end. But I haven't done much to try and get that bottom end other than trying to put different arms in them.
Old 08-05-2004, 09:17 AM   #11780
rice's Avatar
what's the actual weight of your losi with all the stuff in it?
rice is offline   Reply With Quote
Old 08-05-2004, 09:23 AM   #11781
wannabee's Avatar
Been running an Xray but got sick of ordering parts! So I bought a G+ to run the car is dialed just wanted to ask a questions that I'm sure has been asked a million times!
Front droop, are you guys doing any tricks to keep the tabs where the droop screw threads thru from flexing?? Or using limits in the shocks??
And are you guys running the 0R block up front in which case the droop screws are eliminated all together??
Thanks in advance!
Kevin
wannabee is offline   Reply With Quote
Old 08-05-2004, 09:36 AM   #11782
RichO's Avatar
I am running the 2R block up front and I am using the shock limiting method for both front and rear. I don't run a rear bumper to save weight.
Old 08-05-2004, 09:37 AM   #11783
RichO's Avatar
JKerr: How many teeth are you cutting currently? Have you found that the belt wears out or stretches?
BTW: I am going to have a setup for hot climates, good traction and spools coming back your direction after this weekend.
Old 08-05-2004, 09:38 AM   #11784
Jon Kerr's Avatar
The droop screws don't work on this car at all. That's one big complaint from everyone. Just limit the shocks and use the shock ends to adjust droop.
Old 08-05-2004, 09:41 AM   #11785
RichO's Avatar
Its a pain setting the droop. Teadious task that requires some patience. Hopefully they will fix this issue in the "new car".
Are you guys tending towards measuring the droop with the ride height method or Losi gauge? I flip back and forth, but I find the gauge awkward at times because it rocks slightly leading to minor inaccuracy... probably me but...
Disclaimer: "new car" refers to a car yet to be named or announced, sure to be coming, but completely denied at this time.
Old 08-05-2004, 09:43 AM   #11786
Jon Kerr's Avatar
I'm cutting every other tooth and I've been running the same belt since they came out. Drive train is nice and free and no major wear.
Send me that setup. I'd be interested to take a look at it.
Old 08-05-2004, 09:47 AM   #11787
wannabee's Avatar
Thanks guys that is what I thought...I run foams so re-setting after ride changes will be a pain I guess!!
Old 08-05-2004, 09:52 AM   #11788
Buy the extra rigid bumper part# A-4237 it is a hell of alot harder but you may have a better chance of breaking it though
Tony Szep is offline   Reply With Quote
Old 08-05-2004, 09:55 AM   #11789
HarshGuy's Avatar
Droop doesn't change with tire wear, ride height does and for that if you have threaded shocks that's a piece of cake to change.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 08-05-2004, 10:03 AM   #11790
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Those bumpers break way to easy. Just set the droop by the shocks. Its a pain at first but once you get it down its really pretty simple. You'll never have a problem with droop after that.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 08:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 04:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 07:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 07:13 PM
SEO by vBSEO 3.5.0
