Losi XXX-S
Originally posted by mwcet8k
If I were you I would just dial in some auto break using your ESC. Just increase it in small increments until you get the amount of braking you want.
thanks.
automatic brakes
You can set your throttle trim neutral position to center more towards the brake. In other words, when you don't have your finger on the trigger the car will not move at all, even when it pointing down hill.
E
E
That also means that you won't have forward until you pull back on the throttle for a little bit
DID LOSI MAKE A CHANGE TO THEIR SPRINGS SIZE? THE ONES ON MY XXX-S G+ ARE 1" (PURPLE/SILVER) I BOUGHT SOME BLUES TODAY..THEY WERE LONGER.
WHAT'S A GOOD STARTING POINT FOR A 19T ON A SMALL OUTDOOR ASPHALT TRACK USING A 128T SPUR.
THANX
THANX
For anyone who is looking at this car to buy, I am selling a like new one on here, here is the link:
http://www.rctech.net/forum/showthre...threadid=46532
THANX
THANX
THANX
THANX
E
- JayBee
oh, ya, thats too bad, maybe someone else will see it
thanks though
thanks though
Hi All,
Let's see if anyone is smarter then rccaraction. In the fall 2004 Touring Car mag., they have BK's XXX-S G+ car. They give an inside look thought his whole car and in one description of the shock towers it says this. "Trinity blue-graphite shock towers", now after looking for these sweet looking parts I am lost. Does anyone know a part # or even if Trinity did these? I think Kinwald made them.
Originally posted by xxx2fast4u
Hi All,
Hi All,
need a pinion range for 64p on 128 spur for stock
I just picked up a xxx-s for my brother and it came with 64p spurs. Since I don't have any 64p pinions I'd like to know a good range to buy for use in stock with the 128(blue) and/or the 118(yellow) spurs. Motor-wise he's gonna start out with an MVP but I'm sure he'll move up to something like the monster in short order. Thanks.
Re: need a pinion range for 64p on 128 spur for stock
Battery strap
Here is an easy way to eliminate 1/4 ounce from the XXX-S battery strap.
Re: Battery strap
BTW...are you going to Modesto next weekend for their night race?
