Old 07-20-2004, 10:42 PM   #11611
HarshGuy's Avatar
Originally posted by mwcet8k
You tore apart the drag link?!!! Impressive!!
Yea I have no clue how ..I don't "remember" hitting anything, just all of a sudden I had no steering.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 07-20-2004, 10:43 PM   #11612
HarshGuy's Avatar
Originally posted by STLNLST
Rookie...
I know, imagine how I felt right there in front of all those people at a nats, and I break out becuase of a screw ...wasn't even a takeout or anything manly like that!!
Old 07-21-2004, 02:52 AM   #11613
Default xxx-s g+ diff slipping
After having problems with my other car I rebuilt my Losi to give that a whirl at tonights meeting. I have rebuilt the diffs as per the instructions and even when virtually locked they are both slipping like crazy.
Any idea what could be causing this?
Only thing I have done different is to use black grease (which I use on my HPI with no probs) on the thrust race rather than the red grease that comes with the kit.
Rich_p is offline   Reply With Quote
Old 07-21-2004, 05:53 AM   #11614
HarshGuy's Avatar
Default Re: xxx-s g+ diff slipping
Do you have those wierd little beveled washers in the correct side?
Old 07-21-2004, 06:18 AM   #11615
Its all as per the instructions, weird eh! Guess I'll have to strip them both down and build them again.
Should be fun I only have 30mins between getting in from work and leaving for racing!
Old 07-21-2004, 06:57 AM   #11616
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
This may sound kinda harsh but something has to be wrong. If there built per instructions there gonig to work. Just rebuild them and make sure EVERY part is the same.
Kave is offline   Reply With Quote
Old 07-21-2004, 07:15 AM   #11617
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Not really harsh but normally when someone says something is not working right they are not put together correctly. It might be better to have another person go over it with you because alot of times you look at something so much that you miss something. I have done it many times that the more I look the more I miss the simple problem.
I had a perosn just last week that had a problem with his diff and he rebuilt it twice right in front of me. It was not working still. I looked at it closely to find out he had 7 thrust balls instead of the 6 that Associated wanted for the GT. With 7 balls the thrust bearings couldn't move properly and would loosen up. Once we changed it the diff was smooth and worked perfectly.
It is very easy to overlook stuff as I think it is safe to say we all have when building or re building our cars.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
Old 07-21-2004, 07:17 AM   #11618
wyd
Tech Legend
wyd's Avatar
Have any of you guys tried the Low roll center blocks on the front of the car when running foams on asphalt? Wonder how much more steering it might give me vs. the stock G+ high roll center blocks. I was thinking of trying this sometime just to see what happens. Might give me the tad extra steering I want without being too aggressive.
Old 07-22-2004, 10:07 AM   #11619
Randy Caster's Avatar
Trader Rating: 46 (100%+)
If anyone wants a new XXXS G+ I have one up for sale in the for sale forum, I'll build it however you want it built.
Old 07-22-2004, 01:32 PM   #11620
imjonah's Avatar
Default Steering problem
Last night my XXX-S was un-drivable. On carpet even at relatively slow speed any attempt to turn caused the car to spin around 180 degrees. It happened at such a low speed that I doubt it was caused by poor chassis setup.
I have recently switched from an older AM Transmitter to a Airtronics MX-3. I checked all the settings on the MX-3 and they all seem to be the default except for servo which I had to set in REV mode.
It seems like when I turn the wheel to make a turn; it either is turning to much or it doesn't stop turning soon enough so , so sharp is the turning that the tail end breaks loose and the car spins 180 degrees. With the car up on a stand the steering servo seems to be ok and seems to be re-centering it self.
I have a servo that is supposed to be faster than stock like .15 stock being .19.
I do not know if it is relevant but I have a bad habit of giving the wheel a bit of a turn and then releasing it (taking my fingers off the wheel for a second) and allowing the spring in the wheel to take it back to the center. Is it possible that the computer radio does not return to zero as fast as say an analog controller with maybe a stronger spring setting.
Other thought that maybe this is analogous to pulling the safety brake on in a real moving car in order to purposefully turn 180 and go the other direction. For some reason the rear wheels are locking up when I try to turn and reduce throttle going around a corner. Any ideas?
If something jumps out at you, it would help otherwise I think I am going to have to swap out the receiver and transmitter and maybe the servo to eliminate them as culprits.
imjonah is offline   Reply With Quote
Old 07-22-2004, 02:02 PM   #11621
Check for any bind in the car at all, and possibly go to softer rear springs.
Old 07-22-2004, 02:04 PM   #11622
EricF's Avatar
Post
How much drag brake do you have? When you let off the gas the motor come to an abrupt halt or does it slow to a stop?
AE 12R5.2 (x2) - TC7 - M05 - M05V2R
People who don't have to wait for the latest item, should not tell those that do, that "It's worth the wait"
EricF is offline   Reply With Quote
Old 07-22-2004, 02:25 PM   #11623
Korey Harbke's Avatar
I also have a losi g+ for sale with lots of spares, a reedy mvp, trinity binary stock, novak cyclone (almost brand new), and a good smc battery pack (1.175v) It;s posted in the for sale forum...
-Korey
Apex RC - Prospec America - LRP - Roche RC USA - Awesomatix USA - Protoform - AVID - Xenon - Xpert - Sanwa - Sweep - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 07-22-2004, 06:34 PM   #11624
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
-Korey
looking to get some more 'stuff ' Korey
-JayBee
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 07-22-2004, 07:03 PM   #11625
wyd
Tech Legend
wyd's Avatar
Hey Randy I have a question for you. Did you ever have your car bind some when you put on the front diff cover. If I tighten the top 2 screws just snug the car binds up. When I spin the tires it kinda binds and as soon as I loosen them up so they almost touch the case it is fine. Is their a trick or something I'm missing? Never had it happen on my other Losi G+ I had last year. I do have an IRS spool in but it will do it if I put the diff in to.
2007 / 08 1/8th MNL Buggy and Truggy National Series Race Danny Teh Malaysian R/C Racers 856 01-04-2009 07:04 PM
Losi xxx 2wd connyw R/C Items: Wanted to Buy 10 10-31-2008 03:31 PM
NITRO SELLOUT!!! CRT.5**XXX-NT AD1**XTM XCELLORATOR** Novak GTX with BATT duneordie R/C Items: For Sale/Trade 12 06-27-2008 06:28 PM
XXX Parts, B4 jelly Australia For Sale/Trade 10 06-22-2006 06:13 PM
